Adding maven to the provisioning repository [message #632761] |
Thu, 14 October 2010 08:24 |
Lorie Pisicchio Messages: 44 Registered: October 2010 |
Member |
I'm trying to add my local maven repository to the Virgo provisioning repository.
For this, I followed the Virgo user guide : I edited $VWS_HOME/config/org.eclipse.virgo.repository.properties, and add those lines
maven-repo.type=external
maven-repo.searchPattern=/home/lorie/.m2/repository/**/{bund le}.jar
also add the maven-repo string to the chain variable
chain=ext,usr,maven-repo
But after this modification, I'm no longer able to start the Virgo Web Server (no bundle deployed). I get the following error :
[2010-10-14 10:06:16.173] system-artifacts <TC0011E> Failed to start Tomcat. Port 8080 is in use.
Any help would be appreciated.
[Updated on: Thu, 14 October 2010 08:25] Report message to a moderator
Re: Adding maven to the provisioning repository [message #633103 is a reply to message #632791] |
Fri, 15 October 2010 11:50 |
Member |
Hello Glen,
Thanks for your support.
Here are the steps I'm following.
I first start the Virgo server without Maven repository. The server starts fine. (see the trace below)
[2010-10-15 13:42:46.525] startup-tracker <KE0001I> Kernel starting.
[2010-10-15 13:42:52.442] startup-tracker <KE0002I> Kernel started.
[2010-10-15 13:42:52.636] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-10-15 13:42:52.732] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-10-15 13:42:52.759] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-10-15 13:42:52.770] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-10-15 13:42:52.783] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:52.804] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:57.593] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-10-15 13:42:57.597] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-10-15 13:42:57.601] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-10-15 13:42:57.606] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:57.610] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:57.614] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-10-15 13:42:57.644] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-10-15 13:42:57.652] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-10-15 13:42:57.662] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-10-15 13:42:57.667] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-10-15 13:42:58.115] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-10-15 13:42:58.118] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-10-15 13:42:58.125] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-10-15 13:42:58.127] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:58.145] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:58.149] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:58.272] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:58.276] start-signalling-1 <DE0005I> Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-10-15 13:42:58.414] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.web' version '2.1.0'.
[2010-10-15 13:42:58.457] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.core' version '1.1.0.RC1-incubation'.
[2010-10-15 13:42:58.491] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RC1-incubation'.
[2010-10-15 13:42:58.506] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:58.513] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:58.523] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.tomcat' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:58.746] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.web.core' version '1.1.0.RC1-incubation'.
[2010-10-15 13:42:58.750] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RC1-incubation'.
[2010-10-15 13:42:58.753] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:58.756] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:58.760] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.tomcat' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:58.763] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.web' version '2.1.0'.
[2010-10-15 13:42:58.780] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.web' version '2.1.0'.
[2010-10-15 13:42:58.785] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.web.core' version '1.1.0.RC1-incubation'.
[2010-10-15 13:42:58.802] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.gemini.web.core' version '1.1.0.RC1-incubation'.
[2010-10-15 13:42:58.810] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RC1-incubation'.
[2010-10-15 13:42:59.431] system-artifacts <TC0000I> Starting Tomcat.
[2010-10-15 13:42:59.511] system-artifacts <TC0010I> Creating HTTP/1.1 connector with scheme http on port 8080.
[2010-10-15 13:42:59.525] system-artifacts <TC0010I> Creating HTTP/1.1 connector with scheme https on port 8443.
[2010-10-15 13:42:59.539] system-artifacts <TC0010I> Creating AJP/1.3 connector with scheme http on port 8009.
[2010-10-15 13:42:59.602] system-artifacts <TC0001I> Started Tomcat.
[2010-10-15 13:42:59.638] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.web.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:59.646] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.web.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:59.651] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.web.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:59.666] system-artifacts <DE0005I> Started bundle 'org.eclipse.virgo.web.tomcat' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:59.839] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RC1-incubation'.
