Home » Archived » B3 » UnsupportedOperationException with 3 repositories
Re: UnsupportedOperationException with 3 repositories [message #632505 is a reply to message #632104] |
Wed, 13 October 2010 09:04 |
Filip Hrbek Messages: 233 Registered: July 2009 |
Hello Lars,
I have found & fixed the bug. However, we have problems setting up a hudson build for updating the site on the new Eclipse build server. Stay tuned, I hope we'll fix it within a few days.
Filip
On 11.10.2010 16:36, Lars Fischer wrote:
> Hello Filip,
> I apologize for asking again.
> On 01.10.2010 10:14, Lars Fischer wrote:
>>> Could you please enter a bugzilla issue and attach your b3aggr file so
>>> that both of us would work with exactly the same thing?
>>> In addition to this, let me know which version of b3 aggregator you are
>>> using. Thanks.
>> I filed a new issue at https://bugs.eclipse.org/bugs/show_bug.cgi?id=326742
> Is there something else, what I could provide to you?
> Lars
Re: UnsupportedOperationException with 3 repositories [message #640521 is a reply to message #640504] |
Mon, 22 November 2010 12:24 |
Yes, we are already able to build it. The latest build is supposed to be published later today to the 3.6 update site, and we will also modify the build for 3.7milestones (currently there is a new build but it is actually based on 3.6 and we want to change it to 3.7).
I'll let you know when it all gets stable (hopefully later today).
Filip
Dne 22.11.2010 12:25, Lars Fischer napsal(a):
>> No problem, I will watch this group.
> Are there any news about a new build?
> Lars
Re: UnsupportedOperationException with 3 repositories [message #641083 is a reply to message #640521] |
Wed, 24 November 2010 08:36 |
The new build for 3.6 is now available. Please try it out to see if it fixes your problem.
Filip
Dne 22.11.2010 13:24, Filip Hrbek napsal(a):
> Filip
>> Regards,
>> Lars
Re: UnsupportedOperationException with 3 repositories [message #641178 is a reply to message #641145] |
Wed, 24 November 2010 13:08 |
Hi Lars,
The new aggregator will install into a new untainted Eclipse 3.6.1. This only happens when an old aggregator was first
installed into your 3.6.1 since p2 considers the o.e.core.resources bundle has been updated due to the qualifier debacle.
Thomas Hallgren
On 2010-11-24 13:15, Filip Hrbek wrote:
> The aggregator build is set up to include proper version of org.eclipse.core.resources (3.6.0.R36x_v20100825-0600) which would normally be considered as older than 3.6.0.v20100526-0737 but in fact it is not (see bug 327234). This could be fixed by upgrading epp.package.rcp if it is already available with the dependency modified to the newer org.eclipse.core.resources bundle. I am afraid that I can't help more at the moment :-(
> Filip
> Dne 24.11.2010 11:10, Lars Fischer napsal(a):
>>> fixes your problem.
>> I was not able to install the new 3.6 build (0.1.0.r01408) from the
>> update site (http://download.eclipse.org/modeling/emft/b3/updates-3.6)
>> into my Eclipse 3.6.1:
>> Your original request has been modified.
>> "b3 Aggregator Editor (Incubation)" is already installed, so an update
>> will be performed instead.
>> Cannot complete the install because of a conflicting dependency.
>> Software being installed: b3 Aggregator Editor (Incubation)
>> 0.1.0.r01408 (org.eclipse.b3.aggregator.editor.feature.feature.group
>> 0.1.0.r01408)
>> Software currently installed: Eclipse for RCP and RAP Developers
>> 1.3.0.20100617-0521 (epp.package.rcp 1.3.0.20100617-0521)
>> Only one of the following can be installed at once:
>> Core Resource Management 3.6.0.v20100526-0737
>> (org.eclipse.core.resources 3.6.0.v20100526-0737)
>> Core Resource Management 3.6.0.R36x_v20100825-0600
>> (org.eclipse.core.resources 3.6.0.R36x_v20100825-0600)
>> Cannot satisfy dependency:
>> From: Eclipse for RCP and RAP Developers 1.3.0.20100617-0521
>> To: org.eclipse.epp.package.rcp.feature.feature.group
>> [1.3.0.20100617-0521]
>> From: b3 Aggregator Editor (Incubation) 0.1.0.r01408
>> (org.eclipse.b3.aggregator.editor.feature.feature.group 0.1.0.r01408)
>> To: org.eclipse.b3.aggregator.engine.feature.feature.group
>> [0.1.0.r01408]
>> From: b3 Aggregator Engine (Incubation) 0.1.0.r01408
>> (org.eclipse.b3.aggregator.engine.feature.feature.group 0.1.0.r01408)
>> To: org.eclipse.core.resources [3.6.0.R36x_v20100825-0600]
>> From: EPP RCP/RAP Feature 1.3.0.20100617-0521
>> (org.eclipse.epp.package.rcp.feature.feature.group 1.3.0.20100617-0521)
>> To: org.eclipse.platform.feature.group
>> [3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY]
>> From: Eclipse Platform
>> (org.eclipse.platform.feature.group
>> 3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY)
>> To: org.eclipse.core.resources [3.6.0.v20100526-0737]
>> Regards,
>> Lars
Current Time: Fri Apr 26 17:53:32 GMT 2024
Powered by FUDForum. Page generated in 0.04314 seconds
