Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » From Java Class to XMI(Generate an XMI File From a Java Class)
From Java Class to XMI [message #637608] Sun, 07 November 2010 14:22 Go to next message
I am not familier with EMF, i have to realise a program wich can generate an XMI file from a java class.
does anyone know how can i begin. thanks
Re: From Java Class to XMI [message #637611 is a reply to message #637608] Sun, 07 November 2010 14:37 Go to previous messageGo to next message
Am 07.11.2010 20:23, schrieb Ramos:
> Hello,
Lars has done a nice tutorial to import Ecore from Java: http://www.vogella.de/articles/EclipseEMFAnnotations/index.h tml
The resulting model can be moved/copied to an XMIResource and saved. Voilà ;-)
Cheers
/Eike
http://www.esc-net.de
Re: From Java Class to XMI [message #637649 is a reply to message #637608] Mon, 08 November 2010 03:24 Go to previous messageGo to next message
Originally posted by: formatzeh.gmx.de
Or you can checkout the Java parser and printer from
http://www.jamopp.org You just have to install the Plugin and you'll
get a Java editor which is model based. That means you have a full Java
metamodel and its textual syntax. So you open your Java files with that
editor and just invoke "save as...". Specify YourJavaClass.xmi as new
file name and you're done.
best regards,
Gilbert
Re: From Java Class to XMI [message #637745 is a reply to message #637649] Mon, 08 November 2010 11:29 Go to previous message
I'm not sure to understand your question but if you need to get a "model view" of Java code you can also have a look to the MoDisco's Java Discover.
Here is the documentation: http://wiki.eclipse.org/MoDisco/Components/Java/Documentatio n/0.8#Java_Discoverer
To install MoDisco you should have a look to the following page: http://wiki.eclipse.org/MoDisco/Installation
Gregoire
Previous Topic:[EMF Store] ECP - Can it be used without EMFStore?
Next Topic:Importing EMFatic into an EMF project
Current Time: Sun Jul 27 03:10:03 EDT 2025
Powered by FUDForum. Page generated in 0.04491 seconds
