Re: Applying Stereotypes programatically returns IllegalArgumentException [message #628155 is a reply to message #628153] |
Tue, 05 January 2010 15:40 |
Stefan Messages: 13 Registered: October 2009 |
I am working on an standalone application, in an plugin environment all works well. For Example when i skip the programatical Stereotype application and open the generated Model in the Eclipse UML Model Editor i can apply the stereotype without any additional work.
Here is my standalone setup:
final String UML2_200_NS_URI = "http://www.eclipse.org/uml2/2.0.0/UML";
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(UMLPackage.eCONTENT_TYP E, UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(UMLPackage.eNAME, UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(UMLPackage.eNS_PREFIX, UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
EPackage.Registry.INSTANCE.put(UML2_200_NS_URI,EPackage.Regi stry.INSTANCE.get(UMLPackage.eINSTANCE.getNsURI()));
Ecore2XMLPackage.eINSTANCE.getEClassifiers();
Map uriMap = resourceSet.getURIConverter().getURIMap();
URI uri = URI.createURI(" jar:file:/C:/eclipse/plugins/org.eclipse.uml2.uml.resources_ 3.0.0.v200906011111.jar!/ ");
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
And here is the Profile:
<uml:Profile xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML" xmi:id="_sgoFIPRsEd6r3-nGxzDfug" name="Annotation" metaclassReference="_DGU0wPRvEd6-do6LdBmvGQ _DGU0wfRvEd6-do6LdBmvGQ _DGU0wvRvEd6-do6LdBmvGQ">
<eAnnotations xmi:id="_mtIVIPRvEd6-do6LdBmvGQ" source="http://www.eclipse.org/uml2/2.0.0/UML">
<contents xmi:type="ecore:EPackage" xmi:id="_SWYikfoOEd6sgcJOqXKzHA" name="Annotation" nsURI="http:///schemas/Annotation/_SWYikPoOEd6sgcJOqXKzHA/7" nsPrefix="Annotation">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_SWYikvoOEd6sgcJOqXKzHA" name="_winter">
<eAnnotations xmi:id="_SWYik_oOEd6sgcJOqXKzHA" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_M1n2gPRtEd6-do6LdBmvGQ"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_SWYilPoOEd6sgcJOqXKzHA" name="query" ordered="false" lowerBound="1">
<eType xmi:type="ecore:EDataType" href="http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eStructuralFeatures>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_SWYilvoOEd6sgcJOqXKzHA" name="var" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_SWYimPoOEd6sgcJOqXKzHA" name="src" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_SWYimvoOEd6sgcJOqXKzHA" name="dst" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_SWYinPoOEd6sgcJOqXKzHA" name="type" ordered="false" lowerBound="1" eType="_SWYipPoOEd6sgcJOqXKzHA"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_SWYinvoOEd6sgcJOqXKzHA" name="base_Class" ordered="false" lowerBound="1">
<eType xmi:type="ecore:EClass" href="http://www.eclipse.org/uml2/3.0.0/UML#//Class"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_SWYioPoOEd6sgcJOqXKzHA" name="base_Interface" ordered="false" lowerBound="1">
<eType xmi:type="ecore:EClass" href="http://www.eclipse.org/uml2/3.0.0/UML#//Interface"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_SWYiovoOEd6sgcJOqXKzHA" name="base_Property" ordered="false" lowerBound="1">
