Home » Eclipse Projects » Eclipse Platform » .eclipse folder issues
Re: .eclipse folder issues [message #635605 is a reply to message #635580] |
Wed, 27 October 2010 13:13 |
Matthew Dickie Messages: 56 Registered: July 2009 |
Member |
Hi Paul,
Yes, I see Eclipse uses multi-user mode when the installation folder is
read only. We have never thought about 'do we want a multi-user install
or not?', but on Windows we do install to a subdir of c:\Program Files\
by default, so based on that help article you posted a link to, on
Windows Vista/7 this would make the install a multi-user install by default.
The problem we have had is that when our NSIS based installer is used to
install a new version of our Eclipse-based IDE over the top of an old
one, occasionally the new behaviour is not observed (e.g. bug fixes,
changes to dialogs, etc). Deleting the .eclipse folder fixes this. It
seems as if somehow java class files have been cached here. A fix would
be for the installer to delete this folder, but this isn't really
pratical as there can be many users, and I don't really know what
information might be stored here and how important it may be.
So I suppose the question is, does java bytecode from the plugins get
cached here, and if so why? It forces us to ask our users to remove
their .eclipse folder when various strange problems occur.
Thanks in advance,
Matt D.
On 27/10/2010 13:17, Paul Webster wrote:
> When installed in multi-user mode, eclipse uses the $HOME/.eclipse
> folder for user specific configurations (since they can't write into the
> eclipse/configuration folder).
> http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/misc/multi_user_installs.html
> If they install a plugin, it will be managed in that folder. If you
> upgrade or install something in the main install, I thought it was
> supposed to be available to the users the next time they started up.
> If that's not the case, I would open a bug at
> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Equinox& amp;component=p2
> and post the number here.
> If I have your usecase wrong, please provide some more details.
> PW
Re: .eclipse folder issues [message #635606 is a reply to message #635605] |
Wed, 27 October 2010 13:39 |
Matthew Dickie wrote:
> Hi Paul,
> default.
well, yes, but as per that link to make it a proper multi-user install
the admin that installs it needs to run an -initialize command line on
it. That does the correct, complete setup.
> one,
Installing one eclipse on top of another won't work correctly. i.e.
it's pretty well guaranteed to fail, and I'm surprised it ever works for
anyone at all :-)
In the case you've found, does running eclipse as the user with -clean
fix the problem?
If the user has installed an extra plugin, it will be in their own
..eclipse folder. Deleting it would wipe out information for any of the
eclipse installs they are using.
This is most likely a symptom of installing over an old install.
Upgrading the install, or removing it and installing the new version,
would both be better options.
Or installing in versioned directories, and allowing the users to move
to the latest version. ex:
C:\Program Files\eclipse-3.5.1\
C:\Program Files\eclipse-3.6.0\
C:\Program Files\eclipse-3.6.1\
etc.
The eclipse p2 system is good at both creating a new install and
upgrading an existing one. It's what I use:
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/p2_director.html
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Paul Webster
Re: .eclipse folder issues [message #635653 is a reply to message #635606] |
Wed, 27 October 2010 14:59 |
Member |
Hi Paul
On 27/10/2010 14:39, Paul Webster wrote:
>> Hi Paul,
Hmm. That link doesn't make that clear. It seems to suggest that this
allows you to create this configuration area early. I think we will not
bother doing this. Anyway, this is a side issue.
> fix the problem?
Yes, that fixes it as well, and is the best way to fix it. I had
forgotten about this, as we didn't initially discover it.
Yes, so we should use -clean. But that doesn't answer my initial question:
We haven't actually had this problem for a while, and I can't remember
if it still occurs after uninstalling the old IDE and installing the new
version. My colleage, however, insists that this is the case, and
removing the .eclipse folder (or better using -clean) is required to fix
this. I
Yes, I could allow users to update the IDE that way. However our IDE is
installed as part of a wider package, including compilers and runtime
libraries for our language as well as other tools, so the initial
problem remains.
When this issue next occurs, I will look into it more thoroughly, but in
the mean time I would be very grateful if you could answer my initial
question: does Eclipse cache plugins or parts of plugins (not extra
plugins, but installed plugins in the original install location within
the Program Files dir)? If so why, and how can we deal with it when the
user installs a new version (we can't run the IDE with the -clean for
every user on install)
Thanks for your help,
Matt D.
Re: .eclipse folder issues [message #635654 is a reply to message #635653] |
Wed, 27 October 2010 15:48 |
> Hi Paul
If you don't run it, then the main install config area is not configured
properly to be used in multi-user mode. That can cause interference
between your main install configuration and any configuration stored in
the users .eclipse folder.
As for installing over an old eclipse, we don't just recommend against
it but say "never do that". Once you do that, your install will be
broken. You've been lucky that your stuff has run at all (in most cases
it won't) and only caused some upgrade hiccups.
It doesn't cache code there, but it does store other information. In
eclipse/configuration: Certain files that were requested "extracted"
from their plugins, like files or directories. The extension registry
cache (that's what -clean causes to be re-read, and is not a problem
when updated via p2 as p2 cleans the cache). bundles.info, which is a
pointer to specific plugins and their run levels. Other configuration
level (as opposed to workspace level) information (things like network
proxies, for example).
There's also the eclipse/p2 directory at the install level, which
contains pointers to bundles and other install/configuration type
metadata that is generated for a particular install.
PW
Paul Webster
Paul Webster
Current Time: Sat Apr 27 04:33:03 GMT 2024
Powered by FUDForum. Page generated in 0.03974 seconds
