Home » Archived » BIRT » How to create powerpoint and excel exports?
How to create powerpoint and excel exports? [message #635880] |
Thu, 28 October 2010 13:19 |
Originally posted by: vm.vm.com
I am trying to export my reports to excel (.xls) and powerpoint (.ppt).
Currently I do:
try {
EngineConfig reportConfig = new EngineConfig();
reportConfig.setEngineHome(engineDir);
reportConfig.setLogConfig(null, Level.FINE);
Platform.startup(reportConfig);
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_E NGINE_FACTORY);
reportEngine = factory.createReportEngine(reportConfig);
reportEngine.changeLogLevel(Level.WARNING);
IReportRunnable design = reportEngine
.openReportDesign(reportDesignHandle);
task = reportEngine.createRunAndRenderTask(design);
} catch (BirtException e) {
throw new Exception("Report exporter could not be initialized!",
e);
RenderOption renderOption = null;
if (ext.equalsIgnoreCase(OUTPUT_FORMAT_PDF)) {
renderOption = new PDFRenderOption();
renderOption.setOption("htmlPagination", true);
((PDFRenderOption) renderOption).setEmbededFont(true);
} else if (ext.equalsIgnoreCase(OUTPUT_FORMAT_HTML)) {
renderOption = new HTMLRenderOption();
} else if (ext.equalsIgnoreCase(OUTPUT_FORMAT_XLS)) {
renderOption = new EXCELRenderOption();
} else if (ext.equalsIgnoreCase(OUTPUT_FORMAT_PPT)) {
} else if (ext.equalsIgnoreCase(OUTPUT_FORMAT_DOC)) {
} else if (ext.equalsIgnoreCase(OUTPUT_FORMAT_PS)) {
renderOption.setSupportedImageFormats("PNG;GIF;JPG;BMP;SWF;SVG ");
renderOption.setBaseURL("");
renderOption.setOutputFormat(ext);
renderOption.setOutputFileName(documentPath);
task.setRenderOption(renderOption);
try {
task.run();
} catch (EngineException e) {
throw new Exception("Export task could not be completed!", e);
task.close();
But when I export a powerpoint report is just blank. How do I setup my
render to create powerpoints reports?
I have downloaded tribix :
http://qauck.blogspot.com/2010/01/tribix-251-released.html
and added it to my project. But I cannot find any documentation on how to
use it in my code to create powerpoint and excel reports. Anyone know if
there exists any documentation on how to create excel and powerpoint reports
using tribix?
Re: How to create powerpoint and excel exports? [message #635912 is a reply to message #635880] |
Thu, 28 October 2010 14:55 |
If you download both the Tribix xls and ppt emitters you need to remove
the current BIRT emitters for those formats. Then just use a standard
RenderOption instance and set the output format to xls or ppt.
Jason
> Currently I do:
> try {
> e);
> try {
> task.run();
> task.close();
> to use it in my code to create powerpoint and excel reports. Anyone know
> if there exists any documentation on how to create excel and powerpoint
> reports using tribix?
Re: How to create powerpoint and excel exports? [message #635929 is a reply to message #635912] |
Thu, 28 October 2010 15:21 |
Ok so I should replace the files:
org.eclipse.birt.report.engine.emitter.ppt_2.6.1.v20100909.j ar
org.eclipse.birt.report.engine.emitter.excel.config_2.6.1.v2 0100812.jar
in the:
C:\birt-runtime-2_6_1\ReportEngine\plugins
with the :
org.uguess.birt.report.engine.emitter.xls_2.5.1.201001221050 .jar
(could only find a Tribix emitter for xls)
Do you have an example of a "standard" .ppt export example?
I was wondering why the build-in (native birt .ppt) does not work. Is it
only through Tribix its possible to make .ppt reports (assuming that there
is a tribrix .ppt emitter)?
"Jason Weathersby" wrote in message news:iac2ms$mir$1@news.eclipse.org...
Jason
> Currently I do:
> try {
> e);
> try {
> task.run();
> task.close();
Re: How to create powerpoint and excel exports? [message #635931 is a reply to message #635929] |
Thu, 28 October 2010 15:40 |
You need to remove these four plugins:
org.eclipse.birt.report.engine.emitter.prototype.excel_2.6.1 .v20100812
org.eclipse.birt.report.engine.emitter.ppt.config_2.6.1.v201 00812
The Tribix ppt emitter is on this page:
http://sourceforge.net/projects/tribix/files/
If you want to use the standard ppt emitter it should work with:
RenderOption options = new RenderOption();
options.setOutputFormat("ppt");
options.setOutputFileName("output/resample/customers.ppt");
task.setRenderOption(options);
Jason
> in the:
> with the :
> there is a tribrix .ppt emitter)?
> Jason
>> Currently I do:
>> try {
>> e);
>> try {
>> task.run();
>> task.close();
Re: How to create powerpoint and excel exports? [message #635978 is a reply to message #635931] |
Thu, 28 October 2010 19:44 |
Thanks for the suggestions! Regarding the standard (NOT using the Tribix
emitters) .ppt exporter I have now tried:
options.setOutputFileName(c:\\test\\myout.ppt);
task.run();
but when I open the file myout.ppt in microsoft power point 2010 nothing
shows. Does the birt 2.6.1 api not support microsoft powerpoint 2010?
"Jason Weathersby" wrote in message news:iac5as$q84$1@news.eclipse.org...
Jason
> in the:
> with the :
> Jason
>> Currently I do:
>> try {
>> e);
>> try {
>> task.run();
>> task.close();
Re: How to create powerpoint and excel exports? [message #635982 is a reply to message #635978] |
Thu, 28 October 2010 19:52 |
I do not have 2010 but I know it opens in 2007. Can you open a bug?
Jason
> task.run();
> Jason
>> in the:
>> with the :
>> Jason
>>> Currently I do:
>>> try {
>>> e);
>>> try {
>>> task.run();
>>> task.close();
Current Time: Thu Sep 26 14:28:51 GMT 2024
Powered by FUDForum. Page generated in 0.05110 seconds
