CNF: How can ContentProvider determine project of an object? [message #641289] |
Wed, 24 November 2010 18:18 |
Originally posted by: yoduderoo.netscape.net
I use Common Navigator Framework in an RCP app. The user creates
projects and under each project are domain objects which are retrieved
from a DB.
For the content provider methods such as hasChildren(Object element), I
need to know the project to which the passed domain object belongs
(i.e., element argument in hasChildren()).
How does one determine the nav tree path of an element passed to a
content provider?
Thanks, -yo
Re: CNF: How can ContentProvider determine project of an object? [message #641520 is a reply to message #641498] |
Thu, 25 November 2010 19:15 |
The objects are not IResource but rather EMF objects retrieved from a
database.
Thanks, y
Francis Upton wrote:
> You don't need to worry about navigating the tree of the objects if the
> object is an IResource (which it will be if you are using the CNF
> against a workspace. Check if it's an IResource and use
> IResource.getProject().
Re: CNF: How can ContentProvider determine project of an object? [message #641521 is a reply to message #641520] |
Thu, 25 November 2010 19:27 |
Ed Merks Messages: 33142 Registered: July 2009 |
I don't think anyone can answer this question. There isn't a general
way to know the project of an EObject. Certainly one can use
EObject.eResource() to determine the containing resource and
Resource.getURI() to determine that resource's URI. If it's of the form
platform:/resource/ (URI.isPlatformResource() is true) you can map that
to a workspace IResource (as described in the FAQ). In the end though,
I think only you have the specific knowledge to answer your own question.
> database.
> Thanks, y
>> the object is an IResource (which it will be if you are using the CNF
Ed Merks
FUDForum. Page generated in 0.03398 seconds