[2010-10-15 13:42:59.843] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.virgo.web.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:42:59.847] start-signalling-2 <DE0005I> Started plan 'org.eclipse.virgo.web' version '2.1.0'.
[2010-10-15 13:42:59.855] Thread-2 <UR0001I> User region ready.
[2010-10-15 13:43:00.878] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation.par' .
[2010-10-15 13:43:00.983] fs-watcher <DE0000I> Installing par 'org.eclipse.virgo.apps.repository' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:00.987] fs-watcher <DE0000I> Installing bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org. eclipse.virgo.apps.repository.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:00.992] fs-watcher <DE0000I> Installing bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org. eclipse.virgo.apps.repository.web' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:01.354] fs-watcher <DE0001I> Installed bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org. eclipse.virgo.apps.repository.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:01.361] fs-watcher <DE0001I> Installed bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org. eclipse.virgo.apps.repository.web' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:01.365] fs-watcher <DE0001I> Installed bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-synt hetic.context' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:01.373] fs-watcher <DE0001I> Installed par 'org.eclipse.virgo.apps.repository' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:01.400] fs-watcher <DE0004I> Starting par 'org.eclipse.virgo.apps.repository' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:01.417] fs-watcher <DE0004I> Starting bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org. eclipse.virgo.apps.repository.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:01.525] fs-watcher <DE0004I> Starting bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org. eclipse.virgo.apps.repository.web' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:01.547] Thread-3 <WE0000I> Starting web bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org. eclipse.virgo.apps.repository.web' version '2.1.0.M06-incubation' with context path '/org.eclipse.virgo.apps.repository'.
[2010-10-15 13:43:01.549] fs-watcher <DE0004I> Starting bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-synt hetic.context' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:01.566] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-synt hetic.context' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:01.576] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.splash-2.1.0.M06-incubation.war'.
[2010-10-15 13:43:01.865] fs-watcher <DE0000I> Installing bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:02.035] fs-watcher <DE0001I> Installed bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:02.054] fs-watcher <DE0004I> Starting bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:02.074] Thread-3 <WE0000I> Starting web bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.M06-incubation' with context path '/'.
[2010-10-15 13:43:02.075] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.admin-2.1.0.M06-incubation.plan'.
[2010-10-15 13:43:02.341] fs-watcher <DE0000I> Installing plan 'org.eclipse.virgo.apps.admin.plan' version '2.1.0'.
[2010-10-15 13:43:02.354] start-signalling-3 <DE0005I> Started bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org. eclipse.virgo.apps.repository.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:02.372] fs-watcher <DE0000I> Installing bundle 'org.eclipse.virgo.apps.admin.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:02.701] fs-watcher <DE0000I> Installing bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:03.080] fs-watcher <DE0001I> Installed bundle 'org.eclipse.virgo.apps.admin.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:03.084] fs-watcher <DE0001I> Installed bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:03.087] fs-watcher <DE0001I> Installed plan 'org.eclipse.virgo.apps.admin.plan' version '2.1.0'.
[2010-10-15 13:43:03.142] fs-watcher <DE0004I> Starting plan 'org.eclipse.virgo.apps.admin.plan' version '2.1.0'.
[2010-10-15 13:43:03.147] fs-watcher <DE0004I> Starting bundle 'org.eclipse.virgo.apps.admin.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:03.167] fs-watcher <DE0004I> Starting bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:03.188] Thread-3 <WE0000I> Starting web bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.M06-incubation' with context path '/admin'.
[2010-10-15 13:43:03.648] start-signalling-4 <DE0005I> Started bundle 'org.eclipse.virgo.apps.admin.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:04.175] Thread-3 <WE0001I> Started web bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org. eclipse.virgo.apps.repository.web' version '2.1.0.M06-incubation' with context path '/org.eclipse.virgo.apps.repository'.