<eType xmi:type="ecore:EClass" href="http://www.eclipse.org/uml2/3.0.0/UML#//Property"/>
</eClassifiers>
<eClassifiers xmi:type="ecore:EEnum" xmi:id="_SWYipPoOEd6sgcJOqXKzHA" name="Type">
<eAnnotations xmi:id="_SWYipfoOEd6sgcJOqXKzHA" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_RR70UPRuEd6-do6LdBmvGQ"/>
<eLiterals xmi:id="_SWYipvoOEd6sgcJOqXKzHA" name="PATTERN"/>
<eLiterals xmi:id="_SWYip_oOEd6sgcJOqXKzHA" name="MAPPING" value="1"/>
<eLiterals xmi:id="_SWYiqPoOEd6sgcJOqXKzHA" name="EXTERNALOBJECT" value="2"/>
<eLiterals xmi:id="_SWYiqfoOEd6sgcJOqXKzHA" name="INTERNALOBJECT" value="3"/>
<eLiterals xmi:id="_SWYiqvoOEd6sgcJOqXKzHA" name="LITERAL" value="4"/>
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_vxPTgPoNEd6sgcJOqXKzHA" name="Annotation" nsURI="http:///schemas/Annotation/_vxOscPoNEd6sgcJOqXKzHA/6" nsPrefix="Annotation">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_vxPTgfoNEd6sgcJOqXKzHA" name="_winter">
<eAnnotations xmi:id="_vxPTgvoNEd6sgcJOqXKzHA" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_M1n2gPRtEd6-do6LdBmvGQ"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_vxPTg_oNEd6sgcJOqXKzHA" name="query" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_vxPThfoNEd6sgcJOqXKzHA" name="var" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_vxPTh_oNEd6sgcJOqXKzHA" name="src" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_vxPTifoNEd6sgcJOqXKzHA" name="dst" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_vxPTi_oNEd6sgcJOqXKzHA" name="type" ordered="false" lowerBound="1" eType="_vxPTkvoNEd6sgcJOqXKzHA"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_vxPTjfoNEd6sgcJOqXKzHA" name="base_Class" ordered="false" lowerBound="1"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_vxPTjvoNEd6sgcJOqXKzHA" name="base_Interface" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_vxPTkPoNEd6sgcJOqXKzHA" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EEnum" xmi:id="_vxPTkvoNEd6sgcJOqXKzHA" name="Type">
<eAnnotations xmi:id="_vxPTk_oNEd6sgcJOqXKzHA" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_RR70UPRuEd6-do6LdBmvGQ"/>
<eLiterals xmi:id="_vxPTlPoNEd6sgcJOqXKzHA" name="PATTERN"/>
<eLiterals xmi:id="_vxPTlfoNEd6sgcJOqXKzHA" name="MAPPING" value="1"/>
<eLiterals xmi:id="_vxPTlvoNEd6sgcJOqXKzHA" name="EXTERNALOBJECT" value="2"/>
<eLiterals xmi:id="_vxPTl_oNEd6sgcJOqXKzHA" name="INTERNALOBJECT" value="3"/>
<eLiterals xmi:id="_vxPTmPoNEd6sgcJOqXKzHA" name="LITERAL" value="4"/>
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_XH8CgPoNEd6sgcJOqXKzHA" name="Annotation" nsURI="http:///schemas/Annotation/_XH6NUPoNEd6sgcJOqXKzHA/5" nsPrefix="Annotation">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_XH8CgfoNEd6sgcJOqXKzHA" name="_winter">
<eAnnotations xmi:id="_XH8CgvoNEd6sgcJOqXKzHA" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_M1n2gPRtEd6-do6LdBmvGQ"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_XH8Cg_oNEd6sgcJOqXKzHA" name="query" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_XH8ChfoNEd6sgcJOqXKzHA" name="var" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_XH8Ch_oNEd6sgcJOqXKzHA" name="src" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_XH8CifoNEd6sgcJOqXKzHA" name="dst" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