Re: Arabic fonts are not rendered [message #630943 is a reply to message #630840] |
Tue, 05 October 2010 15:45 |
Martin,
If you are using the viewer you can set the log level to FINEST in the
web.xml.
Jason
On 10/5/2010 5:10 AM, Martin Schaller wrote:
> One of our customers is using BIRT and arabic fonts. We have configured
> the fonts directory in fontsConfig.xml. At the startup of the rendition
> engine we get the following message INFO: register fonts in
> /Apps/Documentum/fonts cost:156ms
> but no arabic fonts are rendered.
> In a second environment the rendering of arabic fonts works fine and we
> notice a much larger time to load the fonts:
> INFO: register fonts in /Apps/Documentum/fonts cost:12460ms
> Furthermore, in the not-working environment the access time of the fonts
> is not changed at startup, in contrast to the working environment.
> We are using BIRT 2.3 in an AIX environment. We double-checked directory
> names and file permissions and the two enviroments seem to be identical
> but we were not able to solve the issue.
> Did anyone experience similar problems. Are there any possibilities to
> increase the logging level or to obtain more information why the fonts
> are not loaded (or not used)?
> Thanks for any help,
> Martin
FUDForum. Page generated in 0.03131 seconds
