Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Does Teneo deal with interfaces correctly?
Re: Does Teneo deal with interfaces correctly? [message #63195 is a reply to message #63165] |
Wed, 29 November 2006 13:26 |
Ilya Klyuchnikov Messages: 74 Registered: July 2009 |
Member |
Hi Martin!
yes - placement is mapped but it's mapped as subclass.
Really IAdapdable is just a bridge to org.eclipse.core.IAdaptable.
IAdaptable doesn't declare any fields.
What do I need?
I want that IAdaptable would be absent in mapping cause it's just behavior
interface.
So currently I received this result:
<class entity-name="IAdaptable" abstract="true" lazy="false"
discriminator-value="IAdaptable" table="`iadaptable`">
<meta attribute="eclassName">IAdaptable</meta>
<meta attribute="epackage">http://www.webamg.com/show/inventory</meta>
<id type="long" name="e_id" column="e_id"
access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<discriminator column="`dtype`" type="string"/>
<version name="e_version" column="e_version"
access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
</class>
<subclass entity-name="Placement" abstract="false" lazy="false"
extends="IAdaptable" discriminator-value="Placement">
<meta attribute="eclassName">Placement</meta>
<id name="id" type="long">
<column not-null="true" unique="false" name="`id`"/>
</id>
</version>
<property name="tag" lazy="false" insert="true" update="true"
not-null="false" unique="true" type="java.lang.String">
<column not-null="false" unique="true" name="`tag`"/>
</property>
<property name="name" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`name`"/>
</property>
<many-to-one name="type" entity-name="PlacementType"
cascade="merge,persist,save-update,lock,refresh" lazy="false"
insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`type_id`"/>
</many-to-one>
<property name="startDate" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="timestamp">
<column not-null="false" unique="false" name="`startdate`"/>
</property>
<property name="endDate" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`enddate`"/>
</property>
<property name="url" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`url`"/>
</property>
<many-to-one name="owner" entity-name="Placement"
<column not-null="false" unique="false" name="`owner_id`"/>
</many-to-one>
<property name="modified" lazy="false" insert="false" update="false"
<column not-null="false" unique="false" name="`modified`"
sql-type="timestamp"/>
</property>
<property name="revision" lazy="false" insert="false" update="false"
not-null="false" unique="false" type="int">
<column not-null="false" unique="false" name="`e_version`"/>
</property>
<bag name="info" fetch="subselect" lazy="true"
table="placementinfo_placement">
<key update="true">
<column name="`placement_id`" not-null="true" unique="false"/>
</key>
<many-to-many entity-name="PlacementInfo" unique="false">
<column name="`placementinfo_id`" not-null="true" unique="false"/>
</many-to-many>
</bag>
<bag name="children" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`owner_id`" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="Placement"/>
</bag>
<bag name="features" lazy="true" cascade="all,delete-orphan">
<key update="true">
</key>
<one-to-many entity-name="PlacementFeature"/>
</bag>
<property name="hidden" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="boolean">
<column not-null="false" unique="false" name="`hidden`"
sql-type="boolean"/>
</property>
</subclass>
But I need the same result that was before I introduce IAdaptable into
model - previously Placement did not implement IAdaptable. So I need this
generated mapping:
<class entity-name="Placement" abstract="false" lazy="false"
discriminator-value="Placement" table="`placement`">
<column not-null="true" unique="false" name="`id`" />
<generator class="native" />
</id>
<discriminator column="`dtype`" type="string" />
</version>
<column not-null="false" unique="true" name="`tag`" />
</property>
not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="false" name="`name`" />
</property>
<column not-null="false" unique="false" name="`type_id`" />
</many-to-one>
<column not-null="false" unique="false" name="`startdate`" />
</property>
<column not-null="false" unique="false" name="`enddate`" />
</property>
<column not-null="true" unique="false" name="`url`" />
</property>
<column not-null="false" unique="false" name="`owner_id`" />
</many-to-one>
sql-type="timestamp" />
</property>
<column not-null="false" unique="false" name="`e_version`" />
</property>
<key update="true">
<column name="`placement_id`" not-null="true" unique="false" />
</key>
<column name="`placementinfo_id`" not-null="true" unique="false" />
</many-to-many>
</bag>
<key update="true">
<column name="`owner_id`" not-null="false" unique="false" />
</key>
<one-to-many entity-name="Placement" />
</bag>
<key update="true">
</key>
<one-to-many entity-name="PlacementFeature" />
</bag>
sql-type="boolean" />
</property>
</class>
I need no IAdaptable in generated hibernate mapping.
