[Flock] equivalent() not working [message #638912] |
Sat, 13 November 2010 06:55 |
Mark Tippetts Messages: 25 Registered: July 2009 |
ehlo,
I'm having some trouble with the following line in a Flock migration. I'm not sure if it's my mistake, or a bug?
var newModel : Migrated!GuidanceModel := oldModel.equivalent();
Evidently, equivalent() is returning the original, rather than the migrated, object. I get the same result using the ::= syntax. It produces the following stack trace:
!ENTRY org.eclipse.epsilon.common.dt 4 0 2010-11-13 01:13:45.078
!MESSAGE Error encountered whilst executing Flock migration strategy for: C:/Eclipse/Workspaces/Golemware/DesignLayer/net.golemware.eclipsepsm.design/design/EclipsePSM.guidance
!STACK 0
Exception encountered while executing EOL block.
at org.eclipse.epsilon.flock.FlockContext.executeBlock(FlockContext.java:101)
at org.eclipse.epsilon.flock.model.Body.applyTo(Body.java:31)
at org.eclipse.epsilon.flock.execution.MigrateRuleBasedEquivalence.applyStrategyToPopulateEquivalent(MigrateRuleBasedEquivalence.java:33)
at org.eclipse.epsilon.flock.execution.Equivalences.populateEachEquivalent(Equivalences.java:61)
at org.eclipse.epsilon.flock.MigrationStrategyRunner.populateEachEquivalent(MigrationStrategyRunner.java:49)
at org.eclipse.epsilon.flock.MigrationStrategyRunner.run(MigrationStrategyRunner.java:37)
at org.eclipse.epsilon.flock.FlockContext.run(FlockContext.java:164)
at org.eclipse.epsilon.flock.FlockModule.execute(FlockModule.java:80)
at org.eclipse.epsilon.flock.FlockModule.execute(FlockModule.java:75)
at org.eclipse.epsilon.flock.dt.util.MigrationStrategyExecutor.migrate(MigrationStrategyExecutor.java:87)
at org.eclipse.epsilon.flock.dt.util.MigrationStrategyExecutor.run(MigrationStrategyExecutor.java:64)
at org.eclipse.epsilon.flock.dt.actions.ExecuteMigrationStrategy.migrateSelectionUsing(ExecuteMigrationStrategy.java:64)
at org.eclipse.epsilon.flock.dt.actions.ExecuteMigrationStrategy.run(ExecuteMigrationStrategy.java:54)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: Illegal assignment to variable 'newModel'. Expected Migrated!GuidanceModel and found GuidanceModel [name=EpsilonToolsCore.guidance, ] (5:8)
at org.eclipse.epsilon.eol.execute.context.Variable.setValue(Variable.java:73)
at org.eclipse.epsilon.eol.execute.AssignExecutor.execute(AssignExecutor.java:67)
at org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(ExecutorFactory.java:179)
at org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execute(StatementBlockExecutor.java:33)
at org.eclipse.epsilon.flock.FlockContext.executeBlock(FlockContext.java:93)
... 41 more
(BTW, I love the use of 'whilst'. This is far and away the most literate error message I've ever received!)
I'm using the latest (0.8.9.201011041158) interim build of Epsilon on Helios.Here's the entire migration strategy. I can provide the ecore models as well, if that would be helpful.
migrate Variable to WorkProductVariable
original.println('Migrating ');
var oldModel : GuidanceModel := original.eContainer().getModel();
newModel.variables.add(migrated);
var param := new Migrated!Parameter;
param.source := original.eContainer().equivalent();
param.target := migrated;
newModel.parameters.add(param);
operation UserGuide getModel() : GuidanceModel
if (self.eContainer().isKindOf(GuidanceModel)){
return self.eContainer();
return self.eContainer().getModel();
Mark
Re: [Flock] equivalent() not working [message #638981 is a reply to message #638912] |
Sun, 14 November 2010 10:42 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Mark,
Could you please send us the metamodels and a sample input model at
epsilon.devs gmail com?
Dimitris
On 13/11/2010 08:55, Mark Tippetts wrote:
> ehlo,
> for:
> C:/Eclipse/Workspaces/Golemware/DesignLayer/net.golemware.ec lipsepsm.design/design/EclipsePSM.guidance
> !STACK 0
> at
> org.eclipse.epsilon.flock.FlockContext.executeBlock(FlockCon text.java:101)
> at
> org.eclipse.epsilon.flock.execution.MigrateRuleBasedEquivale nce.applyStrategyToPopulateEquivalent(MigrateRuleBasedEquiva lence.java:33)
> at
> org.eclipse.epsilon.flock.execution.Equivalences.populateEac hEquivalent(Equivalences.java:61)
> at
> org.eclipse.epsilon.flock.MigrationStrategyRunner.populateEa chEquivalent(MigrationStrategyRunner.java:49)
> at
> org.eclipse.epsilon.flock.MigrationStrategyRunner.run(Migrat ionStrategyRunner.java:37)
> at org.eclipse.epsilon.flock.FlockContext.run(FlockContext.java :164)
> at org.eclipse.epsilon.flock.FlockModule.execute(FlockModule.ja va:80)
> at org.eclipse.epsilon.flock.FlockModule.execute(FlockModule.ja va:75)
> at
> org.eclipse.epsilon.flock.dt.util.MigrationStrategyExecutor. migrate(MigrationStrategyExecutor.java:87)
> at
> org.eclipse.epsilon.flock.dt.util.MigrationStrategyExecutor. run(MigrationStrategyExecutor.java:64)
> at
> org.eclipse.epsilon.flock.dt.actions.ExecuteMigrationStrateg y.migrateSelectionUsing(ExecuteMigrationStrategy.java:64)
> at
> org.eclipse.epsilon.flock.dt.actions.ExecuteMigrationStrateg y.run(ExecuteMigrationStrategy.java:54)
> at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
> at
> org.eclipse.epsilon.eol.execute.context.Variable.setValue(Va riable.java:73)
> at
> org.eclipse.epsilon.eol.execute.AssignExecutor.execute(Assig nExecutor.java:67)
> at
> org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(E xecutorFactory.java:179)
> at
> org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te(StatementBlockExecutor.java:33)
> at
> at
> org.eclipse.epsilon.flock.FlockContext.executeBlock(FlockCon text.java:93)
> ... 41 more
> Mark
FUDForum. Page generated in 0.03166 seconds
