| Home » Archived » Buckminster » Buckminster cvs materializing, uses a proxy, how is this configured?
 Goto Forum:|
| Buckminster cvs materializing, uses a proxy, how is this configured? [message #628738] | Thu, 23 September 2010 17:02  |  |
| Eclipse User  |  |  |  |  | Hi, When building texo/teneo job on hudson.eclipse.org buckminster tries to connect to the cvs server (dev.eclipse.org)
 using a proxy server it seems.
 When I check the .settings/org.eclipse.core.net.prefs in the build workspace (created by buckminster) I can see this in
 the workspace settings:
 proxyData/HTTP/hasAuth=false
 proxyData/HTTP/host=proxy.eclipse.org
 org.eclipse.core.net.hasMigrated=true
 eclipse.preferences.version=1
 proxyData/HTTP/port=9898
 These settings are in this file:
 https://hudson.eclipse.org/hudson/job/emft-texo-nightly/ws/b uild/build/workspace/.metadata/.plugins/org.eclipse.core.run time/.settings/org.eclipse.core.net.prefs/*view*/
 Where do these proxy settings come from?
 Here is the bugzilla where Matt (Eclipse Webmaster) comments on this also:
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=325786
 gr. Martin
 [echo] Importing binaries into target platform
 /opt/users/hudsonbuild/.hudson/jobs/emft-texo-nightly/worksp ace/build/build/tp
 [java] com.jcraft.jsch.JSchException: ProxyHTTP: java.io.IOException:
 proxy error: Forbidden
 [java]     at com.jcraft.jsch.ProxyHTTP.connect(ProxyHTTP.java:158)
 [java]     at
 org.eclipse.jsch.internal.core.JSchProvider.connect(JSchProv ider.java:141)
 [java]     at
 org.eclipse.team.internal.ccvs.core.connection.PServerConnec tion.open(PServerConnection.java:116)
 [java]     at
 org.eclipse.team.internal.ccvs.core.connection.Connection.op en(Connection.java:132)
 [java]     at
 org.eclipse.team.internal.ccvs.core.connection.CVSRepository Location.createConnection(CVSRepositoryLocation.java:545)
 [java]     at
 org.eclipse.team.internal.ccvs.core.connection.CVSRepository Location.openConnection(CVSRepositoryLocation.java:806)
 [java]     at
 org.eclipse.team.internal.ccvs.core.client.Session.open(Sess ion.java:159)
 [java]     at
 org.eclipse.buckminster.cvspkg.internal.CVSSession.getReader Session(CVSSession.java:98)
 [java]     at
 org.eclipse.buckminster.cvspkg.internal.RepositoryMetaData.g etMetaData(RepositoryMetaData.java:76)
 [java]     at
 org.eclipse.buckminster.cvspkg.internal.VersionFinder.getMet aData(VersionFinder.java:97)
 [java]     at
 org.eclipse.buckminster.cvspkg.internal.VersionFinder.getTru nk(VersionFinder.java:86)
 [java]     at
 org.eclipse.buckminster.core.version.AbstractSCCSVersionFind er.getBestTrunkMatch(AbstractSCCSVersionFinder.java:320)
 [java]     at
 org.eclipse.buckminster.core.version.AbstractSCCSVersionFind er.getBestVersion(AbstractSCCSVersionFinder.java:151)
 [java]     at
 org.eclipse.buckminster.core.rmap.model.Provider.findMatch(P rovider.java:220)
 [java]     at
 org.eclipse.buckminster.core.rmap.model.SearchPath.getProvid er(SearchPath.java:100)
 [java]     at
 org.eclipse.buckminster.core.rmap.model.ResourceMap.resolve( ResourceMap.java:293)
 [java]     at
 org.eclipse.buckminster.core.rmap.model.ResourceMap.resolve( ResourceMap.java:212)
 [java]     at
 org.eclipse.buckminster.core.resolver.ResourceMapResolver.in nerResolve(ResourceMapResolver.java:202)
 [java]     at
 org.eclipse.buckminster.core.resolver.ResolverNodeWithJob.re solve(ResolverNodeWithJob.java:190)
 [java]     at
 org.eclipse.buckminster.core.resolver.ResolverNodeWithJob.ru n(ResolverNodeWithJob.java:87)
 [java]     at
 org.eclipse.buckminster.core.resolver.ResolverNodeWithJob$No deResolutionJob.run(ResolverNodeWithJob.java:44)
 [java]     at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
 [java] Caused by: java.io.IOException: proxy error: Forbidden
 [java]     at com.jcraft.jsch.ProxyHTTP.connect(ProxyHTTP.java:122)
 [java]     ... 21 more
 With Regards, Martin Taal
 Springsite/Elver.org
 The Netherlands
 Cell: +31 (0)6 288 48 943
 Tel: +31 (0)84 420 2397
 Fax: +31 (0)84 225 9307
| Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #629308 is a reply to message #629303] | Mon, 27 September 2010 14:16   |  |
| Eclipse User  |  |  |  |  | Yes, I am also surprised. Afaics I don't use a workspace template (how is this specified in buckminster?).