Is there is any way to say Teneo: it's just a behavior interface - I would
not like it in your generated mapping?
Thanks.
Martin Taal wrote:
> Hi Ilya,
> Is Placement also mapped (it should be)?
> Here is another post about this topic:
> http://dev.eclipse.org/newslists/news.eclipse.technology.emf t/msg01437.html
> Can you read this post and let me know if this works for you (or not)?
> gr. Martin
> Ilya Klyuchnikov wrote:
>> Hi Martin!
>> I have updated my model and now have problem during hibernate mapping
>> generation.
>> I have class IAdaptable in my model which is mapped to
>> org.eclipse.core.IAdaptable interface:
>> <eClassifiers xsi:type="ecore:EClass" name="IAdaptable"
>> instanceClassName="org.eclipse.core.runtime.IAdaptable"
>> interface="true"/>
>> Also I have class that implements this Interface:
>> <eClassifiers xsi:type="ecore:EClass" name="Placement"
>> eSuperTypes="#//IAdaptable">
>> </eClassifiers>
>> So in generated code I have:
>> package com.webamg.show.inventory;
>> import java.util.Date;
>> import org.eclipse.core.runtime.IAdaptable;
>> import org.eclipse.emf.common.util.EList;
>> import org.eclipse.emf.ecore.EObject;
>> public interface Placement extends EObject, IAdaptable ...
>> BUT when I try to create mapping I get:
>> <meta
>> </id>
>> </version>
>> </class>
>> It's wrong for me - I need to have:
>> Also it's wrong cause IAdaptable is just interface - not an abstract class.
>> Is it a bug in Teneo or I need to customize behavior via jpa or
>> hibernate annotations in my model?
>> Thanks in advance.
>> Ilya
Re: Does Teneo deal with interfaces correctly? [message #63221 is a reply to message #63195] |
Wed, 29 November 2006 13:37 |
Hi Ilya,
You should try to set the @MappedSuperClass annotation on IAdaptable
Just as this post says (see also my previous reaction on your post):
This post also gives you some background of why also interface types are mapped.
I have entered a bugzilla for Teneo to move the info from this post to elver.org.
Let me know if this does (not) work for you.
gr. Martin
> Hi Martin!
> What do I need?
> behavior interface.
> <meta
> </id>
> </version>
> </class>
> <meta
> </id>
> </version>
> </property>
> </property>
> </many-to-one>
> update="true" not-null="false" unique="false" type="timestamp">
> </property>
> </property>
> </property>
> </many-to-one>
> update="false" not-null="false" unique="false" type="timestamp">
> </property>
> update="false" not-null="false" unique="false" type="int">
> </property>
> <key update="true">
> unique="false"/>
> </key>
> unique="false"/>
> </many-to-many>
> </bag>
> <key update="true">
> </key>
> </bag>
> <key update="true">
> </key>
> </bag>
> </property>
> </subclass>
> this generated mapping:
> <meta
> </id>
> </version>
> </property>
> </property>
> </many-to-one>
> </property>
> </property>
> </property>
> </many-to-one>
> </property>
> </property>
> <key update="true">
> unique="false" />
> </key>
> unique="false" />
> </many-to-many>
> </bag>
> <key update="true">
> unique="false" />
> </key>
> </bag>
> <key update="true">
> unique="false" />
> </key>
> </bag>
> </property>
> </class>
> would not like it in your generated mapping?
> Thanks.
> Martin Taal wrote:
>> Hi Ilya,
>> gr. Martin
>>> Hi Martin!
>>> generation.
>>> interface="true"/>
>>> </eClassifiers>
>>> <meta
>>> </id>
>>> </version>
>>> </class>
>>> class.
>>> Thanks in advance.
>>> Ilya
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Does Teneo deal with interfaces correctly? [message #63247 is a reply to message #63221] |
Wed, 29 November 2006 15:16 |
Member |
I will try
Martin Taal wrote:
> Hi Ilya,
mapped.
elver.org.
> gr. Martin
>> Hi Martin!
>> What do I need?
>> behavior interface.
