"Pseudo" Langage C [message #629121] |
Mon, 27 September 2010 09:43 |
DAVID Messages: 1 Registered: September 2010 |
I would like to implement the RTE langguege on Eclipse interface software and i would like to use Xtext.
It's possible to DEBUG the "C" langage with XTest and it is possible to inspect the "include" files defined on the Main code?
Best regards
Vincent
[Updated on: Mon, 27 September 2010 09:44] Report message to a moderator
Re: "Pseudo" Langage C [message #1388986 is a reply to message #629231] |
Fri, 27 June 2014 07:13 |
Mario Prieto Messages: 9 Registered: January 2013 |
Hi Vincent,
did you find a way of debugging the generated language?
I need something similar to what you described in your posting and don't find much information in the Xtext documentation about how to implement such a debugger.
I've seen that somehow I should enrich the generated files with line information and so on...but haven't found where I have to do it.
If anyone could give so some hints or directions I would be very grateful
Thanks and BR,
Mario.
[Updated on: Fri, 27 June 2014 07:37] Report message to a moderator
FUDForum. Page generated in 0.03537 seconds
