Unable to compile class for JSP [message #641528] |
Thu, 25 November 2010 20:12 |
No real name Messages: 3 Registered: November 2010 |
Junior Member |
I'm getting this extremely frustrating error. I've tried all the solutions I could find on the web: including adding JDK to my project build path and adding tools.jar to my lib.
I'm running the google app engine eclipse plugin btw.
It's still not working....can someone please advise me on how to fix this issue?
Here's the error:
HTTP ERROR 500
Problem accessing /gps.jsp. Reason:
Generated servlet error:
[javac] C:\Users\jhwang\AppData\Local\Temp\Jetty_127_0_0_1_8888_war_ ___.g0qk00\jsp\org\apache\jsp\gps_jsp.java:124: 'catch' without 'try'
[javac] } catch (Throwable t) {
[javac] ^
[javac] C:\Users\jhwang\AppData\Local\Temp\Jetty_127_0_0_1_8888_war_ ___.g0qk00\jsp\org\apache\jsp\gps_jsp.java:124: ')' expected
[javac] ^
[javac] C:\Users\jhwang\AppData\Local\Temp\Jetty_127_0_0_1_8888_war_ ___.g0qk00\jsp\org\apache\jsp\gps_jsp.java:124: not a statement
[javac] ^
[javac] C:\Users\jhwang\AppData\Local\Temp\Jetty_127_0_0_1_8888_war_ ___.g0qk00\jsp\org\apache\jsp\gps_jsp.java:124: ';' expected
[javac] ^
[javac] C:\Users\jhwang\AppData\Local\Temp\Jetty_127_0_0_1_8888_war_ ___.g0qk00\jsp\org\apache\jsp\gps_jsp.java:131: 'finally' without 'try'
[javac] } finally {
[javac] ^
[javac] C:\Users\jhwang\AppData\Local\Temp\Jetty_127_0_0_1_8888_war_ ___.g0qk00\jsp\org\apache\jsp\gps_jsp.java:37: 'try' without 'catch' or 'finally'
[javac] try {
[javac] ^
[javac] C:\Users\jhwang\AppData\Local\Temp\Jetty_127_0_0_1_8888_war_ ___.g0qk00\jsp\org\apache\jsp\gps_jsp.java:135: reached end of file while parsing
[javac] }
[javac] ^
[javac] 7 errors
Caused by:
org.apache.jasper.JasperException: Unable to compile class for JSP
[javac] ^
[javac] ^
[javac] ^
[javac] ^
[javac] } finally {
[javac] ^
[javac] try {
[javac] ^
[javac] }
[javac] ^
[javac] 7 errors
at org.apache.jasper.compiler.DefaultErrorHandler.javacError(De faultErrorHandler.java:84)
at org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorD ispatcher.java:332)
at org.apache.jasper.compiler.Compiler.generateClass(Compiler.j ava:412)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:47 2)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:45 1)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:43 9)
at org.apache.jasper.JspCompilationContext.compile(JspCompilati onContext.java:511)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:295)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:292)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java :236)
at com.google.appengine.tools.development.PrivilegedJspServlet. access$101(PrivilegedJspServlet.java:23)
at com.google.appengine.tools.development.PrivilegedJspServlet$ 2.run(PrivilegedJspServlet.java:59)
at com.google.appengine.tools.development.PrivilegedJspServlet. service(PrivilegedJspServlet.java:57)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:806)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:511)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilte r(ServletHandler.java:1166)
at com.google.appengine.api.blobstore.dev.ServeBlobFilter.doFil ter(ServeBlobFilter.java:58)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilte r(ServletHandler.java:1157)
at com.google.apphosting.utils.servlet.TransactionCleanupFilter .doFilter(TransactionCleanupFilter.java:43)
at com.google.appengine.tools.development.StaticFileFilter.doFi lter(StaticFileFilter.java:122)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:388)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHa ndler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandl er.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandl er.java:765)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext. java:418)
at com.google.apphosting.utils.jetty.DevAppEngineWebAppContext. handle(DevAppEngineWebAppContext.java:70)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapp er.java:152)
at com.google.appengine.tools.development.JettyContainerService $ApiProxyHandler.handle(JettyContainerService.java:349)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnectio n.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComple te(HttpConnection.java:923)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:547)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java: 212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java: 404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThr eadPool.java:582)
[Updated on: Thu, 25 November 2010 20:13] Report message to a moderator
Re: Unable to compile class for JSP [message #643696 is a reply to message #641771] |
Tue, 07 December 2010 21:55 |
On 11/27/2010 2:26 PM, jhwang@go.wustl.edu wrote:
You seem to be missing the close brace matching the one that opens at
the end of this line:
> } else {
I'm not sure why the JSP Validator is not reporting something to you.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.08917 seconds
