Re: Exception in a Lib with a Table using group & aggregation [message #640679 is a reply to message #640599] |
Mon, 22 November 2010 18:57 |
Is the dataset in a library?
On 11/22/2010 10:23 AM, Anthony S wrote:
> Hello,
> On a report I made table with a group (bases on a data set computed
> column). In group Header of my table i make an aggregation Sum on a
> colomn of my data Set.
> Birt 2.6 (Actuate 11)
> when I put this on a libarie it does not work anymore. I have an
> exception saying the group I defined does not exist. I do not understand
> because it works when it's in the report and not in a library.
> ERROR : Group "groupSreadCommRate" used in column
> Aggr-Sum-SpreadCommRate-Notional does not exist.
Re: Exception in a Lib with a Table using group & aggregation [message #640978 is a reply to message #640966] |
Tue, 23 November 2010 17:55 |
Can you email me the library and the report design? Or preferably build
a library and report off the sample db that shows the problem and post them?
Jason
On 11/23/2010 12:26 PM, Anthony S wrote:
> I made some tests
> My library containing my Table using a group with an aggregation is in a
> Grid : Library : Grid Row ---- col ---- Table
> Row ---- col ---- (empty : will be filled later)
> In this configuration I have an error that group in my Table does not
> exists.
> I tried this : Library : Table (no grid, nothin else)
> and it works.
> It seems the problem is linked to the fact my Table is embedded in a
> Grid. Have you ever seen this problem ?
> Is there another solution than do not use the Grid and only put directly
> the Table ?
Re: Exception in a Lib with a Table using group & aggregation [message #642027 is a reply to message #641933] |
Mon, 29 November 2010 15:29 |
I sent it to
anthonyserfati at hotmail dot com
I Tried the jar you sent me ( two report libraries and a report) and ran
it in 2.6.1 and it ran for me. Are you using 2.6.1 or 2.6.0?
Jason
On 11/29/2010 5:05 AM, Anthony S wrote:
> Which mail ?
> Can you send it again to :
> - anthony DOT serfati-ext AT sgcib DOT com
> - neozerabbit AT hotmail DOT com
Re: Exception in a Lib with a Table using group & aggregation [message #642108 is a reply to message #642027] |
Mon, 29 November 2010 21:12 |
Anthony S Messages: 19 Registered: September 2010 |
2.6.0 & 2.6.1
I finaly received it in the afternoon (France).
I do not undersand why you don't have the trouble it is very strange. We have constated it with Birt/Actuate Team.
The following versions are
OPEN SOURCE :
BIRT Chart Framework
Version: 2.6.0.v20100617-7f9T0FQCnv7wz02TTZ0LE1
Build id: v20100609-1613
EMF Mapping
Version: 2.6.0.v20100614-1136
Build id: R201006141136
Eclipse Plug-in Development Environment
Version: 3.6.0.v20100525-7b7mFKtFEx2XmfZ4_B7NUJA
Build id: I20100608-0911
ACTUATE TRIAL VERSION
Actuate Open Data Access (ODA) and Adapter
Version : 11.0.0
EMF Mapping
Version: 2.6.0.v20100914-1218
Build id: R201009141218
Eclipse Platform
Version: 3.6.1.r361_v20100909-9gF78GrkFqw7GrsZnvz0JWNTeb6fue6896L
Build id: M20100909-0800
[Updated on: Tue, 30 November 2010 09:07] Report message to a moderator
Re: Exception in a Lib with a Table using group & aggregation [message #642257 is a reply to message #642108] |
Tue, 30 November 2010 15:49 |
I used 2.6.1 and did not see the issue. Do you have a support case open
with Actuate?
Jason
On 11/29/2010 4:12 PM, Anthony S wrote:
> I finaly received it in the afternoon (France). I do not undersand why
> Birt/Actuate Team.
> The following version are
> OPEN SOURCE : BIRT Chart Framework
> ACTUATE TRIAL VERSION Actuate Open Data Access (ODA) and Adapter Version
> : 11.0.0
> Eclipse Platform
FUDForum. Page generated in 0.05570 seconds
