| Try to use osgi compendium services [message #631917] |
Sun, 10 October 2010 10:48  |
Hi everybody,
i try to set up a project using "maven" defining the project. "bundlor" to create the osgi manifest, "Spring extender" to instantiate and get references of services. Virgo as the osgi runtime org.osgi.compendium as the api imported and equinox bundles as implementations of the compendium services !
in mavens pom i defined the api´s i need and defined the scope as provided, because i think they are available in the runtime. (i also provided them into the runtime to be sure they are available)
pom.xml
<dependency>
<groupId>org.osgi</groupId>
<artifactId>org.osgi.core</artifactId>
<version>4.2.0</version>
<scope>provided</scope>
</dependency>
<dependency>
<artifactId>org.osgi.compendium</artifactId>
</dependency>
the manifest file created by the bundlor (only the import) i think this looks right.
manifest.mf
Import-Package: org.osgi.framework,org.osgi.service.cm,org.osgi.servic
e.event,org.osgi.service.log,org.springframework.beans.factory.annotatio
n,org.springframework.core.style,org.springframework.util
the spring extender tries to get an instance of the LogService by interface
bundle-context-osgi.xml
<reference
id="logService"
interface="org.osgi.service.log.LogService" />
to be sure not missing anything i served these jar into the pickup folder of vigor
pickup folder
org.eclipse.equinox.cm_1.0.200.v20100520.jar
org.eclipse.equinox.event_1.2.0.v20100503.jar
org.eclipse.equinox.log_1.2.100.v20100503.jar
org.eclipse.equinox.util_1.0.200.v20100503.jar
org.eclipse.osgi.util_3.2.100.v20100503.jar
org.osgi.compendium-4.2.0.jar
org.osgi.core-4.2.0.jar
and i face to this output and have no clue how to solve this issue.
[2010-10-10 16:45:40.066] startup-tracker <KE0001I> Kernel starting.
[2010-10-10 16:45:47.728] startup-tracker <KE0002I> Kernel started.
[2010-10-10 16:45:47.940] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-10-10 16:45:49.229] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-10-10 16:45:49.699] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-10-10 16:45:49.848] system-artifacts <DE0000I> Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-10-10 16:45:49.967] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:50.067] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:53.554] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-10-10 16:45:53.567] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-10-10 16:45:53.577] system-artifacts <DE0001I> Installed bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-10-10 16:45:53.586] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:53.598] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:53.620] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-10-10 16:45:53.713] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-10-10 16:45:53.734] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-10-10 16:45:53.751] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-10-10 16:45:53.767] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-10-10 16:45:55.021] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-10-10 16:45:55.040] system-artifacts <DE0004I> Starting bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-10-10 16:45:55.052] start-signalling-1 <DE0005I> Started bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-10-10 16:45:55.068] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:55.094] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:55.147] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:55.364] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:55.374] start-signalling-1 <DE0005I> Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-10-10 16:45:55.564] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.web' version '2.1.0'.
[2010-10-10 16:45:55.964] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.core' version '1.1.0.RC1-incubation'.
[2010-10-10 16:45:56.299] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RC1-incubation'.
[2010-10-10 16:45:56.443] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.core' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:56.523] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.dm' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:56.674] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.tomcat' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:58.345] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.web.core' version '1.1.0.RC1-incubation'.
[2010-10-10 16:45:58.359] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RC1-incubation'.
[2010-10-10 16:45:58.374] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.core' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:58.383] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.dm' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:58.392] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.tomcat' version '2.1.0.M06-incubation'.
[2010-10-10 16:45:58.420] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.web' version '2.1.0'.
[2010-10-10 16:45:58.464] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.web' version '2.1.0'.
[2010-10-10 16:45:58.498] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.web.core' version '1.1.0.RC1-incubation'.
[2010-10-10 16:45:58.550] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.gemini.web.core' version '1.1.0.RC1-incubation'.
[2010-10-10 16:45:58.572] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RC1-incubation'.
[2010-10-10 16:46:00.104] system-artifacts <TC0000I> Starting Tomcat.
