Problems using Pydev [message #638806] |
Fri, 12 November 2010 16:06 |
jcdx Messages: 3 Registered: November 2010 |
Hi group,
I am a beginner with Eclipse and Python. I am using Mac OS 10.6.4 (Snow Leopard)
The installation of Eclipse runs and I can also run Python.
I get the following error when using e.g. the pylab or sympy package:
ImportError: dlopen(/opt/local/lib/python2.5/site-packages/matplotlib/_pa th.so, 2): no suitable image found. Did find:
/opt/local/lib/python2.5/site-packages/matplotlib/_path.so: mach-o, but wrong architecture
I performed a platform check within eclipse:
platform.mac_ver() gives
('10.6.4', ('', '', ''), 'i386')
the same check in the terminal gives:
('4294967306.4294967302.4294967300', ('', '', ''), '')
I found that here might be a problem with the "architecture", however I did not find a solution.
What do I have to do get all python packages working in Eclipse?
Actually the same python script runs without errors in the terminal.
Really need help on this.
Best regards
jcdx
FUDForum. Page generated in 0.02699 seconds
