Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo: problems with HibernatePersistableEList.equal(Object)
Teneo: problems with HibernatePersistableEList.equal(Object) [message #63684] Tue, 05 December 2006 02:57 Go to next message
Hi all.
When I have some feature in my model which is unordered list it's mapped
as <bag> so in runtime I have HibernatePersistableEList which delegates
to hibernate PersistentBag class. The problem is that PersistantBag
equals() method is:
* Bag does not respect the collection API and do an
* JVM instance comparison to do the equals.
* The semantic is broken not to have to initialize a
* collection for a simple equals() operation.
* @see java.lang.Object#equals(java.lang.Object)
public boolean equals(Object obj) {
return super.equals(obj);
So when I try to compare two features which are
HibernatePersistableLists in runtime I get annoying result.
More: HibernatePersistableList delegating to PersistentBag is not equal
to itself. Why? Cause HibernatePersistableList extends DelegatingEList
that has:
public boolean equals(Object object)
return delegateEquals(object);
protected boolean delegateEquals(Object object)
return delegateList().equals(object);
Imagine that you have HibernatePersistableList myList.
myList.equals(myList) return always false cause calling to equals
results in comparison
persistentBagDelegate.equals(myList).
BUT HERE IS INSTANCE COMPARISON - SO IT RETURNS FALSE.
Is there any simple workaround or can Teneo implements correct equals()
method in PersistableLists?
Thanks in advance
Re: Teneo: problems with HibernatePersistableEList.equal(Object) [message #63753 is a reply to message #63684] Tue, 05 December 2006 07:11 Go to previous messageGo to next message
Hi Ilya,
As the hibernate remark says it can make sense to do jvm instance comparison for the
HibernatePersistableEList (because of lazy loading etc.).
Can you enter a bugzilla for this change (it means that this change is visible in the release notes
later)?
gr. Martin
Ilya Klyuchnikov wrote:
> Hi all.
> equals() method is:
> that has:
> Thanks in advance
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: problems with HibernatePersistableEList.equal(Object) [message #63800 is a reply to message #63753] Tue, 05 December 2006 09:05 Go to previous message
I have created issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=166778
Will wait for fix
Martin Taal wrote:
> Hi Ilya,
> comparison for the HibernatePersistableEList (because of lazy loading
> etc.).
> visible in the release notes later)?
> gr. Martin
>> Hi all.
>> mapped as <bag> so in runtime I have HibernatePersistableEList which
>> delegates to hibernate PersistentBag class. The problem is that
>> PersistantBag equals() method is:
>> equal to itself. Why? Cause HibernatePersistableList extends
>> DelegatingEList that has:
>> equals() method in PersistableLists?
>> Thanks in advance
Re: Teneo: problems with HibernatePersistableEList.equal(Object) [message #596530 is a reply to message #63684] Tue, 05 December 2006 07:11 Go to previous message
Hi Ilya,
later)?
gr. Martin
> Hi all.
> equals() method is:
> that has:
> Thanks in advance
The Netherlands
Re: Teneo: problems with HibernatePersistableEList.equal(Object) [message #596550 is a reply to message #63753] Tue, 05 December 2006 09:05 Go to previous message
Will wait for fix
Martin Taal wrote:
> Hi Ilya,
> etc.).
> gr. Martin
>> Hi all.
>> Thanks in advance
Previous Topic:extending EvaluationVisitorImpl
Next Topic:Dynamic constraint provider
Current Time: Sun Oct 26 09:20:37 EDT 2025
Powered by FUDForum. Page generated in 0.04604 seconds
