Teneo und Deep Objektgraphs [message #632342] |
Tue, 12 October 2010 10:59  |
I'm not sure this is really a problem of Teneo or more general a problem
of Hibernate itself.
Suppose you have the following Containment-Structure (ie a bidirectional
relation).
Company
Country
Region
Store
Department
When you now issue a HQL-Query "FROM Department" you'll notice that
Hibernate is executing after the first fetch an SQL-Statement which
JOINS Store, Region, Country, Company to follow up the the parent path.
Now imaging the Object-Graph is getting 10-times deeper and you'll get a
SQL-Statement with a lot, a lot of JOINS (in my case it even goes beyond
the limit of the database).
Anybody an idea how this could be solved?
Tom
Re: Teneo und Deep Objektgraphs [message #632359 is a reply to message #632342] |
Tue, 12 October 2010 12:17   |
Hi Tom,
Yes the parent econtainer relations are mapped using a hibernate custom type, apparently these are eagerly fetched. I
need to check if they support lazy loading. Can you enter a bugzilla for this? If you have a focused test model that
would be great, I can also create one myself (sounds pretty reproducable...).
gr. Martin
On 10/12/2010 04:59 PM, Tom Schindl wrote:
> relation).
> Company
> Country
> Region
> Store
> Department
> Tom
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo und Deep Objektgraphs [message #632424 is a reply to message #632359] |
Tue, 12 October 2010 16:22   |
Hi Martin,
So modeling them as bi-directional and not as containment this would not
happen?
I'm not sure that this is a teneo specific problem because when i read
the Hibernate-Docs correct hibernate has to fetch resolve bi-directional
references.
I'll file a bugzilla with a model that should reproduce the problem.
Tom
Am 12.10.10 18:17, schrieb Martin Taal:
> Hi Tom,
> type, apparently these are eagerly fetched. I need to check if they
> focused test model that would be great, I can also create one myself
> gr. Martin
>> relation).
>> Company
>> Country
>> Region
>> Store
>> Department
>> Tom
Re: Teneo und Deep Objektgraphs [message #632507 is a reply to message #632424] |
Wed, 13 October 2010 04:52  |
Hi Tom,
Yes guess so, the problem is that the custom user type used for econtainer associations does eager fetching, for normal
associations this eager fetching can be controlled by annotations.
I will react in the bugzilla.
gr. Martin
On 10/12/2010 10:22 PM, Tom Schindl wrote:
> Hi Martin,
> happen?
> references.
> Tom
>> Hi Tom,
>> gr. Martin
>>> Hi,
>>> relation).
>>> Company
>>> Country
>>> Region
>>> Store
>>> Department
>>> Tom
The Netherlands
FUDForum. Page generated in 0.03548 seconds