[2010-10-15 13:43:04.178] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org. eclipse.virgo.apps.repository.web' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:04.182] start-signalling-2 <DE0005I> Started par 'org.eclipse.virgo.apps.repository' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:04.588] Thread-3 <WE0001I> Started web bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.M06-incubation' with context path '/admin'.
[2010-10-15 13:43:04.591] start-signalling-3 <DE0005I> Started bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.M06-incubation'.
[2010-10-15 13:43:04.594] start-signalling-3 <DE0005I> Started plan 'org.eclipse.virgo.apps.admin.plan' version '2.1.0'.
[2010-10-15 13:43:04.705] Thread-3 <WE0001I> Started web bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.M06-incubation' with context path '/'.
[2010-10-15 13:43:04.708] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.M06-incubation'.
Then, I stop this server instance.
I modify the configuration file to add Maven to the provisioning repository.
And then, I start the server. This time, it crashes with the following trace :
[2010-10-15 13:45:50.912] startup-tracker <KE0001I> Kernel starting.
[2010-10-15 13:45:56.930] service-monitor-thread-1 <KE0100W> Reference '&repository' in bundle 'org.eclipse.virgo.kernel.osgi' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.repository.Repository)'.
[2010-10-15 13:46:00.527] service-monitor-thread-1 <KE0100W> Reference '&packageAdminUtil' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.framework.Packag eAdminUtil)'.
[2010-10-15 13:46:00.528] service-monitor-thread-1 <KE0100W> Reference '&quasiFrameworkFactory' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrame workFactory)'.
[2010-10-15 13:46:00.530] service-monitor-thread-1 <KE0100W> Reference '&runtimeArtifactModel' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.model.Runtim eArtifactModel)'.
[2010-10-15 13:46:00.531] service-monitor-thread-1 <KE0100W> Reference '&userBundleContext' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.M06-incubation' is waiting for service with filter '(&(objectClass=org.osgi.framework.BundleContext)(org.ec lipse.virgo.kernel.regionContext=true))'.
[2010-10-15 13:46:00.533] service-monitor-thread-1 <KE0100W> Reference '&applicationDeployer' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.Applica tionDeployer)'.
[2010-10-15 13:46:00.534] service-monitor-thread-1 <KE0100W> Reference '&quasiFrameworkFactory' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrame workFactory)'.
[2010-10-15 13:46:00.536] service-monitor-thread-1 <KE0100W> Reference '&moduleContextAccessor' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.module.ModuleContextA ccessor)'.
[2010-10-15 13:46:00.539] service-monitor-thread-1 <KE0100W> Reference '&userRegionBundleContext' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.M06-incubation' is waiting for service with filter '(&(objectClass=org.osgi.framework.BundleContext)(org.ec lipse.virgo.kernel.regionContext=true))'.
[2010-10-15 13:46:00.541] service-monitor-thread-1 <KE0100W> Reference '&deployer' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.Applica tionDeployer)'.
[2010-10-15 13:46:00.783] service-monitor-thread-1 <KE0100W> Reference '&objectNameCreator' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.model.management.Runt imeArtifactModelObjectNameCreator)'.
[2010-10-15 13:46:00.935] service-monitor-thread-1 <KE0100W> Reference '&org.springframework.osgi.service.importer.support.Osgi ServiceProxyFactoryBean#0' in bundle 'org.eclipse.virgo.kernel.deployer' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.region.Region)'.
[2010-10-15 13:46:00.937] service-monitor-thread-1 <KE0100W> Reference '&packageAdminUtil' in bundle 'org.eclipse.virgo.kernel.deployer' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.framework.Packag eAdminUtil)'.
[2010-10-15 13:46:00.938] service-monitor-thread-1 <KE0100W> Reference '&repository' in bundle 'org.eclipse.virgo.kernel.deployer' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.repository.Repository)'.
[2010-10-15 13:46:00.940] service-monitor-thread-1 <KE0100W> Reference '&osgiFramework' in bundle 'org.eclipse.virgo.kernel.deployer' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFr amework)'.
