Home » Newcomers » Newcomers » Windows Eclipse and MinGW. How?(Cannot get Hello World to compile.)
Windows Eclipse and MinGW. How? [message #639398] Tue, 16 November 2010 07:25 Go to next message
Hi all,
I am running Windows XP, and wish to use Eclipse to develop C and C++ projects, using GCC to compile them.
I have installed Eclipse Helios Service Release 1 (Build id: 20100917-0705), and it seems to work fine.
I have installed MinGW into the default directory and added the path, and it seems to work fine. (Eclipse finds it, and also I can type gcc -v at the command line, and gcc runs ok.)
I started a new Hello World ANSI C project in Eclipse, and selected MinGW GCC toolchain.
I clicked build, and got this error:
**** Build of configuration Debug for project Hugo2 ****
**** Internal Builder is used for build ****
g++ -O0 -g3 -Wall -c -fmessage-length=0 -osrc\Hugo2.o ..\src\Hugo2.cpp
Build error occurred, build is stopped
Time consumed: 281 ms.
I cannot for the life of me understand what this means. What's the error? Have I missed something obvious? Please help.
Many thanks in advance.
Hugo
Re: Windows Eclipse and MinGW. How? [message #639440 is a reply to message #639398] Tue, 16 November 2010 09:45 Go to previous messageGo to next message
Did you look at the sticky post at the top of this forum?
http://www.eclipse.org/forums/index.php?t=msg&th=161206& amp;start=0&S=d20ba64362c192fa78017d00566a87cd
It helps a lot to go looking for answers before assuming you're the only
one who has had the problem. For example, out there I find:
http://stackoverflow.com/questions/1475415/having-trouble-bu ilding-c-project-in-eclipse-cdt-in-os-x-for-a-silly-reason
http://stackoverflow.com/questions/2606740/internal-builder- cannot-run-program-g-the-system-cannot-find-the-file-speci
http://dev.eclipse.org/newslists/news.eclipse.tools.cdt/msg1 4387.html
....and many more.
On 2010.11.16 5:25, Hugo wrote:
> Hi all,
> Hugo
Re: Windows Eclipse and MinGW. How? [message #1703177 is a reply to message #639398] Wed, 29 July 2015 03:11 Go to previous message
I'm getting the same error and haven't been able to find a workable solution as yet. Please help!
Previous Topic:Installer does not show full tree / github anymore
Next Topic: Where is the resources section now that was in this site now?
Current Time: Fri Jul 04 22:16:36 EDT 2025
Powered by FUDForum. Page generated in 1.13096 seconds
