Re: [ETL] Resolve Proxies [message #634130 is a reply to message #634116] |
Wed, 20 October 2010 15:09 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Henning,
Could you please send a minimal configuration that reproduces this to
epsilon.devs at gmail com so that I can have a look?
Dimitris
Henning <Hager.Henning@gmail.com> wrote:
> I'm having probably quite specialized problem. Indeed, it is very
> likely that I'm just using the tools wrong. So here is my setup maybe
> you can give me a hint:
> I'm doing some transformation of model A and B. During the
> transformation I want to store some information about elements from
> model A into model C as references.
> Model A is an XML based model, which ecore meta model has been
> retrieved from its schema. Model B and C are straight forward ecore
> models.
> The setup works fine for storing the information in model C, but my
> problem occurs when I try to access the element references stored in
> model C. I don't get the real reference to the element, but just an
> EObjectImpl, which is an eProxy. The associated URI and the XPointer
> are correct but the proxy is not resolved.
> For testing purposes, I do the store and read of the reference in the
> same transformation so all metamodels are accessible. I also took care
> that the reference (in metamodel C) is set to resolve proxies.
> What do I need to do to get the reference to the element?
> Thanks for your help,
> Henning
FUDForum. Page generated in 0.03847 seconds
