Re: BIRT Viewer 2.5.1 ISSUE [message #630094 is a reply to message #629924] |
Thu, 30 September 2010 15:41 |
Helios contains BIRT 2.6. Can you download the 2.6 runtime and deploy
the viewer it contains to tomcat and give it a try?
Jason
On 9/29/2010 8:53 PM, JuanD wrote:
> I'm new in BIRT. I created a couple of reports running fine from ECLIPSE
> (Helios)
> When I try to run the same projects using BIRT VIEWER 2.5.1 on
> Apache/Tomcat 5.5.30 doesn`t work. I tested the BIRT VIEWER installation
> with the sample and runs fine. However, my own reports just display the
> popup window with the message "Processsing, please wait..." and never ends.
> I don't know what kind of logs to check or how to troubleshoot the
> issue. One of the reports is a simple list with 5 columns an less than
> 200 records.
> Thanks.
Re: BIRT Viewer 2.5.1 ISSUE [message #630122 is a reply to message #630109] |
Thu, 30 September 2010 16:43 |
Did you use the 2.6. or 2.6.1 runtime. I just tried the 2.6.1 runtime
with tomcat 5.5.20 with no issue. I have the same OS as you.
Jason
On 9/30/2010 12:25 PM, JuanD wrote:
> Hi Jason,
> Thank you very much for your answer.
> I tried with the version 2.6 of the runtime and I have the same symptom.
> Actually, it happens even with the test example.
> I don't know if my issue is related to my OS. I am using Windows 7- 64
> bits. Should I try a different Apache/Tomcat version?
> Thanks again.
> Juan Diego
Re: BIRT Viewer 2.5.1 ISSUE [message #630128 is a reply to message #630123] |
Thu, 30 September 2010 17:11 |
Are you getting anything in the \webapps\WebViewer\logs
directory?
I just tried tomcat 6.0.20 and had no issues.
Jason
On 9/30/2010 1:04 PM, JuanD wrote:
> I tried 2.6.1. Should I try Apache 5.5.20?
> Thanks a lot, again!
Re: BIRT Viewer 2.5.1 ISSUE [message #630144 is a reply to message #630130] |
Thu, 30 September 2010 18:40 |
Look in the catalina.bat file and edit the JAV_OPTS like below.
if not exist "%CATALINA_HOME%\bin\tomcat-juli.jar" goto noJuli
set JAVA_OPTS=%JAVA_OPTS% -XX:MaxPermSize=256m
:noJuli
Jason
On 9/30/2010 1:30 PM, JuanD wrote:
> The file ReportEngine_2010_09_30_13_27_30.log shows:
> 2010-09-30 13:29:23 org.eclipse.birt.report.engine.api.impl.RenderTask
> render
> GRAVE: There is insufficient memory to execute this report.
> It seems that this is the problem. How do I increase the available
> memory for BIRT?
> Thanks.
Re: BIRT Viewer 2.5.1 ISSUE [message #630318 is a reply to message #630281] |
Fri, 01 October 2010 14:59 |
There should be a tomcat5w.exe in the tomcat bin.
Run it and select the java tab and enter
in the Java Options box.
Jason
On 10/1/2010 8:15 AM, JuanD wrote:
> Hi Jason,
> I just looked at your last suggestion now. Unfortunately, I couldn't
> find the file catalilna.bat. Is it because my Apache is running as a
> service?
> Thanks.
> Juan Diego
Re: BIRT Viewer 2.5.1 ISSUE [message #630362 is a reply to message #630326] |
Fri, 01 October 2010 18:18 |
Juan,
It sounds like you do not have admin rights on the machine. You could
always download tomcat zip file instead of service and run the bat file
to start it up.
Jason
On 10/1/2010 11:26 AM, JuanD wrote:
> Hi Jason,
> Thanks. I found the .exe file but when I try to execute it I get "access
> denied" (or something like that, it is in French), "unable to open the
> service 'tomcat5'".
> I tried stopping the service or having it up and didn't work. I am
> suppose to be the Administrator for the machine.
> Sorry for bothering so much. I am a newby on Apache/Tomcat too.
> Thanks again.
> Juan Diego
FUDForum. Page generated in 0.06715 seconds
