Home » Eclipse Projects » Eclipse Platform » CNF: How can ContentProvider determine project of an object?
CNF: How can ContentProvider determine project of an object? [message #641289] Wed, 24 November 2010 13:18 Go to next message
Originally posted by: yoduderoo.netscape.net
I use Common Navigator Framework in an RCP app. The user creates
projects and under each project are domain objects which are retrieved
from a DB.
For the content provider methods such as hasChildren(Object element), I
need to know the project to which the passed domain object belongs
(i.e., element argument in hasChildren()).
How does one determine the nav tree path of an element passed to a
content provider?
Thanks, -yo
Re: CNF: How can ContentProvider determine project of an object? [message #641498 is a reply to message #641289] Thu, 25 November 2010 12:05 Go to previous messageGo to next message
You don't need to worry about navigating the tree of the objects if the object is an IResource (which it will be if you are using the CNF against a workspace. Check if it's an IResource and use IResource.getProject().
Re: CNF: How can ContentProvider determine project of an object? [message #641520 is a reply to message #641498] Thu, 25 November 2010 14:15 Go to previous messageGo to next message
The objects are not IResource but rather EMF objects retrieved from a
database.
Thanks, y
Re: CNF: How can ContentProvider determine project of an object? [message #641521 is a reply to message #641520] Thu, 25 November 2010 14:27 Go to previous message
I don't think anyone can answer this question. There isn't a general
way to know the project of an EObject. Certainly one can use
EObject.eResource() to determine the containing resource and
Resource.getURI() to determine that resource's URI. If it's of the form
platform:/resource/ (URI.isPlatformResource() is true) you can map that
to a workspace IResource (as described in the FAQ). In the end though,
I think only you have the specific knowledge to answer your own question.
> database.
> Thanks, y
Previous Topic:Unable to compile class for JSP
Next Topic:FormEditor and Refresh editor pages
Current Time: Fri Oct 31 21:50:13 EDT 2025
Powered by FUDForum. Page generated in 0.05813 seconds
