| How to write % char within xml that is included for org.eclipse.ui.editors.templates [message #640849] |
Tue, 23 November 2010 05:52  |
I want to write % char within xml file. Whenever xml is parsed by eclipse it tries to search for localized string since % is used in xml to get localized string from .properties file. Is there a way by which you can exclude % from parsing.
This happens specially when you implement extension point org.eclipse.ui.editors.templates and add new include and specify xml file to read the templates.
For example your included xml file can have this.
<templates>
<template name="test" id="xyz"
description="%test.Description" context="java" enabled="true"
> </template>
for(int i;i<10;i++){
${:link('100%')}
When i start eclipse and view these templates it comes as
${:link('100!')}
</templates>
note ! mark. while debugging i found that its trying to find localized string which is empty. so ! is displayed.
FUDForum. Page generated in 0.03204 seconds
