Re: BPEL files are not validated [message #629257 is a reply to message #628794] |
Mon, 27 September 2010 15:38 |
Hi Cristoph,
I think the issue is that the validator is not run unless one of the resources in the project are changed, even if you have "Project/Build Automatically" enabled - is this what you're seeing too? I'm also seeing that projects are not built (validated) automatically when the workbench is started regardless of whether Preferences/Startup/Refresh Workspace is checked, or Project/Build Automatically is checked.
Try opening a *.bpel resource, make an insignificant change maybe in the source view, and save it - you should see the validator being run by the eclipse builder framework (make sure you have "Project/Build Automatically" checked).
Can you please submit a bug to track this?
Thanks!
Bob
Re: BPEL files are not validated [message #630156 is a reply to message #630030] |
Thu, 30 September 2010 19:59 |
I get it now
You probably did not create the project using the "New BPEL Project" wizard, right? This adds the BPEL validator as a builder (which then calls the validator). Check your .project file to see if it has this:
<buildCommand>
<name>org.eclipse.bpel.validator.builder</name>
<arguments>
<dictionary>
<key>debug</key>
<value>false</value>
</dictionary>
</arguments>
</buildCommand>
If not, you can just add the "BPEL 2.0 Facet" and the "BPEL Validator (Builder)" to your project using the Project Properties wizard.
FUDForum. Page generated in 0.03074 seconds
