Re: How retrieve DefaultValue of a Property [message #632591] |
Wed, 13 October 2010 14:13 |
Ed Merks Messages: 33142 Registered: July 2009 |
Tom,
This sounds like a UML2 question that's best asked on the UML2
newsgroup, which I've added to the "to" list of the reply, so no need to
repost. I bet if you used the debugger (your best friend) to look at
the instance you'd know which field stores the value and then you could
look at the source code to see which method returns that field...
Tom Brandenburg wrote:
> Hello,
> currently I convert XMI files, to be processed in Eclipse. Following
> extract of the XMI:
> <ownedAttribute xmi:type="uml:Property" name="testAttr2"
> xmi:id="BOUML_0x27617_1" visibility="public">
> <defaultValue xmi:type="uml:LiteralString"
> xmi:id="BOUML_VALUE_0x27617_1" value="56"/>
> </ownedAttribute>
> evaluates to the following tree structure of the LiteralString:
> obj (LiteralStringImpl)
> +- eContainer (PropertyImpl)
> +- defaultValue (LiteralStringImpl)
> +- value ("56")
> But with what method of "obj" I get the value "56" of the defaultValue?
> Thanks in advance and best regards
> Tom
Ed Merks
Re: How retrieve DefaultValue of a Property [message #632652 is a reply to message #632591] |
Wed, 13 October 2010 17:15 |
Ed Willink Messages: 7655 Registered: July 2009 |
Hi Tom
I'm not a major UML expert, but it looks as if defaultValue is not part
of the model, just the meta-model, so:
At the modeling level you need an OCL ability to navigate the meta-model
that is not currently available (under discussion).
Pragmatically, you can just create a new object and see what value it
gets by default.
Using Ecore reflection you can navigate to the EClass and then the
EAttribute where the default value is reified.
Ed Willink
On 13/10/2010 15:13, Ed Merks wrote:
> Tom,
> repost. I bet if you used the debugger (your best friend) to look at the
> instance you'd know which field stores the value and then you could look
>> Hello,
>> extract of the XMI:
>> </ownedAttribute>
>> +- value ("56")
>> Tom
FUDForum. Page generated in 0.03735 seconds
