Re: Eclipse Helios + PDT = no validation [message #890248 is a reply to message #884572] |
Thu, 21 June 2012 15:24 |
Wait a minute!
"Semantic Awareness to View / Action Helpers" is related to "Zend Framework Integration".
Scrolling the list under "PHP Editor and File Management" we can see:
Code Assist for Include Content = YES
Syntax Coloring & Code Assist = YES
So the new version should offer the same thing as the previous version of PDT with Helios, shouldn't it?
See my problem here: www.eclipse.org/forums/index.php/mv/msg/359347/890241/#msg_890241
Re: Eclipse Helios + PDT = no validation [message #890261 is a reply to message #890254] |
Thu, 21 June 2012 16:07 |
In other word the solution is:
Installation of the new Eclipse PDT
Run
Start on a new workspace, letting Eclipse to create it from scratch
Copy all the project dirs of the older workspace in the new one (COPY, NOT MOVE because after this point you'll not be able to use older version of Eclipse on that workspace. Not tested, but is written in the readme of the new Eclipse. That old workspace could be of use).
File-Import->General->Existing projects into Workspace
then browse and select the new workspace, select all the project (default), dont' check the 2 checkboxes below, and that's it!
There are surely other ways to do the same, but the main concept is creating a new workspace and import the existing projects of the older one.
FUDForum. Page generated in 0.05539 seconds
