Re: Newbe issues [message #630033 is a reply to message #629979] |
Thu, 30 September 2010 12:56 |
The page break interval is a property of the Table object.
Select your table (either in the Outline view or on the layout canvas by hovering at the lower left hand corner) then go to its Properties tab. You'll see a subtab for Page Break.
Re: Newbe issues [message #630195 is a reply to message #630194] |
Fri, 01 October 2010 01:40 |
Remember that Crystal is a page-oriented report package where BIRT is a web-oriented package. Crystal has a lot of logic (such as widow and orphan calculations) that is not (nor will it be) in BIRT.
That said, I assume there's a document somewhere describing the difference between Auto and Avoid. (Avoid means that the emitter - or web viewer - should attempt to avoid having a page break at the indicated position. Depending on the data rows and selected options, avoid cannot always be enforced.)
>> When I have a group with 20 lines, but there is space for 5
>> on one page I would like it to print the first 5 on that page
>> and the rest on the next page, rather than
>> putting all 20 on a new page.
That's how I would expect the report to behave, and I certainly have reports that work that way. If the Edit Group has page break set to Avoid, then you'd see BIRT trying to keep all 20 together.
FUDForum. Page generated in 0.04523 seconds
