Re: Setting cache in BIRT [message #629285 is a reply to message #629226] |
Mon, 27 September 2010 15:54 |
The first option you have has been deprecated and is not needed. The
second two options have to do with design time caching and really should
not be used in runtime. Try using:
"org.eclipse.birt.data.query.ResultBufferSize"
This setting determines how much of the data is cached in memory before
writing to disk. It defaults to 10mb. Set it to an integer.
Jason
On 9/27/2010 10:08 AM, Gaurav Sahni wrote:
> Hi jason
> As you mentioned in another thread that how to set up the cache so i
> have used these following enteries for setting the cache
> task.getAppContext().put("org.eclipse.birt.data.engine.dataset.cache.option
> ", "Yes");
> task.getAppContext().put("org.eclipse.birt.data.cache.RowLimit ", new
> Integer(500));
> task.getAppContext().put("org.eclipse.birt.data.cache.memory ", new
> Integer(500));
> it also increased the performance little bit Please let me know is this
> the right way to use the caching in BIRT servlet
Re: Setting cache in BIRT [message #629792 is a reply to message #629561] |
Wed, 29 September 2010 14:53 |
The first two options have to do with saving the dataset in a cache,
which means if the data changes you will not get the updated data.
The last option if set to 100 should not write to disk cache unless the
100 mb is used.
I have not tried the following data engine setting, but it may be worth
a try:
task.getAppContext().put("org.eclipse.birt.data.memoryusage ","org.eclipse.birt.data.memoryusage.Aggressive");
Jason
On 9/28/2010 1:16 PM, Gaurav Sahni wrote:
> Hi jason
> as you mention the following two options should not be used runtime what
> does it mean and also it runs reports faster if i set these two parameter
> Integer(500));
> Integer(500));
> and while setting "org.eclipse.birt.data.query.ResultBufferSize"
> for 100 mb it does not show any performance improvements and aslo in log
> it say cache use 0 seconds something like that
> andl also if we use the birt viewer instaed of writing own servlet then
> how to set this cache in Birt Viewer
> Thanks for all replies
Re: Setting cache in BIRT [message #901689 is a reply to message #629285] |
Tue, 14 August 2012 07:44 |
Hello Jason,
I am using BIRT runtime to view reports. So when I use complex queries with huge data, I need a caching mechanism for repeated access. Can you suggest how to achieve this. I have tried putting in URL the following parameter __overwrite. But I am passing parameters within report. Is it possible to define for each report to use a 30MB or 50MB memory to use as cache? So that repeated processing can avoid.
Thanks in advance,
Sidharth
Re: Setting cache in BIRT [message #901871 is a reply to message #901689] |
Tue, 14 August 2012 20:54 |
BIRT by default caches datasets already. If you mean by multiple
sessions your can always save the rptdocument and re-render it. Just
use &__document=docname.rptdesign in the URL of the viewer.
Jason
On 8/14/2012 3:44 AM, sidharth mv wrote:
> Hello Jason,
> Thanks in advance,
> Sidharth
FUDForum. Page generated in 0.03022 seconds