_XH8Ci_oNEd6sgcJOqXKzHA" name="type" ordered="false" lowerBound="1" eType="_XH8CkvoNEd6sgcJOqXKzHA"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_XH8CjfoNEd6sgcJOqXKzHA" name="base_Class" ordered="false" lowerBound="1"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_XH8CjvoNEd6sgcJOqXKzHA" name="base_Interface" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_XH8CkPoNEd6sgcJOqXKzHA" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EEnum" xmi:id="_XH8CkvoNEd6sgcJOqXKzHA" name="Type">
<eAnnotations xmi:id="_XH8Ck_oNEd6sgcJOqXKzHA" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_RR70UPRuEd6-do6LdBmvGQ"/>
<eLiterals xmi:id="_XH8pkPoNEd6sgcJOqXKzHA" name="PATTERN"/>
<eLiterals xmi:id="_XH8pkfoNEd6sgcJOqXKzHA" name="MAPPING" value="1"/>
<eLiterals xmi:id="_XH8pkvoNEd6sgcJOqXKzHA" name="EXTERNALOBJECT" value="2"/>
<eLiterals xmi:id="_XH8pk_oNEd6sgcJOqXKzHA" name="INTERNALOBJECT" value="3"/>
<eLiterals xmi:id="_XH8plPoNEd6sgcJOqXKzHA" name="LITERAL" value="4"/>
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_BO1_0fl_Ed6c3LQ2uro9sg" name="Annotation" nsURI="http:///schemas/Annotation/_BO1_0Pl_Ed6c3LQ2uro9sg/4" nsPrefix="Annotation">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_BO1_0vl_Ed6c3LQ2uro9sg" name="_winter">
<eAnnotations xmi:id="_BO1_0_l_Ed6c3LQ2uro9sg" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_M1n2gPRtEd6-do6LdBmvGQ"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_BO1_1Pl_Ed6c3LQ2uro9sg" name="query" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_BO1_1vl_Ed6c3LQ2uro9sg" name="var" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_BO1_2Pl_Ed6c3LQ2uro9sg" name="src" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_BO1_2vl_Ed6c3LQ2uro9sg" name="dst" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_BO1_3Pl_Ed6c3LQ2uro9sg" name="type" ordered="false" lowerBound="1" eType="_BO2m4vl_Ed6c3LQ2uro9sg"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_BO1_3vl_Ed6c3LQ2uro9sg" name="base_Class" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_BO1_4Pl_Ed6c3LQ2uro9sg" name="base_Interface" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_BO2m4Pl_Ed6c3LQ2uro9sg" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EEnum" xmi:id="_BO2m4vl_Ed6c3LQ2uro9sg" name="Type">
<eAnnotations xmi:id="_BO2m4_l_Ed6c3LQ2uro9sg" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_RR70UPRuEd6-do6LdBmvGQ"/>
<eLiterals xmi:id="_BO2m5Pl_Ed6c3LQ2uro9sg" name="PATTERN"/>
<eLiterals xmi:id="_BO2m5fl_Ed6c3LQ2uro9sg" name="MAPPING" value="1"/>
<eLiterals xmi:id="_BO2m5vl_Ed6c3LQ2uro9sg" name="EXTERNALOBJECT" value="2"/>
<eLiterals xmi:id="_BO2m5_l_Ed6c3LQ2uro9sg" name="INTERNALOBJECT" value="3"/>
<eLiterals xmi:id="_BO2m6Pl_Ed6c3LQ2uro9sg" name="LITERAL" value="4"/>
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_tdUykfl9Ed6c3LQ2uro9sg" name="Annotation" nsURI="http:///schemas/Annotation/_tdUykPl9Ed6c3LQ2uro9sg/3" nsPrefix="Annotation">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_tdUykvl9Ed6c3LQ2uro9sg" name="_winter">
