Home » Archived » Sketch » Some minimal documentation available?
Some minimal documentation available? [message #632125] |
Mon, 11 October 2010 11:48  |
Hi all,
I found the Sketch project website and concept intriguing and would love to try
out this SW myself, however, the download and setup instructions are a bit terse
(to say the least). I managed to install EGit and cloned the repository (i.e. I
now have 7 org.eclipse.sketch.* projects in my workspacve). And now, what's
next?
How do I build these into proper eclipse plugins? Where do I then place these
plugins or how do I deploy them to run that code?
Would some kind soul be willing to provide some minimal documentation on how to
get Sketch from source to executing?
Michael
(too) many crashes... [message #632276 is a reply to message #632144] |
Tue, 12 October 2010 08:00   |
On Mon, 11 Oct 2010 16:10:44 -0200, Ugo Sangiorgi <ugo.sangiorgi@gmail.com> wrote:
>Hello MIchael,
>First, sorry for not putting those instructions on the site -- I was trying to figure out a more smooth building with Mariot Chauvin, before putting some definitive documentation.
>But since you have all the plugins there, you should have sketch core (which has the recognition engine) and the RCP application (shapes).
>You can just test it as a normal RCP app, if you open shapes.product inside org.eclipse.sketch.examples.shapes, you should be able to run it using 'Launch an eclipse application' link.
>Then you can create a shapes file and proceed as the video do.
>If you have any more questions, please ask.
>I will be improving sketch quite a lot on the next months.
I managed to get the Sketch version I checked out yesterday running, created a project and then a shapes file, but - alas - it's
still VERY unstable. I never came to the point, where it actually starts recognising shapes (as seen in the video). After at most
the second or third shape drawn I usually ran into an endless exception cycle with the below exception.
The idea IMHO is brilliant, but I guess, I'll have to keep waiting and watching how things evolve!
This was using a freshly updated Eclipse Helios.
Michael
PS.: Most often I got the following Exception (often repeating, i.e. it kept "running away" with this exception):
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4083)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3660)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:173)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:388)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:507)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.r un(ProgressMonitorJobsDialog.java:275)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor. disconnectFromWorkspace(IDEWorkbenchAdvisor.java:509)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor. postShutdown(IDEWorkbenchAdvisor.java:342)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:29 67)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1 115)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:1 032)
at org.eclipse.ui.internal.Workbench$25.run(Workbench.java:1276 )
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1274)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1246)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:731)
at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:710)
at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindo w.java:826)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:824)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:741)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:68 7)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:98)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations. java:308)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1665)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4162 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1598)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2038)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4873 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2454 )
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:497)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4251 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 59)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3655)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: java.lang.NullPointerException
at org.eclipse.sketch.chain.LevenshteinHandler.perform(Levensht einHandler.java:51)
at org.eclipse.sketch.chain.ConnectionHandler.perform(Connectio nHandler.java:91)
at org.eclipse.sketch.chain.GestureHandler.perform(GestureHandl er.java:35)
at org.eclipse.sketch.SketchRecognizer$1.run(SketchRecognizer.j ava:71)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
... 74 more
Re: (too) many crashes... [message #632418 is a reply to message #632276] |
Tue, 12 October 2010 16:03   |
On 12-10-2010 09:00, Michael Moser wrote:
> On Mon, 11 Oct 2010 16:10:44 -0200, Ugo Sangiorgi<ugo.sangiorgi@gmail.com> wrote:
>> Hello MIchael,
> Cheers,
> Michael
> at java.lang.reflect.Method.invoke(Method.java:597)
> ... 74 more
Thanks Michael,
It is very unstable, thats why we didnt made an official release yet. =/
Can you please check if sketches.xml is created at your runtime folder?
I will investigate this further, this is very important -- I had no idea it was that bad.
Re: (too) many crashes... [message #634710 is a reply to message #634621] |
Fri, 22 October 2010 15:08   |
Hi Michael, the '40 .svg files with handdrawn shapes' sounds as expected,
although they must be cleaned up by the runtime when you leave.
I assume you are running a full Eclipse IDE on your target platform and not an RCP application, right?
Is the Control view being shown wither way?
If not, could you please file a couple bugs on sketch?
Thank you for the feedback :)
On 22-10-2010 09:45, Michael Moser wrote:
> On Tue, 12 Oct 2010 17:03:01 -0300, Ugo Sangiorgi<ugo.sangiorgi@gmail.com> wrote:
>> Thanks Michael,
> Hi Ugo and sorry, that I didn't check back earlier.
> Yes, that sketches.xml file was created (in C:\Users\mmo\Documents\eclipse\runtime-EclipseApplication):
> <?xml version="1.0" encoding="UTF-8" standalone="no"?>
> <!DOCTYPE properties SYSTEM "http://java.sun.com/dtd/properties.dtd">
> <properties>
> <comment>Generated by Eclipse Sketch - sketches made by mmo</comment>
> </properties>
> That directory also contained the project that I created (which only contained the .project file) and about 40 .svg files that
> contained misc. handdrawn rectangle shapes as I just verified.
> Cheers,
> Michael
Re: Re: (too) many crashes... [message #634880 is a reply to message #634710] |
Sun, 24 October 2010 15:58  |
On Fri, 22 Oct 2010 16:08:09 -0300, Ugo Sangiorgi <ugo.sangiorgi@gmail.com> wrote:
I guess it didn't get that far since I had to kill eclipse due to the endless ecxception loop.
Right, a full eclipse helios (the J2EE variant, if I recall correct).
yes, there is a control view.
You are welcome! Looking forward to new versions of Sketch! Since I own a tablet PC (MotionComputing) it would be REALLY cool to be
able to sketch drawings with it as well!
Michael
Current Time: Sun Aug 17 05:13:30 EDT 2025
Powered by FUDForum. Page generated in 0.04841 seconds
