Home » Eclipse Projects » Eclipse Platform » Show jarred content using internal browser
Show jarred content using internal browser [message #637956] Tue, 09 November 2010 08:14 Go to next message
we have a view that shows some html/css/png content
which is shipped inside the plug-in.
When the plug-in is unpacked during install the
internal browser is happy, however, as unpacking
plug-ins is deprecated I'm looking for ways how the
browser can display content directly from the jarred
plug-in.
Initially, I have a URL like this:
bundleentry://405.fwk29293232/guide/otjld/xdef/index.html
Previously we converted this using
FileLocator.resolve(url)
resulting in s.t. like
file:jar:pathtoplugin.jar!/guide/otjld/xdef/index.html
which doesn't work in the internal browser.
I then tried
FileLocator.toFileURL(url)
which nicely converts the url to some cache location
in the filesystem.
However, any relative URLs within that initial HTML
fail because those files have not been extracted
(included css and png).
Is there a way to let the internal browser see all the
files in the jarred plug-in?
TIA
Stephan
Re: Show jarred content using internal browser [message #638003 is a reply to message #637956] Tue, 09 November 2010 10:40 Go to previous messageGo to next message
Stephan Herrmann wrote:
> I then tried
> in the filesystem.
If you use bundleentry://405.fwk29293232/guide/otjld/xdef/ then the
entire folder/subfolder system should be extracted
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Show jarred content using internal browser [message #638057 is a reply to message #638003] Tue, 09 November 2010 14:04 Go to previous messageGo to next message
Paul Webster wrote on Tue, 09 November 2010 16:40
Great, that seems to do the trick.
Out of curiosity:
Is my interpretation correct that calling toFileURL() with
the URL of any contained directory will cause all content
of the given bundle to be extracted?
thanks,
Stephan
Re: Show jarred content using internal browser [message #638297 is a reply to message #638057] Wed, 10 November 2010 13:16 Go to previous messageGo to next message
> Out of curiosity:
> the URL of any contained directory will cause all content of the given
Maybe :-)
It specs it will return a file: URL for the system URL. If you did have
a legacy plugin as a directory, it would just point into there, if not
it extracts it.
The corollary is that this file location should still be treated as
read-only.
PW
Paul Webster
Re: Show jarred content using internal browser [message #638332 is a reply to message #638297] Wed, 10 November 2010 16:21 Go to previous messageGo to next message
Paul Webster wrote on Wed, 10 November 2010 19:16
> Out of curiosity:
Maybe Smile
You're not trying to confuse me, are you? Rolling Eyes
Spec guarantees: the one file pointed to by the URL will exist in the filesystem
You told me, passing a dir will cause that dir and all sub dirs to be extracted.
I observed the whole bundle being extracted.
To what degree can I rely on this undocumented extracting?
If you did have
it extracts it.
Yea, using a plugin as a directory everything was easy as pie.
Since I changed the plugin to jarred I need to be sure
whether the browser will reliably be able to follow
relative links starting from the one obtained from toFileURL().
If it works only "maybe" I may feel more comfortable going back
to the safe good-ol plugin-as-directory.
read-only.
rest assured: I wasn't even dreaming of writing to that location.
Stephan
Re: Show jarred content using internal browser [message #638488 is a reply to message #638332] Thu, 11 November 2010 08:18 Go to previous messageGo to next message
Sorry about rambling on :-)
> extracted.
This is well known behaviour, and is used in the SDK. It can be relied on.
PW
Paul Webster
Re: Show jarred content using internal browser [message #638490 is a reply to message #638488] Thu, 11 November 2010 08:40 Go to previous message
Paul Webster wrote on Thu, 11 November 2010 14:18
Great, one less worry Smile
thanks,
Stephan
Previous Topic:cvs update plugin
Next Topic:3.6.1 Helios update woes
Current Time: Mon Nov 10 09:04:43 EST 2025
Powered by FUDForum. Page generated in 0.05495 seconds
