Home » Modeling » EMF » UML class model
UML class model [message #631919] |
Sun, 10 October 2010 15:36 |
Lunus Messages: 4 Registered: August 2010 |
My initial motivation was to create a tool, which converts java source files to UML class diagrams.
The tool I wrote is divided into three sections. The main part is a representation of a class diagram with classes like UMLClassifier, UMLClass, UMLInterface, Stereotype, Multiplicity, Comment, Association, QualifiedAssociation, UMLVisibility and so on.
The other two parts are parsers and output generators.
When I came across XMI, of which I want to have a parser as well as an output generator, I read the book Mastering XMI, which I enjoyed, but sadly it is more about objects than classes. Nevertheless, I thought the ibm xmi framework is iteresting, but it is not maintained anymore and the webpage at ibm pointed me to the EMF project. This is actually where I started. The reason, why I did not get involved with the EMF was that I could not find documentation or tutorials which explain directly how I can create a model for a class diagram with Ecore. So even though I found classes like EClass and EAttribute, it seemed to be too complicated and I did not know whether or not it would fit my needs.
Since I would like to add XMI in and output I reconsider my decision, since it seems to be easy to generate XMI from Ecore models and vice versa.
I found an article which is great but still to short to get me started: http://www.devx.com/Java/Article/29093/0/page/2
So I guess I will give EMF another try and catch the book EMF: Eclipse Modeling Framework from the library.
Does Ecore have enough features to represent a UML 2 class diagram? For instance I need to represent interfaces, classes, comments, attributes with a type (primitive or class/interface), qualified associations with roles, visibilities for classes, interfaces, attributes, methods and roles, methods with named parameters and stereotypes to name just a few.
Any reference that may be of help is welcome.
Thanks a lot,
lunus
Re: UML class model [message #631920 is a reply to message #631919] |
Sun, 10 October 2010 15:53 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------070907020706090308000100
Lunus,
Comments below.
Lunus wrote:
The UML project has already done that.
> my needs.
You're trying to do UML but Ecore itself is too complicated...
> versa.
It's been done already:
<http://www.eclipse.org/modeling/mdt/?project=uml2>
Have a look at http://www.eclipse.org/modeling/mdt/?project=papyrus and
http://www.eclipse.org/MoDisco/ The later is focused on reverse
engineering and likely has already done much of what you describe.
> Thanks a lot,
> lunus
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Lunus,<br>
<br>
Comments below.<br>
<br>
Lunus wrote:
<blockquote cite="mid:i8smbk$e1j$1@news.eclipse.org" type="cite">Hi, <br>
files to UML class diagrams. <br>
<br>
<br>
<br>
directly how I can create a model for a class diagram with Ecore. </blockquote>
The UML project has already done that.<br>
<blockquote cite="mid:i8smbk$e1j$1@news.eclipse.org" type="cite">So
needs.
<br>
</blockquote>
You're trying to do UML but Ecore itself is too complicated...<br>
<blockquote cite="mid:i8smbk$e1j$1@news.eclipse.org" type="cite">Since
it seems to be easy to generate XMI from Ecore models and vice versa. <br>
<a class="moz-txt-link-freetext" href="http://www.devx.com/Java/Article/29093/0/page/2">http://www.devx.com/Java/Article/29093/0/page/2</a>
<br>
<br>
<br>
Does Ecore have enough features to represent a UML 2 class diagram? </blockquote>
It's been done already:<a
href="http://www.eclipse.org/modeling/mdt/?project=uml2"><br>
</a>
<blockquote><a href="http://www.eclipse.org/modeling/mdt/?project=uml2">http://www.eclipse.org/modeling/mdt/?project=uml2</a><br>
</blockquote>
<blockquote cite="mid:i8smbk$e1j$1@news.eclipse.org" type="cite">For
few.
<br>
<br>
<br>
</blockquote>
Have a look at <a
href="http://www.eclipse.org/modeling/mdt/?project=papyrus">http://www.eclipse.org/modeling/mdt/?project=papyrus</a>
and <a href="http://www.eclipse.org/MoDisco/">http://www.eclipse.org/MoDisco/</a>.
The later is focused on reverse engineering and likely has already done
much of what you describe.<br>
<blockquote cite="mid:i8smbk$e1j$1@news.eclipse.org" type="cite"><br>
Thanks a lot,
<br>
lunus
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------070907020706090308000100--
Ed Merks
Re: UML class model [message #632149 is a reply to message #631928] |
Mon, 11 October 2010 18:14 |
Lunus,
Comments below.
Lunus wrote:
> Hi Ed Merks,
> And thanks for your reply. I am confident that I can use the uml2
> plugin. Even though it will be painful to rewrite half of my code, I
> guess it is worth it and I want to learn more about eclipse anyway. I
> did not get what exactly the capabilities of the other two projects
> you brought up are. The description I found is abstract. Can I use
> them to generate a UML class model from java sources
MoDisco is about model discovery, i.e., reverse engineering so it
certainly sounds related.
> or uml 2 class model <--> XMI conversion?
XMI isn't really a conversion process, it's just a serialization
format. UML2 allows you to save UML instances as XMI. But class
diagrams are about more than just the abstract UML2 instance, it's also
about diagrams, and for that you need to consider how to create the
graphical description using things like the Notation model from GMF.
Papyrus is a project that lets you edit and view such graphical
representations.
> I guess I will eventually figure it out in time.
There's a lot to learn...
Ed Merks
Current Time: Sat Apr 27 01:58:07 GMT 2024
Powered by FUDForum. Page generated in 0.03007 seconds
