Re: Adding source feature causes MissingComponentException in site.p2.zip action [message #630029 is a reply to message #630027] |
Thu, 30 September 2010 12:27 |
Please report this in a bugzilla. It's worth a lot if you can provide a
sample that reproduces the problem.
- thomas
On 09/30/2010 02:18 PM, Michael Wenz wrote:
> I did some more investigations on this and found a strange behavior in
> Buckminster: depending on the sequence of my feature includes the build
> succeeds or fails.
> We have two main features, let's call them feature and feature.examples. For
> both obviously source features exist: feature.source and examples.source.
> Besides there is our SDK feature consisting of all 4 features from above
> (convenience for downloading).
> If I now define the my site feature (the one that is being built using
> Buckminster's site.p2 action) in different sequences the build succeeds or
> fails:
> Success: SDK.feature, feature, feature.examples
> Failure: feature, feature.examples, SDK.feature
> Is this exspected behavior or a bug or does this somehow depend on any other
> configuration setting?
> -Michael
> "Michael Wenz"<michael.wenz@sap.com> wrote in message
> news:i7uu87$us5$1@news.eclipse.org...
>> Hi,
>> when I try to build my update site via the site.p2.zip action and have
>> added the source features that are produced by Buckminster automatically
>> to my SDK feature the build fails with:
>> ERROR: org.eclipse.buckminster.core.metadata.MissingComponentExcept ion: No
>> component named
>> org.eclipse.graphiti.feature.examples.source:eclipse.feature is known to
>> Buckminster
>> component named
>> Buckminster
>> at
>> org.eclipse.buckminster.core.metadata.WorkspaceInfo.resolveL ocal(WorkspaceInfo.java:624)
>> at
>> org.eclipse.buckminster.core.metadata.WorkspaceInfo.getResol ution(WorkspaceInfo.java:519)
>> at
>> org.eclipse.buckminster.core.metadata.ModelCache.findCSpec(M odelCache.java:46)
>> at
>> org.eclipse.buckminster.core.internal.actor.PerformContext.f indCSpec(PerformContext.java:219)
>> at
>> org.eclipse.buckminster.core.cspec.model.CSpec.getReferenced CSpec(CSpec.java:461)
>> at
>> org.eclipse.buckminster.core.cspec.model.CSpec.getReferenced Attribute(CSpec.java:439)
>> at
>> org.eclipse.buckminster.core.cspec.model.Prerequisite.getRef erencedAttribute(Prerequisite.java:142)
>> at
>> org.eclipse.buckminster.core.cspec.model.Group.internalGetPa thGroups(Group.java:205)
>> at
>> org.eclipse.buckminster.core.cspec.model.TopLevelAttribute.g etPathGroups(TopLevelAttribute.java:176)
>> at
>> org.eclipse.buckminster.core.internal.actor.PerformContext.a ddPrerequisitePathGroups(PerformContext.java:164)
>> at
>> org.eclipse.buckminster.core.internal.actor.PerformContext.g etNamedPathGroupArrays(PerformContext.java:276)
>> at
>> org.eclipse.buckminster.ant.actor.AntActor.internalPerform(A ntActor.java:238)
>> at
>> org.eclipse.buckminster.core.actor.AbstractActor.perform(Abs tractActor.java:186)
>> at
>> org.eclipse.buckminster.core.internal.actor.PerformManager$D irectActionInvocation.execute(PerformManager.java:143)
>> at
>> org.eclipse.buckminster.core.internal.actor.PerformManager.i nternalPerform(PerformManager.java:454)
>> at
>> org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:293)
>> at
>> org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:305)
>> at
>> org.eclipse.buckminster.core.commands.Perform.internalRun(Pe rform.java:108)
>> at
>> org.eclipse.buckminster.core.commands.WorkspaceCommand.run(W orkspaceCommand.java:91)
>> at
>> org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:194)
>> at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:3 17)
>> at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 36)
>> at org.eclipse.buckminster.cmdline.Headless.start(Headless.java :156)
>> at
>> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
>> at
>> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
>> at java.lang.reflect.Method.invoke(Method.java:597)
>> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
>> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
>> at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
>> at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
>> No component named
>> Buckminster
>> I have the follwing feature structure:
>> org.eclipse.graphiti.site -> org.eclipse.graphiti.feature
>> dk.feature -> org.eclipse.graphiti.feature
>> -> org.eclipse.graphiti.feature.examples
>> -> org.eclipse.graphiti.source.feature
>> -> org.eclipse.graphiti.feature.examples.source
>> When I check my Hudson workspace both source feature appear in the Hudson
>> build folder.
>> Here are the links to my build log:
>> With sources added it fails:
>> https://hudson.eclipse.org/hudson/job/gmp-graphiti-nightly/3 82/console
>> Without sources it runs through:
>> https://hudson.eclipse.org/hudson/job/gmp-graphiti-nightly/3 81/console
>> What am I missing?
>> Thanks,
>> Michael
Re: Adding source feature causes MissingComponentException in site.p2.zip action [message #630277 is a reply to message #630029] |
Fri, 01 October 2010 11:22 |
Michael Wenz Messages: 1931 Registered: July 2009 Location: Walldorf, Germany |
Done.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=326764
Michael
"Thomas Hallgren" <thomas@tada.se> wrote in message
news:i81vhv$ds3$1@news.eclipse.org...
> - thomas
>> succeeds or fails.
>> For
>> or
>> fails:
>> other
>> -Michael
>>> Hi,
>>> No
>>> component named
>>> Buckminster
>>> component named
>>> Buckminster
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> No component named
>>> Buckminster
>>> Hudson
>>> build folder.
>>> What am I missing?
>>> Thanks,
>>> Michael
FUDForum. Page generated in 0.03289 seconds
