Re: Possible bug retrieving single Boolean column [message #635329 is a reply to message #635151] |
Tue, 26 October 2010 12:59 |
Chris Delahunt Messages: 1389 Registered: July 2009 |
Hello Brendan,
Feel free to file one, but I'm not sure you should be using getSingleResult() as it cannot distinguish between a null value and no values being returned. Try using getResultLitst(), but you will still get null values in the collection.
The problem is that you are defaulting the testBoolean value to false. Check the value in the database, but I believe that when you are persisting a value of false nothing is being sent to the database because nothing has changed. So the database column remains null. Try leaving the testBoolean uninitialized in the default constructor, and instead set it in other constructors and/or application code. This will cause EclipseLink to see that it has been set and persist a value to the database.
Best Regards,
Chris
[Updated on: Tue, 26 October 2010 13:00] Report message to a moderator
FUDForum. Page generated in 0.03619 seconds
