EvaluationException : Couldn't resolve type for 'Persistence::Entity'. Did you f [message #627853] |
Thu, 06 August 2009 12:29 |
Originally posted by: karunyap.infotechsw.com
I am a newbie to both UML2 and OAW 4.3.1 and need some help and guidance
on the following issue.
I have to use UML2/EMF API to programatically create a UML model and use
the Fornax hibernate cartridge to generate Entity classes.
I was sucessful in generating classes with the JavaBasic cartridge but
with the Hibernate cartridge I end up with the below issue.
you forget to configure the corresponding metamodel?
org::fornax::cartridges::uml2::hibernate::extensions::Naming .ext[1091,196]
on line 30 'String getFQNPackageName(Persistence::Entity this)'
I have performed the following steps.
1) Registered and loaded the default profiles that come bundled with UML2.
2) Loaded the hibernate [persistence.profile.uml] profile and applied it
onto a UML model object.
3) Programatically verified that the profile got loaded and the stereotype
[Persistence:Entity] was available.
4) Programatically created a java-class using UML2 API and applied the
Entity stereotype.
5) Invoked fornax hibernate template [feature_pojo] to run on the created
model.
public static void generateEntities(){
//create a package add the package to the model
Package pkg = umlFacade.createPackage();
org.eclipse.uml2.uml.Model umlModel = umlFacade.createModel();
umlModel.getPackagedElements().add(pkg);
pkg.setName("com.prefabware");
//Use some thing else instead of EcoreUtil2
URI persistenceURI =
EcoreUtil2.getURI("profiles/Persistence.profile.uml");
persistenceProfile = umlFacade.loadProfile(persistenceURI);
try{
// apply the profile to the main package
pkg.applyProfile(persistenceProfile);
umlModel.applyProfile(persistenceProfile);
//get stereotype of Entity
Stereotype stereotype = persistenceProfile.getOwnedStereotype("Entity");
//create a class
Class cls1 = umlFacade.createClass();
// add class to the pkg
pkg.getPackagedElements().add(cls1);
cls1.setName("StereoTypeTestwithPersistenceprofile");
// apply the stereotype to the baseclass
cls1.applyStereotype(stereotype);
umlModel.getPackagedElements().add(cls1);
catch (Exception e){
e.printStackTrace();
//Some more code to use the XPand runner to load and run the hibernate
template [feature_pojo.xpt]
//this.getTemplate("org::fornax::cartridges::uml2::hibernate::templates::feature_pojo").evaluate("Root",
model, null);
//Now run this template.
//Code fails at the evaluation time with the following stack trace
Did you forget to configure the corresponding metamodel?
org::fornax::cartridges::uml2::hibernate::extensions::Naming.ext[1091,196]
org.openarchitectureware.xtend.ast.AbstractExtension.init(AbstractExtension.java:226)
org.openarchitectureware.xtend.ast.ExtensionFile.getPublicExtensions(ExtensionFile.java:186)
org.openarchitectureware.xtend.ast.ExtensionFile.getPublicExtensions(ExtensionFile.java:165)
org.openarchitectureware.expression.ExecutionContextImpl.getAllExtensions(ExecutionContextImpl.java:302)
org.openarchitectureware.expression.ExecutionContextImpl.getExtensionForTypes(ExecutionContextImpl.java:315)
org.openarchitectureware.expression.ExecutionContextImpl.getExtension(ExecutionContextImpl.java:323)
org.openarchitectureware.expression.ast.OperationCall.evaluateInternal(OperationCall.java:75)
org.openarchitectureware.expression.ast.Expression.evaluate(Expression.java:51)
org.openarchitectureware.xpand2.ast.ExpressionStatement.evaluateInternal(ExpressionStatement.java:48)
org.openarchitectureware.xpand2.ast.Statement.evaluate(Statement.java:42)
org.openarchitectureware.xpand2.ast.AbstractDefinition.evaluate(AbstractDefinition.java:178)
org.openarchitectureware.xpand2.XpandFacade.evaluate(XpandFacade.java:63)
com.prefabware.genlets.commons.XpandRunner.evaluate(XpandRunner.java:41)
com.prefabware.genlets.java.intern.FornaxXpandFacade.feature_pojo(FornaxXpandFacade.java:50)
com.prefabware.genlets.java.GenletJavaImpl.generateUsingFornaxHB(GenletJavaImpl.java:126)
com.prefabware.genlets.java.FornaxJavaBasicTest.testAppliedStereoType(FornaxJavaBasicTest.java:103)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestReference.run(JUnit3TestReference.java:130)
org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:460)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:386)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:196)
Is there anything else that I have to do apart from loading and applying
the hibernate profile on the model object? Is any explicit registration
required?
Thanks for all your help.
FUDForum. Page generated in 0.02971 seconds
