Home » Archived » BIRT » Cascading report parameters
Cascading report parameters [message #637197] |
Thu, 04 November 2010 14:48 |
mkrivic Mising name Messages: 33 Registered: May 2010 |
Member |
I have the following situation:
In one dataset called Projects and I have two attributes in it: leader, project
In second dataset called People and I have two attributes in it: projects, people
When I build cascading parameter group based on single dataset (Projects), and create two parameters in it (leader,project1), I get all projects for specific leader.
then, I want to build another cascading parameter group based on single dataset (People), and create two parameters in it (project2, people).
Is there possible that somehow I use project1 parameter value as default value for dataset People (project2 parameter should use this value), and in that way I can get peoples in that projects?
Example:
In first cascading group, If I choose Leader1, I get Project1, Project2,Project3...
Then, If I choose Project2 from second parameter in this group, I get Man1, Man2, Man3 in second cascading group assuming that Man1, Man2, Man3 belong to Project2.
If my question is not understandable, let me know.
Regards, and thanks,
Re: Cascading report parameters [message #637261 is a reply to message #637197] |
Thu, 04 November 2010 18:00 |
could you not just create a joint dataset with both datasets and put all
the parameters in the same cascade or use a multi-dataset cascade?
Jason
On 11/4/2010 10:48 AM, mkrivic wrote:
> project
> projects, people
> Example:
Current Time: Sat Apr 27 02:36:11 GMT 2024
Powered by FUDForum. Page generated in 0.03169 seconds