>> <meta
>> </id>
>> </version>
>> </class>
>> <meta
>> </id>
>> </version>
>> </property>
>> </property>
>> </many-to-one>
>> </property>
>> </property>
>> </property>
>> </many-to-one>
>> </property>
>> </property>
>> <key update="true">
>> unique="false"/>
>> </key>
>> unique="false"/>
>> </many-to-many>
>> </bag>
>> <key update="true">
>> </key>
>> </bag>
>> <key update="true">
>> </key>
>> </bag>
>> </property>
>> </subclass>
>> <meta
>> </id>
>> </version>
>> </property>
>> </property>
>> </many-to-one>
>> </property>
>> </property>
>> </property>
>> </many-to-one>
>> </property>
>> </property>
>> <key update="true">
>> unique="false" />
>> </key>
>> unique="false" />
>> </many-to-many>
>> </bag>
>> <key update="true">
>> unique="false" />
>> </key>
>> </bag>
>> <key update="true">
>> unique="false" />
>> </key>
>> </bag>
>> </property>
>> </class>
>> Thanks.
>> Martin Taal wrote:
>>> Hi Ilya,
>>> gr. Martin
>>>> Hi Martin!
>>>> generation.
>>>> interface="true"/>
>>>> </eClassifiers>
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </class>
>>>> class.
>>>> Thanks in advance.
>>>> Ilya
Re: Does Teneo deal with interfaces correctly? [message #63271 is a reply to message #63247] |
Wed, 29 November 2006 15:30 |
Member |
Hi Martin!
@MappedSuperclass works fine.
Thanks a lot.
Ilya
> I will try
> Thanks
> Martin Taal wrote:
>> Hi Ilya,
> mapped.
> elver.org.
>> gr. Martin
>>> Hi Martin!
>>> What do I need?
>>> behavior interface.
>>> <meta
>>> </id>
>>> </version>
>>> </class>
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </property>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </property>
>>> </property>
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> unique="false"/>
>>> </many-to-many>
>>> </bag>
>>> <key update="true">
>>> </key>
>>> </bag>
>>> <key update="true">
>>> </key>
>>> </bag>
>>> </property>
>>> </subclass>
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </property>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </property>
>>> </property>
>>> <key update="true">
>>> unique="false" />
>>> </key>
>>> unique="false" />
>>> </many-to-many>
>>> </bag>
>>> <key update="true">
>>> unique="false" />
>>> </key>
>>> </bag>
>>> <key update="true">
>>> unique="false" />
>>> </key>
>>> </bag>
>>> </property>
>>> </class>
>>> Thanks.
>>> Martin Taal wrote:
>>>> Hi Ilya,
>>>> gr. Martin
>>>>> Hi Martin!
>>>>> generation.
>>>>> interface="true"/>
>>>>> </eClassifiers>
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </class>
>>>>> class.
>>>>> Thanks in advance.
>>>>> Ilya
Re: Does Teneo deal with interfaces correctly? [message #596316 is a reply to message #63165] |
Member |
Hi Martin!
What do I need?
interface.
</id>
</version>
</class>
</id>
</version>
</property>
</property>
</many-to-one>
</property>
</property>
</property>
</many-to-one>
</property>
</property>
<key update="true">
</key>
</many-to-many>
</bag>
<key update="true">
</key>
</bag>
<key update="true">
</key>
</bag>
</property>
</subclass>
generated mapping:
</id>
</version>
</property>
</property>
</many-to-one>
</property>
</property>
</property>
</many-to-one>
</property>
</property>
<key update="true">
</key>
</many-to-many>
</bag>
<key update="true">
</key>
</bag>
<key update="true">
</key>
</bag>
</property>
</class>
Thanks.
Martin Taal wrote:
> Hi Ilya,
> gr. Martin
>> Hi Martin!
>> generation.
>> interface="true"/>
>> </eClassifiers>
>> <meta
>> </id>
>> </version>
>> </class>
>> Thanks in advance.
>> Ilya
Re: Does Teneo deal with interfaces correctly? [message #596323 is a reply to message #63195] |
Hi Ilya,
gr. Martin
> Hi Martin!
> What do I need?
> behavior interface.
