Code generator problem with redefinitions [message #626798] |
Wed, 16 July 2008 09:41 |
--------------040808080705050600010608
I ran into the following problem when generating code from my metamodel.
It's when I use a combination of multiple inheritance an redefinition.
See the attached file for a minimal example.
I have a class C that specializes two classes A and B. A and B have
properties a and b, respectively. In C I redefine both properties. I
generate code for this model (with processing duplicate features). The
generated Java implementation class CImpl extends AImpl.
However, the generated code has the problem that it is impossible to get
the value of feature b in C, because eGet, etc., only go up the Java
inheritance hierarchy. Accessing C.b in any way leads to a stack
overflow. To me this looks like an oversight in the UML code generator
because it creates no code that takes UML multiple inheritance into
account for this scenario.
I changed my metamodel to use subsetting instead, but that's not quite
the correct semantics in my situation.
- Lutz
Content-Type: text/xml;
name="Test1.uml"
Content-Disposition: inline;
filename="Test1.uml"
<uml:Model xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" xmi:id="_qb8akM37EdqwVrslYOdUDA" name="TestModel">
<packagedElement xmi:type="uml:Package" xmi:id="_w8IxIM37EdqwVrslYOdUDA" name="Test">
<packagedElement xmi:type="uml:Class" xmi:id="_cv18EFM1Ed2i_6GVTGi6aw" name="A">
<ownedAttribute xmi:id="_flLxjFM1Ed2i_6GVTGi6aw" name="a" type="_cv18EFM1Ed2i_6GVTGi6aw" association="_flLxiFM1Ed2i_6GVTGi6aw">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_flLxjVM1Ed2i_6GVTGi6aw" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_flLxjlM1Ed2i_6GVTGi6aw" value="1"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_deB3yFM1Ed2i_6GVTGi6aw" name="B">
<ownedAttribute xmi:id="_zYp8DFM1Ed2i_6GVTGi6aw" name="b" type="_deB3yFM1Ed2i_6GVTGi6aw" association="_zYp8CFM1Ed2i_6GVTGi6aw">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_zYp8DVM1Ed2i_6GVTGi6aw" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_zYp8DlM1Ed2i_6GVTGi6aw" value="1"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Association" xmi:id="_flLxiFM1Ed2i_6GVTGi6aw" name="Association1" memberEnd="_flLxiVM1Ed2i_6GVTGi6aw _flLxjFM1Ed2i_6GVTGi6aw">
<ownedEnd xmi:id="_flLxiVM1Ed2i_6GVTGi6aw" name="source" type="_cv18EFM1Ed2i_6GVTGi6aw" association="_flLxiFM1Ed2i_6GVTGi6aw">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_flLxilM1Ed2i_6GVTGi6aw" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_flLxi1M1Ed2i_6GVTGi6aw" value="1"/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_i5YGIFM1Ed2i_6GVTGi6aw" name="C">
<generalization xmi:id="_lPuSc1M1Ed2i_6GVTGi6aw" general="_cv18EFM1Ed2i_6GVTGi6aw"/>
<generalization xmi:id="_OKjRM1M2Ed2i_6GVTGi6aw" general="_deB3yFM1Ed2i_6GVTGi6aw"/>
<ownedAttribute xmi:id="_TbwsLVM2Ed2i_6GVTGi6aw" name="a" type="_i5YGIFM1Ed2i_6GVTGi6aw" association="_TbwsKVM2Ed2i_6GVTGi6aw">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_TbwsLlM2Ed2i_6GVTGi6aw" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_TbwsL1M2Ed2i_6GVTGi6aw" value="1"/>
</ownedAttribute>
<ownedAttribute xmi:id="_UARHbFM2Ed2i_6GVTGi6aw" name="b" type="_i5YGIFM1Ed2i_6GVTGi6aw" association="_UARHaFM2Ed2i_6GVTGi6aw">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_UARHbVM2Ed2i_6GVTGi6aw" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_UARHblM2Ed2i_6GVTGi6aw" value="1"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Association" xmi:id="_zYp8CFM1Ed2i_6GVTGi6aw" name="Association2" memberEnd="_zYp8CVM1Ed2i_6GVTGi6aw _zYp8DFM1Ed2i_6GVTGi6aw">
<ownedEnd xmi:id="_zYp8CVM1Ed2i_6GVTGi6aw" name="source" type="_deB3yFM1Ed2i_6GVTGi6aw" association="_zYp8CFM1Ed2i_6GVTGi6aw">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_zYp8ClM1Ed2i_6GVTGi6aw" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_zYp8C1M1Ed2i_6GVTGi6aw" value="1"/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Association" xmi:id="_TbwsKVM2Ed2i_6GVTGi6aw" name="Association5" memberEnd="_TbwsKlM2Ed2i_6GVTGi6aw _TbwsLVM2Ed2i_6GVTGi6aw">
<ownedEnd xmi:id="_TbwsKlM2Ed2i_6GVTGi6aw" name="source" type="_i5YGIFM1Ed2i_6GVTGi6aw" association="_TbwsKVM2Ed2i_6GVTGi6aw">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_TbwsK1M2Ed2i_6GVTGi6aw" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_TbwsLFM2Ed2i_6GVTGi6aw" value="1"/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Association" xmi:id="_UARHaFM2Ed2i_6GVTGi6aw" name="Association6" memberEnd="_UARHaVM2Ed2i_6GVTGi6aw _UARHbFM2Ed2i_6GVTGi6aw">
<ownedEnd xmi:id="_UARHaVM2Ed2i_6GVTGi6aw" name="source" type="_i5YGIFM1Ed2i_6GVTGi6aw" association="_UARHaFM2Ed2i_6GVTGi6aw">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_UARHalM2Ed2i_6GVTGi6aw" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_UARHa1M2Ed2i_6GVTGi6aw" value="1"/>
</ownedEnd>
</packagedElement>
</packagedElement>
</uml:Model>
name="TestModel.ecore"
filename="TestModel.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="TestModel"
nsURI="http:///TestModel.ecore" nsPrefix="TestModel">
<eSubpackages name="Test" nsURI="http:///TestModel/Test.ecore" nsPrefix="TestModel.Test">
<eClassifiers xsi:type="ecore:EClass" name="A">
<eStructuralFeatures xsi:type="ecore:EReference" name="a" ordered="false" lowerBound="1"
eType="#//Test/A"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="B">
<eStructuralFeatures xsi:type="ecore:EReference" name="b" ordered="false" lowerBound="1"
eType="#//Test/B"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="C" eSuperTypes="#//Test/A #//Test/B">
<eAnnotations source="duplicates">
<contents xsi:type="ecore:EReference" name="a" ordered="false" lowerBound="1"
eType="#//Test/A">
<eAnnotations source="redefines" references="#//Test/A/a"/>
</contents>
<contents xsi:type="ecore:EReference" name="b" ordered="false" lowerBound="1"
eType="#//Test/B">
<eAnnotations source="redefines" references="#//Test/B/b"/>
</contents>
</eAnnotations>
</eClassifiers>
</eSubpackages>
</ecore:EPackage>
--------------040808080705050600010608--
FUDForum. Page generated in 0.26597 seconds
