Re: [QVTo] Errors importing a blackbox library [message #641808 is a reply to message #640985] |
Sun, 28 November 2010 10:47 |
Toñi Reina Messages: 209 Registered: July 2009 |
finally I found what the problem was. I'm going to report it in case
someone could find it useful.
The problem was that I wrote the class name in the import sentence
org.mwacsl.SWC2jsp.lib.MWACSLUtilitiesLibrary. However, the right
sentence should include the namespace and the unit name.
import m2m.qvt.oml.MWACSLUtilitiesLibrary;
This information can be found in the plugin.xml file attached to the
library project.
<?eclipse version="3.7"?>
<plugin>
<extension point="org.eclipse.m2m.qvt.oml.javaBlackboxUnits">
<unit name="MWACSLUtilitiesLibrary" namespace="m2m.qvt.oml">
<library name="MWACSLUtilitiesLibrary"
class="org.mwacsl.SWC2jsp.lib.MWACSLUtilitiesLibrary">
<metamodel nsURI="http://www.eclipse.org/emf/2002/Ecore"/>
</library>
</unit>
</extension>
</plugin>
Furthermore, I have to create the plugin from the MWACSLUtilitiesLibrary
project and installed it.
Toñi
El 23/11/2010 19:14, Toñi Reina Quintero escribió:
> Hi all,
> I' m trying to write a blackbox library in Java to add some
> functionality to some extra methods.
> I have found the following resource:
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.qvtoml/doc/org.eclipse.m2m.qvt.oml.doc/references/b lackboxing.html?root=Modeling_Project&view=co
> I have installed the example at 'Examples/Operational QVT
> Transformation/Black-box Library Definition'wizard and downloaded the
> project org.eclipse.emf.compare from eclipse svn because it also has an
> example of blackboxing at org.eclipse.emf.compare.mpatch.emfdiff2mpatch.
> The problem is that the import sentence in the qvto files has an error
> whose text is "Cannot find imported compilation unit
> 'org.mwacsl.SWC2jsp.lib'.
> I have been looking for similar problem described in the messages posted
> in the eclipse m2m forum, but although I have found some, I haven't
> found any answer.
> How can I configure in a QVT project where the blackbox libraries can be
> found? Is there something similar to Java Build Path to specify this
> configuration?
> I have created a project that holds the Java code, based on the example
> at the wizard. Then I have created a plugin and installed it in my
> Eclipse. But I does not work.
> Can anyone give me a hint?
> Regards,
> Toñi Reina
FUDForum. Page generated in 0.04025 seconds