[2010-10-15 13:46:00.942] service-monitor-thread-1 <KE0100W> Reference '&quasiFrameworkFactory' in bundle 'org.eclipse.virgo.kernel.deployer' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrame workFactory)'.
[2010-10-15 13:46:00.943] service-monitor-thread-1 <KE0100W> Reference '&importExpander' in bundle 'org.eclipse.virgo.kernel.deployer' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.framework.Import Expander)'.
[2010-10-15 13:46:11.930] service-monitor-thread-1 <KE0100W> Reference '&repository' in bundle 'org.eclipse.virgo.kernel.osgi' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.repository.Repository)'.
[2010-10-15 13:46:14.202] Thread-3 <KE0101I> Reference '&repository' in bundle 'org.eclipse.virgo.kernel.deployer' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.repository.Repository)'.
[2010-10-15 13:46:14.204] Thread-3 <KE0101I> Reference '&repository' in bundle 'org.eclipse.virgo.kernel.osgi' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.repository.Repository)'.
[2010-10-15 13:46:14.735] Thread-3 <KE0101I> Reference '&importExpander' in bundle 'org.eclipse.virgo.kernel.deployer' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.framework.Import Expander)'.
[2010-10-15 13:46:14.742] Thread-3 <KE0101I> Reference '&osgiFramework' in bundle 'org.eclipse.virgo.kernel.deployer' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFr amework)'.
[2010-10-15 13:46:14.747] Thread-3 <KE0101I> Reference '&quasiFrameworkFactory' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrame workFactory)'.
[2010-10-15 13:46:14.750] Thread-3 <KE0101I> Reference '&quasiFrameworkFactory' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrame workFactory)'.
[2010-10-15 13:46:14.752] Thread-3 <KE0101I> Reference '&quasiFrameworkFactory' in bundle 'org.eclipse.virgo.kernel.deployer' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrame workFactory)'.
[2010-10-15 13:46:14.757] Thread-3 <KE0101I> Reference '&packageAdminUtil' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.framework.Packag eAdminUtil)'.
[2010-10-15 13:46:14.759] Thread-3 <KE0101I> Reference '&packageAdminUtil' in bundle 'org.eclipse.virgo.kernel.deployer' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.framework.Packag eAdminUtil)'.
[2010-10-15 13:46:14.764] Thread-3 <KE0101I> Reference '&moduleContextAccessor' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.module.ModuleContextA ccessor)'.
[2010-10-15 13:46:14.781] Thread-3 <KE0101I> Reference '&org.springframework.osgi.service.importer.support.Osgi ServiceProxyFactoryBean#0' in bundle 'org.eclipse.virgo.kernel.deployer' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.osgi.region.Region)'.
[2010-10-15 13:46:14.786] Thread-3 <KE0101I> Reference '&userBundleContext' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.M06-incubation' was satisfied by service with filter '(&(objectClass=org.osgi.framework.BundleContext)(org.ec lipse.virgo.kernel.regionContext=true))'.
[2010-10-15 13:46:14.801] Thread-3 <KE0101I> Reference '&userRegionBundleContext' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.M06-incubation' was satisfied by service with filter '(&(objectClass=org.osgi.framework.BundleContext)(org.ec lipse.virgo.kernel.regionContext=true))'.
[2010-10-15 13:46:14.980] Thread-3 <KE0101I> Reference '&applicationDeployer' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.Applica tionDeployer)'.
[2010-10-15 13:46:14.983] Thread-3 <KE0101I> Reference '&deployer' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.Applica tionDeployer)'.
[2010-10-15 13:46:15.399] Thread-3 <KE0101I> Reference '&runtimeArtifactModel' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.model.Runtim eArtifactModel)'.
[2010-10-15 13:46:15.783] service-monitor-thread-1 <KE0100W> Reference '&objectNameCreator' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.M06-incubation' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.model.management.Runt imeArtifactModelObjectNameCreator)'.
