Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Acceleo as standalone(How to run Acceleo as a standalone Java application)
[Acceleo] Acceleo as standalone [message #635753] |
Thu, 28 October 2010 01:10 |
Yannick Duchene (Hibou57) Messages: 50 Registered: September 2010 Location: Metz (France - Europe) |
Member |
Hi happy designers,
I would like try to test something with which I would need Acceleo to be used as a standalone Java application : would give it two arguments, target directory and M2T source file, launch from command line (this is what I would like to get).
I had a look at the doc, but there was just really few things about this topic in Acceleo's doc.
It says nothing about what Java compiled files I have to copy outside of Eclipse, and I failed with a test.
This test, which suggested by the doc, is to run a transformation from Eclipse, and to run it as a Java application instead of as a plug-in.
When I do so, I have a message box with a progress bar, which reach the end, but then does not close, what ever the time I wait (even multiple minutes). I have to manually close the Eclipse process, otherwise, the whole Eclipse does not respond any more.
As this test fails, does that means I cannot use Acceleo standalone ?
Surprisingly, the process seems to complete in some way, as files in the target folder appears to be really generated ; this is just that it does not close at the end.
Here is the state of my attempts.
Any hint or tip, or links to doc, to use Acceleo as a Java standalone application, welcome.
Re: [Acceleo] Acceleo as standalone [message #636309 is a reply to message #635764] |
Sat, 30 October 2010 16:44 |
--------------050306020704040705030601
Hi Yannick,
Acceleo works in a standalone environment for sure, since it has been
designed with this use case in mind. The Java classes you are to launch
are the files automatically generated besides your "mtl" modules (those
which are annotated with the "@main" comment).
However as Simon mentionned, if we did have standalone generation in
mind while designing Acceleo, we did not expect that there would also be
such a need for standalone compilation, and you'll have to take a look
at his advice as we haven't made progress in this field since then.
As for the documentation, looking at your comment I do believe we'll
have to update it with a dedicated "standalone" section :).
Laurent Goubet
Obeo
Yannick Duchene (Hibou57) wrote:
> Thanks for the link Simon, will have a look at all of this
> (gonna not be a piece of cake for me who just know all that Eclipse and
> Java stuffs too few... still can be done, I believe)
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------050306020704040705030601--
Re: [Acceleo] Acceleo as standalone [message #636319 is a reply to message #636309] |
Sat, 30 October 2010 20:39 |
Member |
Hi once again Mr Laurent,
Laurent Goubet wrote on Sat, 30 October 2010 12:44 | However as Simon mentionned, if we did have standalone generation in
Yes, "standalone" and "portable" is a famous requirement nowadays (and to talk about Java applications, there exist some very lightweight JVM now) .
Just let me explain why I was thinking about it, so it does not look like an unjustified or silly expectation : I though about it because a process may rely on an external compiler and an external UML editor (I am balancing TopCased and ArgoUML, while ArgoUML does not work fine in Eclipse), so that most of the process is done outside of Eclipse. That was why I though about running Acceleo outside of Eclipse if possible.
Laurent Goubet wrote on Sat, 30 October 2010 12:44 | As for the documentation, looking at your comment I do believe we'll
have to update it with a dedicated "standalone" section .
I guess you have many pending job, so please, don't bother too much (except if someone with a commercial support request the same).
Re: [Acceleo] Acceleo as standalone [message #636321 is a reply to message #636309] |
Sat, 30 October 2010 20:49 |
Simon harrer Messages: 25 Registered: August 2010 |
Hi Laurent,
I think, the use case of standalone compilation is an important one.
Most companies use the Hudson Buildserver to build their products. For this occasion, the standalone-compilation is neccessary to build the fully functional product, execute test cases, etc.
It would be great, if some documentation would be provided. Maybe, with an example how to call the compiler. Is it possible to provide something myself? I do not know how the contribution guidelines are for the Acceleo Project.
And currently, the presented AcceleoCompiler Class only puts its output in the source directory. It is currently not possible to specify a target directory. This contradicts to the normal java compilation mechanism, as it compiles from src to bin. Something like this would also be preferred, I think.
Also, at default, the mtl files are copied to the bin directory. By adding Acceleo to the project, this could automatically be excluded.
The last two aspects just came into mind.
Simon
Re: [Acceleo] Acceleo as standalone [message #636334 is a reply to message #636319] |
Sun, 31 October 2010 01:03 |
Member |
Yannick Duchene (Hibou57) wrote on Sat, 30 October 2010 16:39 | Just let me explain why I was thinking about it, so it does not look like an unjustified or silly expectation : I though about it because a process may rely on an external compiler and an external UML editor (I am balancing TopCased and ArgoUML, while ArgoUML does not work fine in Eclipse), so that most of the process is done outside of Eclipse. That was why I though about running Acceleo outside of Eclipse if possible.
I'm pretty sure now. After some tests, pretty sure ArgoUML is the UML editor to recommend. Papyrus let you draw erroneous diagrams (you have to manually validate all the time with another tool), has trouble with XMI imports. TopCased is a validating editor, but suffers from too much "pointer error" and also have real troubles with XMI imports. The only one which does not crash while running, validates during edition, and imports XMI without a trouble, is ArgoUML. As said before, as it has failure with its Eclipse variant (ArgoEclipse), and works fine outside of Eclipse, then no more reasons to use Eclipse, except for Acceleo.
TBH: ArgoUML only have experimental support for UML2, and cannot draw state diagrams (which I need) in UML mode. But it seems the more promising of all the ones I tried.
This was my off-topic about what is the most recommended validating UML editor
Have a nice time all.
Re: [Acceleo] Acceleo as standalone [message #636354 is a reply to message #636334] |
Sun, 31 October 2010 10:31 |
--------------060706080407040409030000
Hi Yannick,
Comparison between UML modelers seem to be a reccurent topic :). It's a
wonder no studies are yet out on this ^^.
Laurent Goubet
Obeo
> editor :p
--------------060706080407040409030000--
Re: [Acceleo] Acceleo as standalone [message #642025 is a reply to message #636354] |
Mon, 29 November 2010 15:33 |
Thomas Neustupny Messages: 75 Registered: October 2009 |
Member |
Hi Laurent!
Laurent Goubet wrote on Sun, 31 October 2010 06:31 | Comparison between UML modelers seem to be a reccurent topic . It's a
At the same time it seems to be a dead topic for years: since UML2 the "old" market leaders lost their positions and a new set of players offer quite nice (non-free) tools. Regarding free tools: there are way too few volunteering developers to have mature feature-complete tools, and that is true both in the eclipse community as well as for standalone tools.
[Updated on: Mon, 29 November 2010 15:34] Report message to a moderator
Current Time: Fri Apr 26 17:58:13 GMT 2024
Powered by FUDForum. Page generated in 0.04383 seconds
