Home » Modeling » Papyrus » "Repository moved permanently ..."(Cannot access Papyrus SVN location)
"Repository moved permanently ..." [message #636561] Mon, 01 November 2010 17:39 Go to next message
When I want to access the Papyrus SVN repository, with Subclipse, using the adresse
https://speedy.supelec.fr/Papyrus/svn/Papyrus/
which is specified here
http://www.papyrusuml.org/scripts/home/publigen/content/temp lates/show.asp?P=114&L=EN&ITEMID=16
I get this surprising error from the SVN client :
Repository moved permanently to 'https://speedy.supelec.fr/Papyrus/svn/Papyrus/'; please relocate
It says the repository has moved... to the exact same location as the one entered.
What's wrong here ?
Subclipse is working fine, as I've checked with the ArgoUML SVN. This seems to be something wrong with the Papyrus SVN.
Re: "Repository moved permanently ..." [message #636572 is a reply to message #636561] Mon, 01 November 2010 19:34 Go to previous messageGo to next message
I get the same error using another client, a command line SVN. I suppose this means no body is working on the source actually, otherwise someone would have noticed the SVN is broken.
Do anybody know since when it is broken ?
Re: "Repository moved permanently ..." [message #636596 is a reply to message #636561] Tue, 02 November 2010 03:03 Go to previous messageGo to next message
OK, the above SVN URL was the one of a previous Papyrus.
The URL for the actual is here :
http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus
This is explain in this topic :
http://www.eclipse.org/forums/index.php?t=msg&goto=63057 2
Re: "Repository moved permanently ..." [message #636614 is a reply to message #636596] Tue, 02 November 2010 05:02 Go to previous messageGo to next message
Hi Yannick,
thanks for your feedback. Hope this will helps next users!
regards
Rémi
Re: "Repository moved permanently ..." [message #636662 is a reply to message #636561] Tue, 02 November 2010 07:37 Go to previous messageGo to next message
You're welcome Remi,
Are you part of the developer team ?
I tried to build, but I failed, I am not sure of the reason. I used the PSF file provided here :
http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/trunk/org.eclipse.papyrus.releng/psf/Papyrus-ALL-pserver .psf
But I get multiple errors about directory/files which could not be found (43 total).
Also about ANTLR. The wiki says it should downloaded here :
http://download.eclipse.org/tools/orbit/downloads/drops/S201 00120144102/bundles/org.antlr.runtime_3.0.0.v200803061811.ja r
But the page says "Not found" and the fallback link turns itself into a "page not found".
GMF was already installed. JAutodoc, Subversive and CheckStyle could be installed properly, so I am just lacking ANTLR.
Is ANTLR required to build ? I will try again to import the Papyrus-ALL-pserver.psf set.
Re: "Repository moved permanently ..." [message #637895 is a reply to message #636662] Tue, 09 November 2010 04:46 Go to previous messageGo to next message
Hi Yannick,
yes, I am one of the commiters on the project. Papyrus.
The project set was not updated these last weeks. It was previously generated during the nightly build of the tool. Unfortunately, the build framework evolved recently, and we have lost this functionnality.
I am working on this again. I will propose a psf in the next days, manually done. I hope to be able to reintegrate the generation of the PSF from the build.
Rémi
Re: "Repository moved permanently ..." [message #637901 is a reply to message #637895] Tue, 09 November 2010 04:56 Go to previous messageGo to next message
For ANTLR, you can find it there:
http://www.eclipse.org/downloads/download.php?r=1&file=/ tools/orbit/downloads/drops/R20100519200754/bundles/org.antl r.runtime_3.0.0.v200803061811.jar
Rémi
Re: "Repository moved permanently ..." [message #639765 is a reply to message #637895] Wed, 17 November 2010 12:19 Go to previous message
Hi Yannick,
The psf files have been updated and are now available, as described in this topic
Rémi
Previous Topic:[Info] PSF Files for Papyrus plugins
Next Topic:rename a papyrus model
Current Time: Fri Sep 26 12:52:27 EDT 2025
Powered by FUDForum. Page generated in 0.03718 seconds