[2010-10-15 13:46:15.924] Thread-3 <KE0101I> Reference '&objectNameCreator' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.M06-incubation' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.model.management.Runt imeArtifactModelObjectNameCreator)'.
[2010-10-15 13:46:16.264] startup-tracker <KE0002I> Kernel started.
[2010-10-15 13:46:16.371] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-10-15 13:46:16.432] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-10-15 13:46:16.450] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-10-15 13:46:16.459] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-10-15 13:46:16.469] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:16.477] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:50.756] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-10-15 13:46:50.760] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-10-15 13:46:50.764] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-10-15 13:46:50.768] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:50.771] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:50.775] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-10-15 13:46:50.800] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-10-15 13:46:50.807] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-10-15 13:46:50.815] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-10-15 13:46:50.823] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-10-15 13:46:51.316] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-10-15 13:46:51.319] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-10-15 13:46:51.329] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:51.329] start-signalling-2 <DE0005I> Started bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-10-15 13:46:51.344] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:51.348] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:51.446] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:51.450] start-signalling-2 <DE0005I> Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-10-15 13:46:51.526] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.web' version '2.1.0'.
[2010-10-15 13:46:51.539] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.core' version '1.1.0.RC1-incubation'.
[2010-10-15 13:46:51.559] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RC1-incubation'.
[2010-10-15 13:46:51.569] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:51.576] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:51.585] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.tomcat' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:51.834] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.web.core' version '1.1.0.RC1-incubation'.
[2010-10-15 13:46:51.837] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RC1-incubation'.
[2010-10-15 13:46:51.840] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.core' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:51.844] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.dm' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:51.847] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.tomcat' version '2.1.0.M06-incubation'.
[2010-10-15 13:46:51.850] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.web' version '2.1.0'.
[2010-10-15 13:46:51.872] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.web' version '2.1.0'.
[2010-10-15 13:46:51.877] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.web.core' version '1.1.0.RC1-incubation'.
[2010-10-15 13:46:51.892] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.gemini.web.core' version '1.1.0.RC1-incubation'.
[2010-10-15 13:46:51.899] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RC1-incubation'.
[2010-10-15 13:46:52.220] system-artifacts <TC0011E> Failed to start Tomcat. Port 8080 is in use.
[2010-10-15 13:46:52.234] System Bundle Shutdown <KE0010I> Shutdown initiated.
Any idea?
[Updated on: Fri, 15 October 2010 11:52] Report message to a moderator
Re: Adding maven to the provisioning repository [message #633163 is a reply to message #633159] |
Fri, 15 October 2010 14:29 |
Member |
Here is a zip file containing :
- the configuration file working fine (org.eclipse.virgo.repository_OK.properties)
- the log file when starting and stopping the server successfully (successfull_start_and_stop.log)
- the configuration file declaring the maven repository as provisioning repository (org.eclipse.virgo.repository_KO.properties)
- the log file when server won't start with <TC0011E> Failed to start Tomcat. Port 8080 is in use. (failed_start_after_conf_change.log)
The new bug report have been created and has number Bug 327895
[Updated on: Fri, 15 October 2010 14:31] Report message to a moderator
Re: Adding maven to the provisioning repository [message #667957 is a reply to message #632761] |
Tue, 03 May 2011 01:07 |
Matt Fellows Messages: 28 Registered: February 2011 |
Just in case anybody else was having a similar issue, a simple rm -rf $VIRGO_HOME/work/* and restart from STS seemed to fix the problem for me. I wasn't pointing to a Maven repository, however I did have the remnants of an artifact (pax-web-services in fact) which caused problems only within STS.
Even though the configuration in Eclipse suggests it was no longer referencing it, there was some traces of the configuration left in the work dir.
Matt
[Updated on: Tue, 03 May 2011 02:57] Report message to a moderator
FUDForum. Page generated in 0.04762 seconds