[2010-10-10 16:46:00.193] system-artifacts <TC0010I> Creating HTTP/1.1 connector with scheme http on port 8080.
[2010-10-10 16:46:00.637] system-artifacts <TC0010I> Creating HTTP/1.1 connector with scheme https on port 8443.
[2010-10-10 16:46:00.693] system-artifacts <TC0010I> Creating AJP/1.3 connector with scheme http on port 8009.
[2010-10-10 16:46:00.821] system-artifacts <TC0001I> Started Tomcat.
[2010-10-10 16:46:00.916] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.web.core' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:00.935] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.web.dm' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:00.965] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.web.dm' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:01.194] system-artifacts <DE0005I> Started bundle 'org.eclipse.virgo.web.tomcat' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:01.516] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.gemini.web.tomcat' version '1.1.0.RC1-incubation'.
[2010-10-10 16:46:01.526] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.virgo.web.core' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:01.536] start-signalling-2 <DE0005I> Started plan 'org.eclipse.virgo.web' version '2.1.0'.
[2010-10-10 16:46:01.549] Thread-6 <UR0001I> User region ready.
[2010-10-10 16:46:01.947] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.equinox.cm' version '1.0.200.v20100520'.
[2010-10-10 16:46:02.195] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.equinox.cm' version '1.0.200.v20100520'.
[2010-10-10 16:46:02.227] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.equinox.cm' version '1.0.200.v20100520'.
[2010-10-10 16:46:02.269] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.equinox.cm' version '1.0.200.v20100520'.
[2010-10-10 16:46:02.504] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.equinox.event' version '1.2.0.v20100503'.
[2010-10-10 16:46:02.673] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.equinox.event' version '1.2.0.v20100503'.
[2010-10-10 16:46:02.707] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.equinox.event' version '1.2.0.v20100503'.
[2010-10-10 16:46:03.032] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.equinox.log' version '1.2.100.v20100503'.
[2010-10-10 16:46:03.283] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.equinox.log' version '1.2.100.v20100503'.
[2010-10-10 16:46:03.323] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.equinox.log' version '1.2.100.v20100503'.
[2010-10-10 16:46:03.357] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.equinox.log' version '1.2.100.v20100503'.
[2010-10-10 16:46:03.942] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.equinox.util' version '1.0.200.v20100503'.
[2010-10-10 16:46:04.201] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.equinox.util' version '1.0.200.v20100503'.
[2010-10-10 16:46:04.212] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.equinox.util' version '1.0.200.v20100503'.
[2010-10-10 16:46:04.402] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.osgi.util' version '3.2.100.v20100503'.
[2010-10-10 16:46:04.508] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.osgi.util' version '3.2.100.v20100503'.
[2010-10-10 16:46:04.548] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.osgi.util' version '3.2.100.v20100503'.
[2010-10-10 16:46:04.560] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.osgi.util' version '3.2.100.v20100503'.
[2010-10-10 16:46:04.664] deployer-recovery <DE0000I> Installing plan 'org.eclipse.virgo.apps.admin.plan' version '2.1.0'.
[2010-10-10 16:46:04.896] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.virgo.apps.admin.core' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:11.768] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:22.385] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.virgo.apps.admin.core' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:22.394] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:22.403] deployer-recovery <DE0001I> Installed plan 'org.eclipse.virgo.apps.admin.plan' version '2.1.0'.
[2010-10-10 16:46:22.433] deployer-recovery <DE0004I> Starting plan 'org.eclipse.virgo.apps.admin.plan' version '2.1.0'.
[2010-10-10 16:46:22.457] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.virgo.apps.admin.core' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:22.725] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:22.742] Thread-7 <WE0000I> Starting web bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.M06-incubation' with cont
ext path '/admin'.
