Re: Misaligned feature name problems after upgrading to SR1 [message #630295 is a reply to message #630274] |
Fri, 01 October 2010 12:46 |
--------------000703000702010403050008
Hi Ed,
Do you have an hint as to what caused this? Otherwise, could you provide
us with the list of features you installed?
Laurent Goubet
Obeo
Ed Willink wrote:
> Hi
> After upgrading to the Modeling EPP SR1, I am getting a variety of
> builder and editor initialization failures due to "The feature
> 'tilities' is not a valid feature" also for or 'angType' or
> 'avaImplementionCS'. In each case the problem feature is a valid feature
> name less its leading character.
> These problems cause fatal Resource load issues and prevent the Acceleo
> Editor or Builder being used; the error log suggests the Xtext builder
> has a problem too.
> The problems go away within a nested Eclipse session.
> I suspected some Java 5/6 or file encoding nightmare but couldn't find
> any real difference. I reverted back to SR'0' and for a while the
> Acceleo editor seemed ok. Eventually bit rot set in and SR0 and SR1
> are now equally broken.
> Any suggestions?
> Regards
> Ed Willink
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------000703000702010403050008--
Re: Misaligned feature name problems after upgrading to SR1 [message #630297 is a reply to message #630296] |
Fri, 01 October 2010 13:24 |
--------------000902050606070303040605
Ed,
I prefer that :p. Just tried to download a fresh 3.6.1 modeling package
and install some projects (including Acceleo) from the discovery UI, and
I couldn't reproduce this (hopefully).
I never trusted in updating from one version to the next ... You're not
helping that ^^.
Laurent Goubet
Obeo
Ed Willink wrote:
> Hi Laurent
> I suspect, it is a Platform or possibly EMF bug. I was just hoping that
> someone might have also seen this and solved it.
> I've never had much success reusing a Workspace after an upgrade despite
> one of the senior Platform guys claiming that he had kept the same
> workspace going for many years.
> Problem goes away when I start a brand new workspace, yet again. My old
> workspace had far too many interesting incubation projects like Modisco
> and Papyrus to be able to pin down a cause.
> Ed
> On 01/10/2010 13:46, Laurent Goubet wrote:
>> Hi Ed,
>> Laurent Goubet
>> Obeo
>> Ed Willink wrote:
>>> Hi
>>> feature name less its leading character.
>>> Acceleo Editor or Builder being used; the error log suggests the Xtext
>>> builder has a problem too.
>>> Any suggestions?
>>> Regards
>>> Ed Willink
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
version:2.1
end:vcard
--------------000902050606070303040605--
FUDForum. Page generated in 0.02774 seconds