 I launch buckminster like this:
 <macrodef name="buckminster">
 <attribute name="command" />
 <attribute name="workspace" />
 <element name="globargs" optional="true" />
 <element name="cmdargs" optional="true" />
 <sequential>
 <eclipse.launch app="buckminster">
 <args>
 <jvmarg value="-Xmx1024m" />
 <jvmarg value="-Dbugfix.288796=true" />
 <arg value="-data" />
 <arg value="@{workspace}" />
 <arg value="--loglevel" />
 <arg value="${buckminster.loglevel}" />
 <arg value="--displaystacktrace" />
 <arg value="@{command}" />
 <globargs />
 <arg value="-P" />
 <arg value="${properties.tmp}" />
 <cmdargs />
 </args>
 </eclipse.launch>
 </sequential>
 </macrodef>
 After creating the workspace directory, one of the first things I do is this:
 <echo message="Setting jre to ${env.JAVA_HOME}"/>
 <buckminster command="installJRE" workspace="${workspacePath}">
 <cmdargs>
 <arg value="--location" />
 <arg value="${env.JAVA_HOME}" />
 </cmdargs>
 </buckminster>
 so I don't understand either where this proxy thing comes from...
 gr. Martin
 On 09/27/2010 07:16 PM, Thomas Hallgren wrote:
 > On 09/23/2010 11:02 PM, Martin Taal wrote:
 >> connect to the cvs server (dev.eclipse.org) using a proxy server it
 >> seems.
 >> workspace (created by buckminster) I can see this in the workspace
 >> settings:
 > I'm puzzled. I haven't seen this before. AFAIK, Buckminster has no code
 > that fiddles with proxy settings and I cannot find any preference
 > settings for org.eclipse.core.net in any of my workspaces. Are you using
 > a workspace template?
 > - thomas
 The Netherlands
| Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #629505 is a reply to message #629330] | Tue, 28 September 2010 09:27   |  |
| Eclipse User  |  |  |  |  | Hi Henrik, This is a build run on hudson.eclipse.org, afaics I am not reusing an earlier workspace.
 The strange thing is when I do the build locally it does not contain this setting. The local build is the same as the
 hudson build afaics....
 Is there something in buckminster which makes it run differently when run on hudson.eclipse.org?
 gr. Martin
 > Other ways for these preferences to end up in the workspace could be:
 > - If reusing a workspace that was used earlier with the IDE
 > - Something is installed in headless buckminster that sets or modifies
 > the proxy preferences.
 > Do you see the preferences with a "vanilla" buckminster and a freshly
 > created workspace?
 > - henrik
 The Netherlands
| Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #629542 is a reply to message #629541] | Tue, 28 September 2010 11:59   |  |
| Eclipse User  |  |  |  |  | Hi Thomas, Yes this auto proxy setting maybe the cause, see an old post from a year back, you answered it :-)
 http://dev.eclipse.org/mhonarc/lists/p2-dev/msg01955.html
 I will research it further.
 gr. Martin
 On 09/28/2010 05:48 PM, Thomas Hallgren wrote:
 > What I could suspect is that the Eclipse proxy support
 The Netherlands
| Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #630405 is a reply to message #629542] | Fri, 01 October 2010 18:30  |  |
| Eclipse User  |  |  |  |  | This was solved!
 To finish this thread. Michael Wenz pointed me to a change made in the cdo build (to solve this issue), a snippet from
 his email to me:
 But I saw that the CDO build is green again and they still do an Ant call from Hudson that again triggers Buckminster.
 Previously that build failed with the same exception as ours did or do.
 Not sure what these guys changed, but I saw that they added something in their build.xml that seems to fix this. I found
 2 snippets that appear to be in connection with this:
 <condition property="no.proxy" value="${env.no_proxy}, dev.eclipse.org" else="dev.eclipse.org">
 <isset property="env.no_proxy" />
 </condition>
 <!-- Launch the eclipse application -->
 <java fork="true" jar="${@{app}.launcher}" dir="${@{app}.deploy.dir}" failonerror="true">
 <env key="no_proxy" value="${no.proxy}" />
 <properties />
 <!-- Uncomment to debug <jvmarg value=" -agentlib:jdwp=transport=dt_socket,address=8000,server=y,sus pend=y "/> -->
 <args />
 </java>
 gr. Martin
 On 09/28/2010 05:59 PM, Martin Taal wrote:
 > Hi Thomas,
 > gr. Martin
 The Netherlands
 Current Time: Fri Oct 31 06:14:13 EDT 2025
 Powered by FUDForum . Page generated in 0.03987 seconds |