<eAnnotations xmi:id="_tdUyk_l9Ed6c3LQ2uro9sg" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_M1n2gPRtEd6-do6LdBmvGQ"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_tdUylPl9Ed6c3LQ2uro9sg" name="query" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_tdUylvl9Ed6c3LQ2uro9sg" name="var" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_tdUymPl9Ed6c3LQ2uro9sg" name="src" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_tdUymvl9Ed6c3LQ2uro9sg" name="dst" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_tdUynPl9Ed6c3LQ2uro9sg" name="type" ordered="false" lowerBound="1" eType="_tdUypPl9Ed6c3LQ2uro9sg"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_tdUynvl9Ed6c3LQ2uro9sg" name="base_Class" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_tdUyoPl9Ed6c3LQ2uro9sg" name="base_Interface" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_tdUyovl9Ed6c3LQ2uro9sg" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EEnum" xmi:id="_tdUypPl9Ed6c3LQ2uro9sg" name="Type">
<eAnnotations xmi:id="_tdUypfl9Ed6c3LQ2uro9sg" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_RR70UPRuEd6-do6LdBmvGQ"/>
<eLiterals xmi:id="_tdUypvl9Ed6c3LQ2uro9sg" name="PATTERN"/>
<eLiterals xmi:id="_tdUyp_l9Ed6c3LQ2uro9sg" name="MAPPING" value="1"/>
<eLiterals xmi:id="_tdUyqPl9Ed6c3LQ2uro9sg" name="EXTERNALOBJECT" value="2"/>
<eLiterals xmi:id="_tdUyqfl9Ed6c3LQ2uro9sg" name="INTERNALOBJECT" value="3"/>
<eLiterals xmi:id="_tdUyqvl9Ed6c3LQ2uro9sg" name="LITERAL" value="4"/>
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_rs1zwfl6Ed6c3LQ2uro9sg" name="Annotation" nsURI="http:///schemas/Annotation/_rs1zwPl6Ed6c3LQ2uro9sg/2" nsPrefix="Annotation">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_rs1zwvl6Ed6c3LQ2uro9sg" name="_winter">
<eAnnotations xmi:id="_rs1zw_l6Ed6c3LQ2uro9sg" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_M1n2gPRtEd6-do6LdBmvGQ"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_rs1zxPl6Ed6c3LQ2uro9sg" name="query" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_rs1zxvl6Ed6c3LQ2uro9sg" name="var" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_rs1zyPl6Ed6c3LQ2uro9sg" name="src" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_rs1zyvl6Ed6c3LQ2uro9sg" name="dst" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_rs1zzPl6Ed6c3LQ2uro9sg" name="type" ordered="false" lowerBound="1" eType="_rs1z1Pl6Ed6c3LQ2uro9sg"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_rs1zzvl6Ed6c3LQ2uro9sg" name="base_Class" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_rs1z0Pl6Ed6c3LQ2uro9sg" name="base_Interface" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_rs1z0vl6Ed6c3LQ2uro9sg" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EEnum" xmi:id="_rs1z1Pl6Ed6c3LQ2uro9sg" name="Type">
<eAnnotations xmi:id="_rs1z1fl6Ed6c3LQ2uro9sg" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_RR70UPRuEd6-do6LdBmvGQ"/>
<eLiterals xmi:id="_rs1z1vl6Ed6c3LQ2uro9sg" name="PATTERN"/>
<eLiterals xmi:id="_rs1z1_l6Ed6c3LQ2uro9sg" name="MAPPING" value="1"/>
<eLiterals xmi:id="_rs1z2Pl6Ed6c3LQ2uro9sg" name="EXTERNALOBJECT" value="2"/>
<eLiterals xmi:id="_rs1z2fl6Ed6c3LQ2uro9sg" name="INTERNALOBJECT" value="3"/>
<eLiterals xmi:id="_rs1z2vl6Ed6c3LQ2uro9sg" name="LITERAL" value="4"/>
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_GtJqUPl5Ed6c3LQ2uro9sg" name="Annotation" nsURI="http:///schemas/Annotation/_GtHOEPl5Ed6c3LQ2uro9sg/1" nsPrefix="Annotation">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_GtJqUfl5Ed6c3LQ2uro9sg" name="_winter">
