Home » Eclipse Projects » Remote Application Platform (RAP) » Doing POST to external server
Doing POST to external server [message #641873] |
Mon, 29 November 2010 02:18 |
Gustavo Messages: 12 Registered: July 2009 |
Hi there
I'm trying to develop a Button that works like the Amazon FPS payment
button which does a POST action when clicked.
I have tried the following:
- Use PrintWriter from RWT.getResponse().getWriter(). When I use this
and try to print the <form> tag (and its hidden fields) the browser
shows an InvalidStateException: WRITER message.
- I also created an Equinox Servlet so I perform a redir and delegate
<form> tag creation (and its hidden fields) also using PrintWriter
object, but the browser shows "Session expired".
Now I'm trying to create a custom widget that uses an
qx.io.remote.Request instance and override _sendChanges Button's method
(my class inherits from org.eclipse.rwt.widgets.Button):
members : {
_sendChanges : function() {
this.info("debugging in qooxdoo!!!!!!!!!!");
req = new
qx.io.remote.Request(" https://authorize.payments-sandbox.amazon.com/pba/paypipelin e",
"POST", "text/html");
req.setParameter("returnUrl","");
req.setParameter("ipnUrl","");
req.setParameter("processImmediate","1");
req.setParameter("accessKey","AKIAI40KDLFJYS5P4KGQ");
req.setParameter("signatureMethod","HmacSHA256");
req.setParameter("fixedMarketplaceFee","0.01");
req.setParameter("referenceId","test-reference123");
req.setParameter("cobrandingStyle","logo");
req.setParameter("recipientEmail","test@amazon.com");
req.setParameter("immediateReturn","0");
req.setParameter("amount","USD 1.1");
req.setParameter("description","description");
req.setParameter("abandonUrl","");
req.setParameter("variableMarketplaceFee","4");
req.setParameter("signatureVersion","2");
req.setParameter("signature","lpILGczDhpecyQAtr8BjOji4ex7CVh7+26bwwKiuZT4= ");
req.setCrossDomain(true);
req.send();
Until now when I click on the Button instance I get nothing, not even
the logger line. Can anybody help me please?
Gustavo
Re: Doing POST to external server [message #642017 is a reply to message #641873] |
Mon, 29 November 2010 13:27 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Gustavo,
are you running your application in "debug" mode? Please check your
launch configuration settings - "Client-side library variant" and
"Client-side log level".
Best,
Ivan
On 29.11.2010 4:18 AM, Gustavo wrote:
> Hi there
> method (my class inherits from org.eclipse.rwt.widgets.Button):
> members : {
> req = new
> req.send();
> Thanks
> Gustavo
Re: Doing POST to external server [message #642128 is a reply to message #642017] |
Tue, 30 November 2010 00:12 |
Gustavo Messages: 4 Registered: November 2010 |
Hi Ivan
Yes, I'm running my application in debug mode and also set Client-side
log level to "All". I haven't found "Client-side library variant"
though, I'm using Eclipse Helios and RAP 1.3.
When the application starts it shows the Qooxdoo logging window, but
when I click on my button the log window shows nothing.
Best Regards.
Gustavo
On 11/29/2010 11:27 AM, Ivan Furnadjiev wrote:
> Hi Gustavo,
> Best,
> Ivan
>> Hi there
>> members : {
>> req = new
>> req.send();
>> Thanks
>> Gustavo
Re: Doing POST to external server [message #642383 is a reply to message #642128] |
Wed, 01 December 2010 07:23 |
Hi Gustavo,
I don't see any reason why the overrided _sendChanges function is not
called. Maybe you create an instance of "org.eclipse.rwt.widgets.Button"
in your custom widget LCA instead of your custom widget javascript
class?! Without a complete code of your custom button I can't help you much.
Best,
Ivan
On 30.11.2010 2:12 AM, Gustavo wrote:
> Hi Ivan
> Best Regards.
> Gustavo
>> Hi Gustavo,
>> Best,
>> Ivan
>>> Hi there
>>> members : {
>>> req = new
>>> req.send();
>>> Thanks
>>> Gustavo
Re: Doing POST to external server [message #642610 is a reply to message #642383] |
Thu, 02 December 2010 00:43 |
Hi Ivan
Your hint about the LCA class made me see I wasn't using the correct
pattern required by RAP. Now my widget is at least showing the log line
but still not getting the effect I want: do a POST so I show the Amazon
FPS front-end. I have some ideas, I will let you know if it works!!
Gustavo
On 12/01/2010 05:23 AM, Ivan Furnadjiev wrote:
> Hi Gustavo,
> much.
> Best,
> Ivan
>> Hi Ivan
>> Best Regards.
>> Gustavo
>>> Hi Gustavo,
>>> Best,
>>> Ivan
>>>> Hi there
>>>> members : {
>>>> req = new
>>>> req.send();
>>>> Thanks
>>>> Gustavo
Current Time: Fri Apr 26 04:20:24 GMT 2024
Powered by FUDForum. Page generated in 0.03446 seconds