> <meta
> </id>
> </version>
> </class>
> <meta
> </id>
> </version>
> </property>
> </property>
> </many-to-one>
> </property>
> </property>
> </property>
> </many-to-one>
> </property>
> </property>
> <key update="true">
> unique="false"/>
> </key>
> unique="false"/>
> </many-to-many>
> </bag>
> <key update="true">
> </key>
> </bag>
> <key update="true">
> </key>
> </bag>
> </property>
> </subclass>
> <meta
> </id>
> </version>
> </property>
> </property>
> </many-to-one>
> </property>
> </property>
> </property>
> </many-to-one>
> </property>
> </property>
> <key update="true">
> unique="false" />
> </key>
> unique="false" />
> </many-to-many>
> </bag>
> <key update="true">
> unique="false" />
> </key>
> </bag>
> <key update="true">
> unique="false" />
> </key>
> </bag>
> </property>
> </class>
> Thanks.
> Martin Taal wrote:
>> Hi Ilya,
>> gr. Martin
>>> Hi Martin!
>>> generation.
>>> interface="true"/>
>>> </eClassifiers>
>>> <meta
>>> </id>
>>> </version>
>>> </class>
>>> class.
>>> Thanks in advance.
>>> Ilya
The Netherlands
Re: Does Teneo deal with interfaces correctly? [message #596333 is a reply to message #63221] |
Member |
I will try
Martin Taal wrote:
> Hi Ilya,
mapped.
elver.org.
> gr. Martin
>> Hi Martin!
>> What do I need?
>> behavior interface.
>> <meta
>> </id>
>> </version>
>> </class>
>> <meta
>> </id>
>> </version>
>> </property>
>> </property>
>> </many-to-one>
>> </property>
>> </property>
>> </property>
>> </many-to-one>
>> </property>
>> </property>
>> <key update="true">
>> unique="false"/>
>> </key>
>> unique="false"/>
>> </many-to-many>
>> </bag>
>> <key update="true">
>> </key>
>> </bag>
>> <key update="true">
>> </key>
>> </bag>
>> </property>
>> </subclass>
>> <meta
>> </id>
>> </version>
>> </property>
>> </property>
>> </many-to-one>
>> </property>
>> </property>
>> </property>
>> </many-to-one>
>> </property>
>> </property>
>> <key update="true">
>> unique="false" />
>> </key>
>> unique="false" />
>> </many-to-many>
>> </bag>
>> <key update="true">
>> unique="false" />
>> </key>
>> </bag>
>> <key update="true">
>> unique="false" />
>> </key>
>> </bag>
>> </property>
>> </class>
>> Thanks.
>> Martin Taal wrote:
>>> Hi Ilya,
>>> gr. Martin
>>>> Hi Martin!
>>>> generation.
>>>> interface="true"/>
>>>> </eClassifiers>
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </class>
>>>> class.
>>>> Thanks in advance.
>>>> Ilya
Re: Does Teneo deal with interfaces correctly? [message #596343 is a reply to message #63247] |
Member |
Hi Martin!
Thanks a lot.
Ilya
> I will try
> Thanks
> Martin Taal wrote:
>> Hi Ilya,
> mapped.
> elver.org.
>> gr. Martin
>>> Hi Martin!
>>> What do I need?
>>> behavior interface.
>>> <meta
>>> </id>
>>> </version>
>>> </class>
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </property>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </property>
>>> </property>
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> unique="false"/>
>>> </many-to-many>
>>> </bag>
>>> <key update="true">
>>> </key>
>>> </bag>
>>> <key update="true">
>>> </key>
>>> </bag>
>>> </property>
>>> </subclass>
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </property>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </property>
>>> </property>
>>> <key update="true">
>>> unique="false" />
>>> </key>
>>> unique="false" />
>>> </many-to-many>
>>> </bag>
>>> <key update="true">
>>> unique="false" />
>>> </key>
>>> </bag>
>>> <key update="true">
>>> unique="false" />
>>> </key>
>>> </bag>
>>> </property>
>>> </class>
>>> Thanks.
>>> Martin Taal wrote:
>>>> Hi Ilya,
>>>> gr. Martin
>>>>> Hi Martin!
>>>>> generation.
>>>>> interface="true"/>
>>>>> </eClassifiers>
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </class>
>>>>> class.
>>>>> Thanks in advance.
>>>>> Ilya
Current Time: Thu Sep 26 19:41:07 GMT 2024
Powered by FUDForum. Page generated in 0.06173 seconds