<eAnnotations xmi:id="_GtJqUvl5Ed6c3LQ2uro9sg" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_M1n2gPRtEd6-do6LdBmvGQ"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_GtJqU_l5Ed6c3LQ2uro9sg" name="query" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_GtJqVfl5Ed6c3LQ2uro9sg" name="var" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_GtJqV_l5Ed6c3LQ2uro9sg" name="src" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_GtJqWfl5Ed6c3LQ2uro9sg" name="dst" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_GtJqW_l5Ed6c3LQ2uro9sg" name="type" ordered="false" lowerBound="1" eType="_GtJqY_l5Ed6c3LQ2uro9sg"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_GtJqXfl5Ed6c3LQ2uro9sg" name="base_Class" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_GtJqX_l5Ed6c3LQ2uro9sg" name="base_Interface" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_GtJqYfl5Ed6c3LQ2uro9sg" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EEnum" xmi:id="_GtJqY_l5Ed6c3LQ2uro9sg" name="Type">
<eAnnotations xmi:id="_GtJqZPl5Ed6c3LQ2uro9sg" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_RR70UPRuEd6-do6LdBmvGQ"/>
<eLiterals xmi:id="_GtJqZfl5Ed6c3LQ2uro9sg" name="PATTERN"/>
<eLiterals xmi:id="_GtJqZvl5Ed6c3LQ2uro9sg" name="MAPPING" value="1"/>
<eLiterals xmi:id="_GtJqZ_l5Ed6c3LQ2uro9sg" name="EXTERNALOBJECT" value="2"/>
<eLiterals xmi:id="_GtJqaPl5Ed6c3LQ2uro9sg" name="INTERNALOBJECT" value="3"/>
<eLiterals xmi:id="_GtJqafl5Ed6c3LQ2uro9sg" name="LITERAL" value="4"/>
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_mtI8MPRvEd6-do6LdBmvGQ" name="Annotation" nsURI="http:///schemas/Annotation/_mtEqwPRvEd6-do6LdBmvGQ/0" nsPrefix="Annotation">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_mtI8MfRvEd6-do6LdBmvGQ" name="_winter">
<eAnnotations xmi:id="_mtI8MvRvEd6-do6LdBmvGQ" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_M1n2gPRtEd6-do6LdBmvGQ"/>
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_mtI8M_RvEd6-do6LdBmvGQ" name="query" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_mtI8NfRvEd6-do6LdBmvGQ" name="var" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_mtI8N_RvEd6-do6LdBmvGQ" name="src" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_mtI8OfRvEd6-do6LdBmvGQ" name="dst" ordered="false" upperBound="-1">
<eStructuralFeatures xmi:type="ecore:EAttribute" xmi:id="_mtI8O_RvEd6-do6LdBmvGQ" name="type" ordered="false" lowerBound="1" eType="_mtI8Q_RvEd6-do6LdBmvGQ"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_mtI8PfRvEd6-do6LdBmvGQ" name="base_Class" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_mtI8P_RvEd6-do6LdBmvGQ" name="base_Interface" ordered="false" lowerBound="1">
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_mtI8QfRvEd6-do6LdBmvGQ" name="base_Property" ordered="false" lowerBound="1">
</eClassifiers>
<eClassifiers xmi:type="ecore:EEnum" xmi:id="_mtI8Q_RvEd6-do6LdBmvGQ" name="Type">
<eAnnotations xmi:id="_mtI8RPRvEd6-do6LdBmvGQ" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_RR70UPRuEd6-do6LdBmvGQ"/>
<eLiterals xmi:id="_mtI8RfRvEd6-do6LdBmvGQ" name="PATTERN"/>