[2010-10-10 16:46:23.453] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.apps.admin.core' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:24.829] deployer-recovery <DE0000I> Installing par 'org.eclipse.virgo.apps.repository' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:24.896] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org.eclipse.virgo.app
s.repository.core' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:24.916] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org.eclipse.virgo.app
s.repository.web' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:26.005] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org.eclipse.virgo.apps
[2010-10-10 16:46:26.015] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org.eclipse.virgo.apps
[2010-10-10 16:46:26.024] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-synthetic.context' ver
[2010-10-10 16:46:26.033] deployer-recovery <DE0001I> Installed par 'org.eclipse.virgo.apps.repository' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:26.141] deployer-recovery <DE0004I> Starting par 'org.eclipse.virgo.apps.repository' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:26.202] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org.eclipse.virgo.apps.
[2010-10-10 16:46:26.468] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org.eclipse.virgo.apps.
[2010-10-10 16:46:26.486] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-synthetic.context' vers
[2010-10-10 16:46:26.625] start-signalling-3 <DE0005I> Started bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-synthetic.context' versi
[2010-10-10 16:46:26.717] Thread-7 <WE0000I> Starting web bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org.eclipse.virgo.a
pps.repository.web' version '2.1.0.M06-incubation' with context path '/org.eclipse.virgo.apps.repository'.
[2010-10-10 16:46:26.973] Thread-7 <WE0001I> Started web bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.M06-incubation' with conte
xt path '/admin'.
[2010-10-10 16:46:27.053] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.virgo.apps.admin.web' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:27.064] start-signalling-2 <DE0005I> Started plan 'org.eclipse.virgo.apps.admin.plan' version '2.1.0'.
[2010-10-10 16:46:27.311] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org.eclipse.virgo.apps.r
[2010-10-10 16:46:28.081] deployer-recovery <DE0000I> Installing bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:28.596] deployer-recovery <DE0001I> Installed bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:28.642] Thread-7 <WE0001I> Started web bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org.eclipse.virgo.ap
[2010-10-10 16:46:28.652] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation-org.eclipse.virgo.apps.r
[2010-10-10 16:46:28.661] start-signalling-1 <DE0005I> Started par 'org.eclipse.virgo.apps.repository' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:28.705] deployer-recovery <DE0004I> Starting bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:28.800] Thread-7 <WE0000I> Starting web bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.M06-incubation' with context
path '/'.
[2010-10-10 16:46:29.356] Thread-7 <WE0001I> Started web bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.M06-incubation' with context
path '/'.
[2010-10-10 16:46:29.365] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.apps.splash' version '2.1.0.M06-incubation'.
[2010-10-10 16:46:32.857] deployer-recovery <DE0000I> Installing bundle 'osgi.cmpn' version '4.2.0.200908310645'.
[2010-10-10 16:46:36.047] deployer-recovery <DE0001I> Installed bundle 'osgi.cmpn' version '4.2.0.200908310645'.
[2010-10-10 16:46:36.066] deployer-recovery <DE0004I> Starting bundle 'osgi.cmpn' version '4.2.0.200908310645'.
[2010-10-10 16:46:36.076] start-signalling-1 <DE0005I> Started bundle 'osgi.cmpn' version '4.2.0.200908310645'.
[2010-10-10 16:46:38.080] deployer-recovery <DE0000I> Installing bundle 'osgi.core' version '4.2.0.200908310645'.
[2010-10-10 16:46:40.622] deployer-recovery <DE0001I> Installed bundle 'osgi.core' version '4.2.0.200908310645'.
[2010-10-10 16:46:40.636] deployer-recovery <DE0004I> Starting bundle 'osgi.core' version '4.2.0.200908310645'.
[2010-10-10 16:46:40.644] start-signalling-1 <DE0005I> Started bundle 'osgi.core' version '4.2.0.200908310645'.
[2010-10-10 16:46:41.403] TCP Connection(4)-127.0.0.1 <DE0000I> Installing bundle 'osgi.supervisor.scada' version '0.0.0'.
[2010-10-10 16:46:41.661] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.equinox.cm_1.0.200.v20100520.jar'
[2010-10-10 16:46:41.859] TCP Connection(4)-127.0.0.1 <DE0001I> Installed bundle 'osgi.supervisor.scada' version '0.0.0'.
