GreenPages solution doesn't run on Virgo web server M06 [message #632221] |
Tue, 12 October 2010 07:39 |
Lorie Pisicchio Messages: 44 Registered: October 2010 |
Member |
I tried to run Greenpages solution on a Virgo Web Server created with M06 runtime file version.
When starting the web server, it raises an exception as it is not able to resolve the dependency for com.springsource.org.eclipse.persistence (see stack trace below).
I tried to open the Virgo admin console, to check which bundles were installed on the platform, but the console won't open (only displaying a white page).
I revert back to M05 version (fixing the path issue to have the server run), and everything went fine : running the greenpages web app, and starting the virgo admin console.
Stack trace :
[2010-10-12 09:33:18.331] TCP Connection(2)-127.0.0.1 <DE0002E> Installation of par 'greenpages' version '2.0.1' failed. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Unsatisfied dependency detected when expanding imports for [bundle 'greenpages-2.0.1-synthetic.context' version '2.0.1' in scope 'greenpages-2.0.1', bundle 'greenpages-2.0.1-greenpages.web' version '2.0.0' in scope 'greenpages-2.0.1', bundle 'greenpages-2.0.1-greenpages.jpa' version '2.0.0' in scope 'greenpages-2.0.1', bundle 'greenpages-2.0.1-greenpages' version '2.0.0' in scope 'greenpages-2.0.1', bundle 'greenpages-2.0.1-greenpages.db' version '2.0.0' in scope 'greenpages-2.0.1']
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpand ingTransformer.expandImports(ImportExpandingTransformer.java :116)
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpand ingTransformer.expandImportsOfBundlesInScopedPlan(ImportExpa ndingTransformer.java:89)
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpand ingTransformer$ImportExpandingTreeVisitor.visit(ImportExpand ingTransformer.java:76)
at org.eclipse.virgo.util.common.ThreadSafeArrayListTree.visit( ThreadSafeArrayListTree.java:165)
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpand ingTransformer.transform(ImportExpandingTransformer.java:58)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.in ternal.TransformationStage.doProcessTree(TransformationStage .java:55)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipe lineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardP ipeline.doProcessTree(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.Compensat ingPipeline.doProcessTree(CompensatingPipeline.java:72)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApp licationDeployer.driveInstallPipeline(PipelinedApplicationDe ployer.java:268)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApp licationDeployer.doInstall(PipelinedApplicationDeployer.java :151)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApp licationDeployer.install(PipelinedApplicationDeployer.java:1 23)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApp licationDeployer.deploy(PipelinedApplicationDeployer.java:18 7)
at org.eclipse.virgo.kernel.deployer.management.StandardDeploye r.deploy(StandardDeployer.java:52)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at com.sun.jmx.mbeanserver.ConvertingMethod.invokeWithOpenRetur n(ConvertingMethod.java:167)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIn trospector.java:96)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIn trospector.java:33)
at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntro spector.java:208)
at com.sun.jmx.mbeanserver.PerInterface.invoke(PerInterface.jav a:120)
at com.sun.jmx.mbeanserver.MBeanSupport.invoke(MBeanSupport.jav a:262)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke (DefaultMBeanServerInterceptor.java:836)
at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer .java:761)
at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RM IConnectionImpl.java:1427)
at javax.management.remote.rmi.RMIConnectionImpl.access$200(RMI ConnectionImpl.java:72)
at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOper ation.run(RMIConnectionImpl.java:1265)
at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOp eration(RMIConnectionImpl.java:1360)
at javax.management.remote.rmi.RMIConnectionImpl.invoke(RMIConn ectionImpl.java:788)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.ja va:305)
at sun.rmi.transport.Transport$1.run(Transport.java:159)
at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTranspo rt.java:535)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TC PTransport.java:790)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCP Transport.java:649)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundl eDependenciesException: Unable to satisfy dependencies of bundle 'greenpages-2.0.1-greenpages.jpa' at version '2.0.0': Import-Bundle with symbolic name 'com.springsource.org.eclipse.persistence' in version range '[1.0.0, 1.0.0]' could not be satisfied
at org.eclipse.virgo.kernel.userregion.internal.importexpansion .ImportExpansionHandler.getBundlePackageImports(ImportExpans ionHandler.java:271)
at org.eclipse.virgo.kernel.userregion.internal.importexpansion .ImportExpansionHandler.getAdditionalPackageImports(ImportEx pansionHandler.java:236)
at org.eclipse.virgo.kernel.userregion.internal.importexpansion .ImportExpansionHandler.expandImports(ImportExpansionHandler .java:206)
at org.eclipse.virgo.kernel.userregion.internal.importexpansion .ImportExpansionHandler.expandImportsIfNecessary(ImportExpan sionHandler.java:174)
at org.eclipse.virgo.kernel.userregion.internal.importexpansion .ImportExpansionHandler.expandImports(ImportExpansionHandler .java:112)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsin gReflection(AopUtils.java:307)
at org.springframework.osgi.service.importer.support.internal.a op.ServiceInvoker.doInvoke(ServiceInvoker.java:58)
at org.springframework.osgi.service.importer.support.internal.a op.ServiceInvoker.invoke(ServiceInvoker.java:62)
at org.springframework.aop.framework.ReflectiveMethodInvocation .proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.support.DelegatingIntroductionInterc eptor.doProceed(DelegatingIntroductionInterceptor.java:131)
at org.springframework.aop.support.DelegatingIntroductionInterc eptor.invoke(DelegatingIntroductionInterceptor.java:119)
at org.springframework.osgi.service.util.internal.aop.ServiceTC CLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java :56)
at org.springframework.osgi.service.util.internal.aop.ServiceTC CLInterceptor.invoke(ServiceTCCLInterceptor.java:39)
at org.springframework.osgi.service.importer.support.LocalBundl eContextAdvice.invoke(LocalBundleContextAdvice.java:59)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke( JdkDynamicAopProxy.java:202)
at $Proxy63.expandImports(Unknown Source)
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpand ingTransformer.expandImports(ImportExpandingTransformer.java :107)
... 47 common frames omitted
FUDForum. Page generated in 0.03418 seconds
