Home » Modeling » EMF » Importing an XMI file
Re: Importing an XMI file [message #634898 is a reply to message #634893] |
Mon, 25 October 2010 01:06 |
Ed Merks Messages: 33141 Registered: July 2009 |
Kissaki,
Comments below.
Kissaki wrote:
> hey,
> I'm trying to use EMF / ECore to parse an XMI file to use it
> programmaticaly.
> Can anyone help me with that?
Did you read the introductory overview? Do you have an Ecore model
generated for the type of XMI you're trying to process.
> Currently I'm trying with XMILoadImpl.load
> Would this be the correct / best way?
No.
> Currently I get "Package with uri 'null' not found."
What does the XMI look like?
> What I don't get is what those load method params are for ... Shall
> Resource as well as input source point to my XMI file; both?
> The javadoc doesn't really tell me ...
I'd suggest generating a model, invoking Generate Test Code, and look at
the XyzExample.java.
> What does the error indicate? Is it a problem with the xmlresource or
> inputsource?
> Or is it parsing the file itself while everything else seemed ok?
It's hard to comment if you don't show the file. But it sounds like you
have an unqualified root element in your XML.
> My current test-code follows:
> String filePath = dir + File.separator + "xmi_ex4.xmi";
> URI filePathURI = URI.createFileURI(filePath);
> XMLHelper h = new XMIHelperImpl();
> XMLLoad loader = new XMILoadImpl(h);
Why would you create these direction.
> //logger.info("loader: {}", loader);
> XMIResource resXMI = new XMIResourceImpl(filePathURI);
> //XMLResource res = new XMLResourceImpl(filePathURI);
> try {
> File xmiFile = new File(filePath);
> FileReader xFR = new FileReader(xmiFile);
> InputSource xmiIS = new InputSource(xFR);
> loader.load(resXMI, xmiIS, new java.util.HashMap());
You'd use a resource to load the contents. Best to read the
introductory overview.
> } catch (FileNotFoundException e) {
> logger.error("File Not Found exception thrown when loading
> XMI: {}", e.getMessage());
> e.printStackTrace();
> } catch (IOException e) {
> logger.error("IO exception thrown when loading XMI: {}",
> e.getMessage());
Ed Merks
Re: Importing an XMI file [message #635198 is a reply to message #635048] |
Mon, 25 October 2010 23:25 |
Kissaki Messages: 6 Registered: October 2010 |
I tried to load the XMI file with UML2, but failed again.
I get the old error.
So could you / someone point out to me what I'm doing wrong?
The UML2 wiki only has info on using it as an eclipse plugin, but not on using it programmaticaly as libs.
As can be seen in the code, I'm using UMLImporter, which I found via javadoc.
UMLImporter i = new UMLImporter();
ResourceSet resS = i.createResourceSet();
Resource resource = resS.getResource(filePathURI, true);
Object object = resource.getContents().get(0);
logger.info("MA OBJECT: {}", object);
As that wasn't enough I added factoryMap data:
resS.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl() {
public Resource createResource(URI uri)
XMIResource xmiResource = new XMIResourceImpl(uri);
return xmiResource;
But I get the old
Quote: | Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'null' not found. (file:/G:/.../xmi_ex4.xmi, 3, 16)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
Re: Importing an XMI file [message #635211 is a reply to message #635198] |
Tue, 26 October 2010 01:12 |
Kissaki,
Comments below.
> javadoc.
The importer isn't what you use to read UML instances.
> resS.getResourceFactoryRegistry().getExtensionToFactoryMap() .put( "xmi",
> return xmiResource;
Ask about UML2 on their newsgroup. You'll need to use the UML2Resource...
> But I get the old Quote:
Ed Merks
Re: Importing an XMI file [message #635573 is a reply to message #635518] |
Wed, 27 October 2010 10:48 |
--------------020507090408060202030403
Kissaki,
Comments below.
Kissaki wrote:
> Thanks.
> I made it work.
> But having no doc,
There is documentation, but it could certainly be easier to find.
> a lot of dependencies,
The p2 installer finds all the dependencies so pointing at the Helios
repo should be sufficient for your needs.
> no contact info or forum for UML2,
There is a UML2 forum. news://new.eclipse.org/eclipse.modeling.mdt.uml2
> and having to debug the actual structure of the UML2-parsed XMI is
> frustrating.
Debug?
> Thus, I will now parse XML myself.
UML2 is large and complex. Parsing the XMI for it yourself seems like
an exercised in futility. I imagine you could spend the time on more
important things, i.e., manipulating the structure itself.
