Re: Default Dynamic Parameter [message #635164 is a reply to message #635155] |
Mon, 25 October 2010 19:54 |
If you're showing the listbox interactively and have an order by clause on the query, the first item in the list will be presented.
If you want to actually have that as the default value (preselected) then you will need to iterate over the dropdown values in the parameter value event script. I've seen references to that somewhere, that was added in 2.5.
Re: Default Dynamic Parameter [message #635177 is a reply to message #635155] |
Mon, 25 October 2010 21:00 |
Sorry, I missed that this was a listbox and not a combo box. You need to run iteratively through the values and set the one you want. I just won't have time to find where I think I did that for a week. Hopefully someone else has done this.
Re: Default Dynamic Parameter [message #635380 is a reply to message #635177] |
Tue, 26 October 2010 14:57 |
If you do not set a default value and are using the viewer, the first
item returned should be preselected automatically in the parameter entry
box.
Jason
Re: Default Dynamic Parameter [message #637258 is a reply to message #637220] |
Thu, 04 November 2010 17:19 |
An example of the getdefaultvaluelist script would look something like:
var dVLArray = [];
dVLArray[0]= "10104";
dVLArray[1] = "10108";
dVLArray;
This is for multi-select list box.
Jason
On 11/4/2010 12:06 PM, Bernie Durfee wrote:
> It looks like I can maybe do what I want using 'getdefaultvaluelist',
> but I can't find any examples. The values in the combo-box come from a
> data set, that returns a list of academic terms...
> TERM_CODE
> TERM_DESC
> TERM_START
> TERM_END
> ...the terms in the list include some past and some future terms. I want
> the current term selected by default. So in pseudo-code I figure I
> should be able to...
> Create array with default values
> Iterate through the values in the dataset to find the term code where
> today's date is between the term start and end dates
> Add the term code to the array so it becomes the default value
> ...I just don't know what's available within the context of the
> 'getdefaultvaluelist' call. Anyone want to get me started here?
Re: Default Dynamic Parameter [message #637455 is a reply to message #637274] |
Fri, 05 November 2010 15:02 |
Bernie,
We are looking at ways to improve this script because currently you have
very little access to current dataset. Two ways around this is to call
a custom java class to return the default list of values or call the
BIRT data engine. I am attaching an example that calls the birt data
engine to run a dataset that sets the default values.
What the script does is preselect all values in the list.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.6.1.v20100902 Build <2.6.1.v20100915-1750></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">auto layout</property>
<property name="bidiLayoutOrientation">ltr</property>
<parameters>
<scalar-parameter name="ListParameter3" id="21">
<property name="valueType">dynamic</property>
<property name="dataSetName">tiedtolist3</property>
<expression name="valueExpr"
type="javascript">dataSetRow["ORDERNUMBER"]</expression >
<expression
name="sortByColumn">dataSetRow["ORDERNUMBER"]</expression >
<property name="sortDirection">asc</property>
<property name="dataType">integer</property>
<property name="distinct">true</property>
<property name="paramType">multi-value</property>
<property name="controlType">list-box</property>
<property name="mustMatch">true</property>
<property name="fixedOrder">false</property>
<method name="getDefaultValueList"><![CDATA[try{
rsArr= [];
importPackage(Packages.java.lang);
importPackage(Packages.java.util);
importPackage(Packages.org.eclipse.birt.data.engine.api);
importPackage(Packages.org.eclipse.birt.report.model.api);
importPackage(Packages.org.eclipse.birt.data.engine.api.quer ydefn);
importPackage(Packages.org.eclipse.birt.data.engine.core);
var myconfig =
reportContext.getReportRunnable().getReportEngine().getConfi g();
var de = DataEngine.newDataEngine( myconfig, null );
var dsrc = reportContext.getDesignHandle().findDataSource("Data Source");
var dset = reportContext.getDesignHandle().findDataSet("tiedtolist3");
var odaDataSource = new OdaDataSourceDesign( "Test Data Source" );
odaDataSource.setExtensionID( "org.eclipse.birt.report.data.oda.jdbc" );
odaDataSource.addPublicProperty( "odaURL",
dsrc.getProperty("odaURL").toString() );
odaDataSource.addPublicProperty( "odaDriverClass",
dsrc.getProperty("odaDriverClass").toString());
odaDataSource.addPublicProperty( "odaUser",
dsrc.getProperty("odaUser").toString() );
odaDataSource.addPublicProperty( "odaPassword", "" );
var odaDataSet = new OdaDataSetDesign( "Test Data Set" );
odaDataSet.setDataSource( odaDataSource.getName( ) );
odaDataSet.setExtensionID(
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
odaDataSet.setQueryText( dset.getQueryText() );
de.defineDataSource( odaDataSource );
de.defineDataSet( odaDataSet );
queryDefinition = new QueryDefinition( );
queryDefinition.setDataSetName( odaDataSet.getName() );
queryDefinition.setAutoBinding(true);
var pq = de.prepare( queryDefinition );
var qr = pq.execute( null );
var ri = qr.getResultIterator( );
var cc = ri.getResultMetaData().getColumnCount();
var rsmd = ri.getResultMetaData();
var jj = 0;
while ( ri.next( ) )
rsArr[jj] = ri.getValue(rsmd.getColumnName(1)).toString();
jj++;
ri.close( );
qr.close( );
de.shutdown( );
}catch(e){
rsArr;]]></method>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<list-property name="privateDriverProperties">
<ex-property>
<name>contentBidiFormatStr</name>
<value>ILYNN</value>
</ex-property>
<ex-property>
<name>metadataBidiFormatStr</name>
</ex-property>
</list-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="tiedtolist3" id="22">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
</report>
On 11/4/2010 3:22 PM, Bernie Durfee wrote:
> I've been digging through the API's, I don't quite have a clear picture
> as to how they link together. A couple questions...
> 1) Where is getDefaultValueList defined in the API?
> 2) Is it possible to access rows of a data set from within
> getDefaultValueList?
FUDForum. Page generated in 0.04172 seconds
