Re: Export report as csv (unicode) [message #635871 is a reply to message #635861] |
Thu, 28 October 2010 12:50 |
Originally posted by: thilo.bruesshaber.gmail.com
Excel
Am 28.10.2010 13:52, schrieb Luboslav:
> Hello,
> I use birt-runtime-2_3_2,I export data with CSVRenderOption to csv
> file,but the unicode characters like 'Ü' are becomes "Ãœ".It is problem
> from CSVRenderOption,parsing or exel,any idea?
> Regards,
> Lubo
Re: Export report as csv (unicode) [message #635873 is a reply to message #635871] |
Thu, 28 October 2010 13:05 |
Luboslav Messages: 4 Registered: October 2010 |
Are you sure?Exel,but how to fix that problem?It is depents on version or plugin?Here is my code for export :
public void executeReportCsvDataExtraction(String strReportsDirectory,String strReportName,String strParameters) throws Exception
try
Log4J.infoout(String.valueOf(m_objReportEngine));
IReportRunnable design = m_objReportEngine.openReportDesign(strReportsDirectory+File. separator+strReportName+ ".rptdesign");
IGetParameterDefinitionTask paramtask = m_objReportEngine.createGetParameterDefinitionTask( design );
Collection clParameters = paramtask.getParameterDefns( true );
ReportDesignHandle designHandle = (ReportDesignHandle) design.getDesignHandle( );
ElementFactory designFactory = designHandle.getElementFactory( );
buildDataSource(designFactory, designHandle);
designHandle.close();
//Create task to run and render the report,
IRunAndRenderTask task = m_objReportEngine.createRunAndRenderTask(design);
Hashtable htParameters=new Hashtable();
StringTokenizer objParametersTokenizer=new StringTokenizer(strParameters,"&");
String strParameter;
int iIndex;
for(;objParametersTokenizer.hasMoreTokens()
strParameter=objParametersTokenizer.nextToken();
iIndex=strParameter.indexOf('=');
if (iIndex>-1)
htParameters.put(strParameter.substring(0,iIndex),
strParameter.substring(iIndex+1));
Iterator iter = clParameters.iterator();
IParameterDefnBase param;
IScalarParameterDefn scalar;
String strParameterValue;
while ( iter.hasNext( ) )
param = (IParameterDefnBase) iter.next( );
if ( param instanceof IScalarParameterDefn )
scalar = (IScalarParameterDefn) param;
strParameterValue=String.valueOf(htParameters.get(scalar.get Name()));
switch (scalar.getDataType())
case IScalarParameterDefn.TYPE_INTEGER:
case IScalarParameterDefn.TYPE_DECIMAL:
task.setParameterValue(scalar.getName(),Integer.parseInt(str ParameterValue));
break;
default:
String a=(String) htParameters.get(scalar.getName());
task.setParameterValue(scalar.getName(),a);
break;
task.validateParameters();
CSVRenderOption csvOptions = new CSVRenderOption();
csvOptions.setOutputFormat( "CSV" );
csvOptions.setOutputFileName("c:/csvReport.csv");
task.setRenderOption( csvOptions );
task.run();
task.close();
catch( Exception ex)
ex.printStackTrace();
throw ex;
[Updated on: Thu, 28 October 2010 13:17] Report message to a moderator
Re: Export report as csv (unicode) [message #638539 is a reply to message #638422] |
Thu, 11 November 2010 15:13 |
Can you post your code?
Jason
On 11/11/2010 4:36 AM, Luboslav wrote:
> You can see my code,i don`t make any changes with locale,but which
> locale?csvOptions.LOCALE?How to set this locale or maybe you talk about
> computer settings?
FUDForum. Page generated in 0.03338 seconds
