XML ERROR in Workbook Setting when opening exported excel [message #640145] |
Fri, 19 November 2010 10:34 |
Hai Feng Luo Messages: 3 Registered: November 2010 |
an error shows in log like:
REASON: Bad Value
FILE: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Report-42.xls
GROUP: Names
TAG: NamedRange
ATTRIB: Name
VALUE: R2A
is showing when I try to open a excel, which is exported from my BIRT report.
My birt version is 2.3.2. And then I checked my excel file, and found this:
<NamedRange ss:Name="R2A" ss:RefersTo="=Sheet1!R2162C1"/>. If I change R2A to RA, then the excel can be opened
successfully. I also tested it for many times, and found if the name is started with "R number letter" format, the error will
happen.
I'm really confused and have two questions as below:
1, Is the format like "R2A" are illegal for NamedRange name? Does birt has any defined rules for this?
2, If not, can we treat this as a birt bug?
Any input is appreciated, thanks!
Re: XML ERROR in Workbook Setting when opening exported excel [message #640909 is a reply to message #640752] |
Tue, 23 November 2010 13:57 |
Are you using the default BIRT excel emitter? Can you post the report
design?
Jason
On 11/22/2010 8:55 PM, Hai Feng Luo wrote:
> Hi Jason, currently I didn't test that on 261, I tested on 252, the same
> problem, as our product use 232 and 252. Seems that the NameRange name
> is not supported. Should we consider it as a defect?
FUDForum. Page generated in 0.03604 seconds
