Home » Modeling » EMF » [EMF] UnresolvedReferenceException on a ID reference with spaces in it.
[EMF] UnresolvedReferenceException on a ID reference with spaces in it. [message #629332] Mon, 27 September 2010 15:43 Go to next message
I didn't notice before, but it seems when the ID field is set on a
feature, the references to a class holding this feature, will be
absolute and serialize the reference with the feature value.
In my case the class Relationships has a reference (Element2Ref) to an
object named "Elephant Talk".
<Relationships Abstract="false" Element1Ref="#AMSHLR01"
Element2Ref="#Elephant Talk" MaxConnections="0" Name="_AAATEST"
Payload="Traffic" RequireConnection="false"/>
The fact that this name holds a space(is not encoded) leads to an
exception. Is there a way to make the reference relative? (Not sure of
the name of this, but it uses a reference to the index of the object in
the resource like this: "#//@elements.1" ). How do I control how
references are serialized?
Note that the referenced object in this case ("Elephant Talk") is
generated by QVTo, and, I should look for a way for QVTo to encode it
properly.
org.eclipse.emf.ecore.xmi.UnresolvedReferenceException: Unresolved
reference 'Elephant'.
(platform:/resource/NetXstudio/Imports/27092010_CS.netxstudi o, 326, 170)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHandler.java:1154)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:1228)
thanks Christophe
Re: [EMF] UnresolvedReferenceException on a ID reference with spaces in it. [message #629389 is a reply to message #629332] Tue, 28 September 2010 02:46 Go to previous messageGo to next message
Christophe,
Comments below.
Christophe Bouhier wrote:
Yes.
That could be problematic.
> of the name of this, but it uses a reference to the index of the
> object in the resource like this: "#//@elements.1" ).
By making the feature not be an ID.
> How do I control how references are serialized?
An alternative is to define an EDataType that wraps java.lang.String,
but encodes spaces (and characters like : and # that will also cause
confusion).
> properly.
> at
> at
> thanks Christophe
Re: [EMF] UnresolvedReferenceException on a ID reference with spaces in it. [message #629437 is a reply to message #629389] Tue, 28 September 2010 05:50 Go to previous message
Thanks Ed, I found a long thread on the topic in the forum with many
more details. I have removed the ID from the feature and this is ok for
now.
rgds Christophe
On 28-09-10 08:46, Ed Merks wrote:
> Christophe,
> Comments below.
> Yes.
> confusion).
>> properly.
>> at
>> at
>> thanks Christophe
Previous Topic:DragAndDropCommand
Next Topic:[CDO] How to close server ?
Current Time: Wed Nov 05 19:24:15 EST 2025
Powered by FUDForum. Page generated in 0.23828 seconds