<eLiterals xmi:id="_mtI8RvRvEd6-do6LdBmvGQ" name="MAPPING" value="1"/>
<eLiterals xmi:id="_mtI8R_RvEd6-do6LdBmvGQ" name="EXTERNALOBJECT" value="2"/>
<eLiterals xmi:id="_mtI8SPRvEd6-do6LdBmvGQ" name="INTERNALOBJECT" value="3"/>
<eLiterals xmi:id="_mtI8SfRvEd6-do6LdBmvGQ" name="LITERAL" value="4"/>
</eClassifiers>
</contents>
</eAnnotations>
<elementImport xmi:id="_DGU0wPRvEd6-do6LdBmvGQ">
<importedElement xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Class"/>
</elementImport>
<elementImport xmi:id="_DGU0wfRvEd6-do6LdBmvGQ">
<importedElement xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Interface"/>
</elementImport>
<elementImport xmi:id="_DGU0wvRvEd6-do6LdBmvGQ">
<importedElement xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Property"/>
</elementImport>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_M1n2gPRtEd6-do6LdBmvGQ" name="@winter">
<ownedAttribute xmi:id="_Q2qqEPRtEd6-do6LdBmvGQ" name="query">
<type xmi:type="uml:PrimitiveType" href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
</ownedAttribute>
<ownedAttribute xmi:id="_SoU08PRtEd6-do6LdBmvGQ" name="var">
</ownedAttribute>
<ownedAttribute xmi:id="_TnM4APRtEd6-do6LdBmvGQ" name="src">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_p3r3gPRtEd6-do6LdBmvGQ" value="*"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_pJps0PRtEd6-do6LdBmvGQ"/>
</ownedAttribute>
<ownedAttribute xmi:id="_UkXq4PRtEd6-do6LdBmvGQ" name="dst">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_sUFogPRtEd6-do6LdBmvGQ" value="*"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_rhj_YPRtEd6-do6LdBmvGQ"/>
</ownedAttribute>
<ownedAttribute xmi:id="_Vd568PRtEd6-do6LdBmvGQ" name="type" type="_RR70UPRuEd6-do6LdBmvGQ"/>
<ownedAttribute xmi:id="_RmSeQfRvEd6-do6LdBmvGQ" name="base_Class" association="_RmR3MPRvEd6-do6LdBmvGQ">
<type xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Class"/>
</ownedAttribute>
<ownedAttribute xmi:id="_RmSeRPRvEd6-do6LdBmvGQ" name="base_Interface" association="_RmR3MPRvEd6-do6LdBmvGQ">
<type xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Interface"/>
</ownedAttribute>
<ownedAttribute xmi:id="_RmTFUfRvEd6-do6LdBmvGQ" name="base_Property" association="_RmR3MPRvEd6-do6LdBmvGQ">
<type xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Property"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Enumeration" xmi:id="_RR70UPRuEd6-do6LdBmvGQ" name="Type">
<ownedLiteral xmi:id="_TXRJIPRuEd6-do6LdBmvGQ" name="PATTERN"/>
<ownedLiteral xmi:id="_US8HMPRuEd6-do6LdBmvGQ" name="MAPPING"/>
<ownedLiteral xmi:id="_U_jVkPRuEd6-do6LdBmvGQ" name="EXTERNALOBJECT"/>
<ownedLiteral xmi:id="_VwXugPRuEd6-do6LdBmvGQ" name="INTERNALOBJECT"/>
<ownedLiteral xmi:id="_WY8xcPRuEd6-do6LdBmvGQ" name="LITERAL"/>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_RmR3MPRvEd6-do6LdBmvGQ" name="Extension_@winter" memberEnd="_RmSeQPRvEd6-do6LdBmvGQ _RmSeQfRvEd6-do6LdBmvGQ _RmSeRPRvEd6-do6LdBmvGQ _RmTFUfRvEd6-do6LdBmvGQ">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_RmSeQPRvEd6-do6LdBmvGQ" name="extension_@winter" type="_M1n2gPRtEd6-do6LdBmvGQ" association="_RmR3MPRvEd6-do6LdBmvGQ"/>
</packagedElement>
</uml:Profile>
Thx for your work, hope you could help.
Stefan
FUDForum. Page generated in 0.04400 seconds
