Home » Modeling » Modeling (top-level project) » Interrogating ecore model and programmatically generating model instances
Interrogating ecore model and programmatically generating model instances [message #636118] Fri, 29 October 2010 07:43 Go to next message
Very high level question:
I am using an app which generates ecore models (maybe I should be calling
them model instances?).
I modify the model using a UI (drag and drop, adding properties).
Now I want to programmatically produce models that conform to the models
that are produced by the GUI.
How do I get started?
I imagine the steps would be:
**interrogate the GUI generated models to figure out the schema
*map this schema into some sort of Java based model.
*produce models using Java
*export the Java model into a model that conforms to the schema found in
step **
Am I at all on the right path?
Thanks for any help
Re: Interrogating ecore model and programmatically generating model instances [message #636128 is a reply to message #636118] Fri, 29 October 2010 08:22 Go to previous messageGo to next message
Comments below.
> calling them model instances?).
> models that are produced by the GUI.
> in step **
It's all starting to hurt my brain. Maybe reading this will help:
http://www.ibm.com/developerworks/library/os-eclipse-dynamic emf/
> Thanks for any help
Re: Interrogating ecore model and programmatically generating model instances [message #636130 is a reply to message #636128] Fri, 29 October 2010 08:35 Go to previous messageGo to next message
Thats great. Thanks Ed, I really didnt want to make your head hurt :)
It sort of misses the step of interrogating the model though. I am guessing
the company who owns the model (IBM) would not want to make it public, and
as such I have no way of getting my hands on the entire ecore model
namespace without interrogating existing model instances.
Any ideas?
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:iaee3h$8nn$2@news.eclipse.org...
> Comments below.
>> step **
>> Thanks for any help
Re: Interrogating ecore model and programmatically generating model instances [message #636146 is a reply to message #636130] Fri, 29 October 2010 09:14 Go to previous messageGo to next message
Comments below.
You figure out what kind of object is in the resource and then you use
it's API to "interrogate" it.
> I am guessing the company who owns the model (IBM)
IBM doesn't own any of these models. It's open source.
> would not want to make it public, and as such I have no way of getting
> my hands on the entire ecore model namespace without interrogating
Again, I haven't a clue what you're driving at. It's open source, all
the APIs are public, there are entire books describing what you can do...
> Any ideas?
I'm not sure I understand what's holding you up.
>> Comments below.
>>> found in step **
>>> Thanks for any help
Re: Interrogating ecore model and programmatically generating model instances [message #636725 is a reply to message #636146] Tue, 02 November 2010 11:12 Go to previous messageGo to next message
Ok I think I have the wrong terminology here.
By model I mean the ECore "meta"-model, the abstract model that describes
the rules a particular model instance must follow.
An analogy would be an XML schema, and an XML document which is written
according to the schema.
Keeping on with the analogy, I have an XML document which follows a
particular schema. Now I want to find out what the schema is (reverse
engineer it). Is there any way to work out the an ECore model from instances
of it?
Greg
news:iaeh5i$esd$1@news.eclipse.org...
> Comments below.
>> would not want to make it public, and as such I have no way of getting my
>> hands on the entire ecore model namespace without interrogating existing
>> model instances.
> Again, I haven't a clue what you're driving at. It's open source, all the
>> Any ideas?
>>> Comments below.
>>>> in step **
>>>> Thanks for any help
Generating metamodel from models [Was: Interrogating ecore model and programmatically generating mod [message #636739 is a reply to message #636725] Tue, 02 November 2010 11:58 Go to previous messageGo to next message
> describes the rules a particular model instance must follow.
> instances of it?
> Thanks
> Greg
Discovering the metamodel which corresponds to a set of given models
(which then will conform to this metamodel) is an interesting question
(but still open from what I know).
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: Interrogating ecore model and programmatically generating model instances [message #636749 is a reply to message #636118] Tue, 02 November 2010 12:26 Go to previous messageGo to next message
I don't think this is that hard though you may end with an unprecise meta-model (cardinalities especially).
But how would you read the models then ? In XML ?
Re: Interrogating ecore model and programmatically generating model instances [message #636763 is a reply to message #636749] Tue, 02 November 2010 12:46 Go to previous messageGo to next message
Yep, read the "template" models in as XML, then ideally I would generate
typed Java classes representing the model from there somehow.
"Sylvain EVEILLARD" <s.eveillard@netfective.com> wrote in message
news:iapdt8$jeg$1@news.eclipse.org...
Re: Interrogating ecore model and programmatically generating model instances [message #636764 is a reply to message #636118] Tue, 02 November 2010 13:14 Go to previous message
Wouldn't it be easier to directly build the ecore meta-model ?
That's what I would do.
Previous Topic:Text to Model Transformation
Next Topic:Ada 95 or 2005 metamodel resource (ecore)
Current Time: Mon Sep 22 01:51:29 EDT 2025
Powered by FUDForum. Page generated in 0.04374 seconds
