| NoClassDefFoundError on Virgo Web Server M5 [message #631598] |
Fri, 08 October 2010 03:26  |
My bundle publish "javax.transaction.UserTransaction" using Atomikos 3.6.5. It works well on Virgo Web Server M4, but it failed on M5.
Is it a known issue due to the directory layout change in M5?
[2010-10-08 15:10:19.694] start-signalling-3 org.eclipse.virgo.medic.eventlog.default DE0006E Start failed for bundle 'org.planner.infrastructure.jtatransaction' version '1.0.0.201009211243'. org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'userTransactionService' defined in URL [ bundleentry://81.fwk12296027/META-INF/spring/module-context. xml]: Invocation of init method failed; nested exception is java.lang.NoClassDefFoundError: javax/transaction/TransactionManager
at org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.initializeBean(AbstractAutowireCapableBeanF actory.java:1401)
at org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFac tory.java:512)
at org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.createBean(AbstractAutowireCapableBeanFacto ry.java:450)
at org.springframework.beans.factory.support.AbstractBeanFactor y$1.getObject(AbstractBeanFactory.java:290)
at org.springframework.beans.factory.support.DefaultSingletonBe anRegistry.getSingleton(DefaultSingletonBeanRegistry.java:22 2)
at org.springframework.beans.factory.support.AbstractBeanFactor y.doGetBean(AbstractBeanFactory.java:287)
at org.springframework.beans.factory.support.AbstractBeanFactor y.getBean(AbstractBeanFactory.java:189)
at org.springframework.beans.factory.support.DefaultListableBea nFactory.preInstantiateSingletons(DefaultListableBeanFactory .java:557)
at org.springframework.context.support.AbstractApplicationConte xt.finishBeanFactoryInitialization(AbstractApplicationContex t.java:842)
at org.springframework.osgi.context.support.AbstractDelegatedEx ecutionApplicationContext.access$1600(AbstractDelegatedExecu tionApplicationContext.java:69)
at org.springframework.osgi.context.support.AbstractDelegatedEx ecutionApplicationContext$4.run(AbstractDelegatedExecutionAp plicationContext.java:355)
at org.springframework.osgi.util.internal.PrivilegedUtils.execu teWithCustomTCCL(PrivilegedUtils.java:85)
at org.springframework.osgi.context.support.AbstractDelegatedEx ecutionApplicationContext.completeRefresh(AbstractDelegatedE xecutionApplicationContext.java:320)
at org.springframework.osgi.extender.internal.dependencies.star tup.DependencyWaiterApplicationContextExecutor$CompleteRefre shTask.run(DependencyWaiterApplicationContextExecutor.java:1 32)
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExec utor$2.run(ContextPropagatingTaskExecutor.java:95)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.NoClassDefFoundError: javax/transaction/TransactionManager
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2427)
at java.lang.Class.getMethod0(Class.java:2670)
at java.lang.Class.getMethod(Class.java:1603)
at org.springframework.beans.BeanUtils.findMethod(BeanUtils.jav a:162)
at org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapa bleBeanFactory.java:1483)
at org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.invokeInitMethods(AbstractAutowireCapableBe anFactory.java:1468)
at org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.initializeBean(AbstractAutowireCapableBeanF actory.java:1398)
... 17 common frames omitted
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoun dException: javax.transaction.TransactionManager in KernelBundleClassLoader: [bundle=com.atomikos.transactions-api_3.6.5]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelB undleClassLoader.loadClass(KernelBundleClassLoader.java:139)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
... 25 common frames omitted
Caused by: java.lang.ClassNotFoundException: javax.transaction.TransactionManager
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:460)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:107)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelB undleClassLoader.loadClass(KernelBundleClassLoader.java:135)
... 26 common frames omitted
FUDForum. Page generated in 0.04059 seconds