[2010-10-10 16:46:41.879] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.equinox.cm_1.0.200.v20100520.jar' is already
deployed.
[2010-10-10 16:46:41.885] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.equinox.event_1.2.0.v20100503.jar
[2010-10-10 16:46:41.891] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.equinox.event_1.2.0.v20100503.jar' is alread
y deployed.
[2010-10-10 16:46:41.899] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.equinox.log_1.2.100.v20100503.jar
[2010-10-10 16:46:41.905] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.equinox.log_1.2.100.v20100503.jar' is alread
y deployed.
[2010-10-10 16:46:41.913] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.equinox.util_1.0.200.v20100503.ja
r'.
[2010-10-10 16:46:41.924] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.equinox.util_1.0.200.v20100503.jar' is alrea
dy deployed.
[2010-10-10 16:46:41.931] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.osgi.util_3.2.100.v20100503.jar'.
[2010-10-10 16:46:41.953] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.osgi.util_3.2.100.v20100503.jar' is already
deployed.
[2010-10-10 16:46:41.975] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.admin-2.1.0.M06-incuba
tion.plan'.
[2010-10-10 16:46:41.983] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.virgo.apps.admin-2.1.0.M06-incubation.plan'
is already deployed.
[2010-10-10 16:46:41.998] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.repository-2.1.0.M06-i
ncubation.par'.
[2010-10-10 16:46:42.005] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.virgo.apps.repository-2.1.0.M06-incubation.p
ar' is already deployed.
[2010-10-10 16:46:42.013] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.splash-2.1.0.M06-incub
ation.war'.
[2010-10-10 16:46:42.021] fs-watcher <HD0005I> Hot deploy not performed because file 'org.eclipse.virgo.apps.splash-2.1.0.M06-incubation.war'
[2010-10-10 16:46:42.033] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.osgi.compendium-4.2.0.jar'.
[2010-10-10 16:46:42.117] TCP Connection(4)-127.0.0.1 <DE0004I> Starting bundle 'osgi.supervisor.scada' version '0.0.0'.
[2010-10-10 16:46:42.127] fs-watcher <HD0005I> Hot deploy not performed because file 'org.osgi.compendium-4.2.0.jar' is already deployed.
[2010-10-10 16:46:42.135] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.osgi.core-4.2.0.jar'.
[2010-10-10 16:46:42.148] fs-watcher <HD0005I> Hot deploy not performed because file 'org.osgi.core-4.2.0.jar' is already deployed.
[2010-10-10 16:46:42.378] Thread-7 <AG0000E> Application context creation failure for bundle 'osgi.supervisor.scada' version '0.0.0'. org.sp
ringframework.beans.factory.BeanCreationException: Error creating bean with name 'logService': Initialization of bean failed; nested exception is org.springfram
ework.beans.TypeMismatchException: Failed to convert property value of type 'java.lang.String' to required type 'java.lang.Class[]' for property 'interfaces'; n
ested exception is java.lang.IllegalArgumentException: Cannot find class [org.osgi.service.log.LogService]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:450)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:290)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:287)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:189)
at org.springframework.osgi.extender.internal.dependencies.startup.MandatoryImporterDependencyFactory.getServiceDependencies(MandatoryImporterDependencyFactory
.java:63)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager.doFindDependencies(DependencyServiceManager.java:272)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager.access$700(DependencyServiceManager.java:40)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager$1.run(DependencyServiceManager.java:213)
at org.springframework.osgi.extender.internal.util.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:124)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager.findServiceDependencies(DependencyServiceManager.java:209)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.stageOne(DependencyWaiterApplicationContextExecut
or.java:239)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.refresh(DependencyWaiterApplicationContextExecuto
r.java:169)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.refresh(AbstractDelegatedExecutionApplicationContext.java:175)
