| Applying stereotypes [message #627835] |
Sun, 02 August 2009 02:39 |
Hello, I am doing my first UML2 profile and have been following the
article below.
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Intro duction_to_UML2_Profiles/article.html
It all seems to go well up until the 'Applying Stereotypes' section step 3:
1) Select an element (i.e. <Property> pendingOrders : PurchaseOrder [0..*]
in <Class> Supplier) in the UML editor.
2) Select the UML Editor > Element > Apply Stereotype
menu item.
3) Choose a stereotype (i.e. ecore::EReference), press the Add button,
then press the OK button.
When the dialogue appears with the available choices it is empty!? Hmm, I
have tried it several times and playd around with it and searched the
newsgroup but I can't work it out. I am sure it will be simple as all the
doco states that doing a lightweight extension is easy :)
For what reason could the choices dialogue be empty? I have applied the
profile as per the previous steps in the article.
Thanks in advance
Eban
FUDForum. Page generated in 0.02781 seconds