> My impression on the eclipse websites is that they are confusing and
> the doc bad.
There's lots of room for improvement. But little time or investment to
make it happen.
> It is not first-time user friendly.
No, not so much. But users themselves could improve the wiki. They
just typically never find the time to do that, though many find the time
to complain.
> Thanks for all your guys help.
It's not as if your question hasn't actually been answered a 100 times
on the UML2 newsgroup. There's even a FAQ on their home page:
http://wiki.eclipse.org/index.php/MDT-UML2-FAQ#What.27s_requ ired_to_load_a_UML_.28.uml.29_resource_from_a_standalone_app lication.3F
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Kissaki,<br>
<br>
Comments below.<br>
<br>
Kissaki wrote:
<blockquote cite="mid:ia8lhu$5tf$1@news.eclipse.org" type="cite">Thanks.
<br>
I made it work.
<br>
<br>
But having no doc,
<br>
</blockquote>
There is documentation, but it could certainly be easier to find.<br>
<blockquote cite="mid:ia8lhu$5tf$1@news.eclipse.org" type="cite">a lot
of dependencies,
<br>
</blockquote>
repo should be sufficient for your needs.<br>
<blockquote cite="mid:ia8lhu$5tf$1@news.eclipse.org" type="cite">no
<br>
</blockquote>
There is a UML2 forum. <a
href="news://new.eclipse.org/eclipse.modeling.mdt.uml2">news://new.eclipse.org/eclipse.modeling.mdt.uml2</a><br>
<blockquote cite="mid:ia8lhu$5tf$1@news.eclipse.org" type="cite">and
frustrating.
<br>
</blockquote>
Debug?<br>
<blockquote cite="mid:ia8lhu$5tf$1@news.eclipse.org" type="cite">Thus,
I will now parse XML myself.</blockquote>
important things, i.e., manipulating the structure itself.<br>
<blockquote cite="mid:ia8lhu$5tf$1@news.eclipse.org" type="cite"><br>
<br>
the doc bad.
<br>
</blockquote>
make it happen.<br>
<blockquote cite="mid:ia8lhu$5tf$1@news.eclipse.org" type="cite">It is
<br>
</blockquote>
time to complain.<br>
<br>
</blockquote>
on the UML2 newsgroup. There's even a FAQ on their home page:<br>
<blockquote><a
href=" http://wiki.eclipse.org/index.php/MDT-UML2-FAQ#What.27s_requ ired_to_load_a_UML_.28.uml.29_resource_from_a_standalone_app lication.3F"> http://wiki.eclipse.org/index.php/MDT-UML2-FAQ#What.27s_requ ired_to_load_a_UML_.28.uml.29_resource_from_a_standalone_app lication.3F</a><br>
</blockquote>
<br>
</body>
</html>
--------------020507090408060202030403--
Ed Merks
Re: Importing an XMI file [message #635639 is a reply to message #635573] |
Wed, 27 October 2010 15:15 |
I'm not familiar with p2 installer.
I am not familiar with the news:// protocol.
>> and having to debug the actual structure of the UML2-parsed XMI is frustrating.
>Debug?
I'm not familiar with what is returned and it just seems to be AnyType lists within each other.
I'm also not familiar with AnyType classes and how I get data out of it, or if I have to instanceof-check all of them and cast them, or whatever.
>UML2 is large and complex. Parsing the XMI for it yourself seems like an exercised in futility. I imagine you could spend the time on more important things, i.e., manipulating the structure itself.
I don't need all of it and neither do I need to validate that it's true and valid XMI or UML2 in XMI format.
As long as I can get the data I need out of it ...
Neither was I familiar with newsgroup (news:// protocol) nor can I log in there. And having that much of a hassle to search for something just to make it work ...
I checked that one, and it didn't really help me much.
[Updated on: Wed, 27 October 2010 15:17] Report message to a moderator
Re: Importing an XMI file [message #635663 is a reply to message #635639] |
Wed, 27 October 2010 16:08 |
Kissaki,
Comments below.
It's quite a standard thing. I guess you're using the web forums, so
eclipse.modeling.mdt.uml2 is the symbolic ID...
>>> frustrating.
>> Debug?
Sounds like it's not working well, not recognizing the namespaces.
Not sure what you need then.
> on the UML2 newsgroup. Neither was I familiar with newsgroup (news://
It doesn't sound like you've read all the much of the introductory EMF
information.
Ed Merks
Current Time: Fri Apr 26 00:00:27 GMT 2024
Powered by FUDForum. Page generated in 0.06039 seconds