at org.springframework.osgi.extender.internal.activator.ContextLoaderListener$2.run(ContextLoaderListener.java:716)
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.springframework.beans.TypeMismatchException: Failed to convert property value of type 'java.lang.String' to required type 'java.lang.Class[]' for
property 'interfaces'; nested exception is java.lang.IllegalArgumentException: Cannot find class [org.osgi.service.log.LogService]
at org.springframework.beans.BeanWrapperImpl.convertForProperty(BeanWrapperImpl.java:457)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.convertForProperty(AbstractAutowireCapableBeanFactory.java:1351)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1310)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1067)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:511)
... 19 common frames omitted
Caused by: java.lang.IllegalArgumentException: Cannot find class [org.osgi.service.log.LogService]
at org.springframework.util.ClassUtils.resolveClassName(ClassUtils.java:294)
at org.springframework.beans.propertyeditors.ClassArrayEditor.setAsText(ClassArrayEditor.java:67)
at org.springframework.beans.TypeConverterDelegate.doConvertTextValue(TypeConverterDelegate.java:474)
at org.springframework.beans.TypeConverterDelegate.doConvertValue(TypeConverterDelegate.java:446)
at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:215)
at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:154)
at org.springframework.beans.BeanWrapperImpl.convertForProperty(BeanWrapperImpl.java:452)
... 23 common frames omitted
Caused by: java.lang.ClassNotFoundException: org.osgi.service.log.LogService not found from bundle [osgi.supervisor.scada]
at org.springframework.osgi.util.BundleDelegatingClassLoader.findClass(BundleDelegatingClassLoader.java:103)
at org.springframework.osgi.util.BundleDelegatingClassLoader.loadClass(BundleDelegatingClassLoader.java:156)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at org.springframework.util.ClassUtils.forName(ClassUtils.java:258)
at org.springframework.util.ClassUtils.resolveClassName(ClassUtils.java:291)
... 29 common frames omitted
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: org.osgi.service.log.LogService in KernelBundleClassLoader: [bundle=osgi.supe
rvisor.scada_0.0.0]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:139)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:338)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:232)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1197)
at org.springframework.osgi.util.BundleDelegatingClassLoader.findClass(BundleDelegatingClassLoader.java:99)
... 33 common frames omitted
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:506)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:135)
... 38 common frames omitted
[2010-10-10 16:46:42.395] start-signalling-1 <DE0006E> Start failed for bundle 'osgi.supervisor.scada' version '0.0.0'. org.springframework.beans.fact
ory.BeanCreationException: Error creating bean with name 'logService': Initialization of bean failed; nested exception is org.springframework.beans.TypeMismatch
Exception: Failed to convert property value of type 'java.lang.String' to required type 'java.lang.Class[]' for property 'interfaces'; nested exception is java.
.java:63)
or.java:239)
r.java:169)
rvisor.scada_0.0.0]
[2010-10-10 16:46:42.412] start-signalling-1 <DE0010I> Stopping bundle 'osgi.supervisor.scada' version '0.0.0'.
[2010-10-10 16:46:42.732] start-signalling-1 <DE0011I> Stopped bundle 'osgi.supervisor.scada' version '0.0.0'.
[2010-10-10 16:46:42.743] TCP Connection(4)-127.0.0.1 <DE0013I> Uninstalling bundle 'osgi.supervisor.scada' version '0.0.0'.
[2010-10-10 16:46:42.876] TCP Connection(4)-127.0.0.1 <DE0014I> Uninstalled bundle 'osgi.supervisor.scada' version '0.0.0'.
[2010-10-10 16:46:44.666] TCP Connection(4)-127.0.0.1 <DE0000I> Installing bundle 'osgi.supervisor.dlog' version '0.0.0'.
[2010-10-10 16:46:44.733] TCP Connection(4)-127.0.0.1 <DE0001I> Installed bundle 'osgi.supervisor.dlog' version '0.0.0'.
[2010-10-10 16:46:44.750] TCP Connection(4)-127.0.0.1 <DE0004I> Starting bundle 'osgi.supervisor.dlog' version '0.0.0'.
[2010-10-10 16:46:44.763] start-signalling-1 <DE0005I> Started bundle 'osgi.supervisor.dlog' version '0.0.0'.
FUDForum. Page generated in 0.03923 seconds
